Question about Lexmark C533DN InkJet Printer
Error 1203 displayed - Lexmark C533DN InkJet Printer
  • Lexmark Master
  • 4,338 Answers
Use a kleenex with a few drops of water to dampen and clean off the contacts in the ink cartridge holder .
Then before you print anything, you should run a"ligned the catridges" a couple times then run "clean catridges "a couple times.
Print the test page to see how it's look and way you go.
Be sure not to leave any debris of kleenex on those holder contact panel.
Also, make sure the contacts on the cartridges are not globbed up with ink. Clean them by damping a kleenex or a soft cloth. put the kleenex on the table and press the contacts of the inkcartridges on it. This will "wick" the ink and make sure it is flowing ok.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Dec 01, 2008
How do I correct error h5 on a Sharp printer AR-5620N?
Hello Sudhir,
The error code H5 means there was at least 5 pages in a row where the paper did not come out of the printer correctly (most likely paper jams. The following manual will direct you on the steps needed to clear the code, please note especially page #8-3
Service Manual SHARP AR 5618 5620 5623 SME
The following video should help also;
Jan 09, 2017 | Sharp Office Equipment & Supplies
Sharp ar gives me error number h4 how to let it work again
The error H4 stands for the heater roller H3 (Fuser) temperature is low and probably burnt out. You need to call for service.
Jan 08, 2017 | Sharp Office Equipment & Supplies
Toshiba estudio 455 Error Code E030
E030 indicates jam error on exit...U need to see where the paper stop and why...
Jul 28, 2015 | Toshiba Office Equipment & Supplies
My printer brother dcp7065dn disply 71 and72 error
This is codes for the ink cartridge. The code means there is a problem with the cartridge. Change them both and restart the machine.
Jan 13, 2015 | Office Equipment & Supplies
How do i solve an error e000-0000 canon ir 2202 please
Dear
Its related to the fixing temp. do the error clear on service mode. then check the fixing film assy. heater circuit contact points for corrosion. Replace it.
Thanks.
Dec 12, 2014 | Canon Office Equipment & Supplies
Hp laserjet m1522f error 5 turn off and on
Hi, Error 5 is a Scanner error. When turning the printer on, have the lid up so you can watch the scanner movement. Does it move smoothly? It should go through a warm up and you should be able to watch the scanner movement. If there is a problem with the scanner, there isn't a lot you could do except. The service manual says the scanner assembly should be replaced. If it was my printer, I would try to take a closer look at the scanner assembly and check to see if the scanner unit is bound up somewhere, or maybe a drop of 3 in 1 oil on the scanner rails. Let us know what happens.
thanks
Oct 02, 2013 | Office Equipment & Supplies
Error code 3501
HI
I HAVE KONICA C6500
ERROR CODE 3501 and 3802 but know the error 3501
I know it rech high temperature I change the sensor 1 UP fuser roller
and I reset the error, the machine start and stop again with error 3501
Oct 01, 2013 | Konica Minolta Bizhub C 6500 Copier
Ricoh 1045 error code sc 395
fix copier is a youtube channel
fixing error in videos
this is a video see you how to fix sc 395
https://www.youtube.com/watch?v=cI6o6mYOqow
Oct 07, 2012 | Ricoh Aficio 1045 Black and White Copier
HP Laserjet 3330. Scanner bulb warming up doesn't go away. I have done the "solution 1" as discribte but nothing is happening. It goes like: - i put the power on, hewlett packard is flashing, the...
How does the bulb look? Is it bright or kind of dim. The bulb warming error is designed to halt use of the machine until the scanner bulb reaches the correct output level. As these are basically a flourescent tube, they will dim over time and at a certain point they will not generate enough light to enable proper scanning. If the bulb is dim, it will require replacement.
Mar 14, 2011 | Office Equipment & Supplies
Lexmark C533DN InkJet Printer Logo
67 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Sanath Kumar V
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
