Question about Stanley Factory Reconditioned Bostitch U/CPACK270 Finishing Nailer, Brad Nailer/Stapler & Compressor Combo Kit
BostitchCAP60-OF won't pressure up past 95lb and keeps running
I have a Bostitch CAP60-OF that wont shut off and wont build pressure past 95 lbs. I believe it use to shut off at 120lbs
  • Anonymous Mar 21, 2014
    gas motor shuts off when it builds proper pressure
    President:
  • Stanley Master
  • 1,388 Answers
This comperssor is oiless thus has a vinyl piston ring that wears quite fast depending on use and conditions at the work site. Slow pressure build or cycle never completes indicates a worn cylinder and piston ring. I would replace the cylinder, piston ring, valve plate, and intake valve. These parts are not expensive and available at www.bostitch.com. enjoy
Posted on Dec 01, 2008
Why does my pump loose pressure
Sounds like your not using enough water, and or your pipes to sprinkler is to to small, causing pump to build up to cut off head. I cant lay my hands on a performance chart for your pump, but 60 psi cut off and 20 on sounds about right. Try running another tap when your sprinkler is running, and see if this keeps your pump running
Mar 25, 2015 | Utilitech 1-HP Cast Iron Convertible Jet...
Why will my bostitch pancake compressor 240 psi tank 180 regulator that the guages will not show building pressure
Hi, There are different posibilities. I would need more information. Was it always like that? Does the guage on the main tank and the guage on the regulator both not show more than 20psi? When the auto shut-off is triggered do you feel there is more than 20 psi in the tank?
Sep 15, 2014 | Stanley NEW Bostitch 2 HP 6 Gallon...
Stanley Bostitch compressor cpack model runs and runs but won't fill tank.
check for any air leaks and fix as needed. then look for oil coming from cylinder heads , if oil is coming from heads you have blown head gaskets ,it wont build pressure like this. you might also check the pop off valve to be blown open. push the pin in and see if air starts to build up then. If so get a new valve.also check the drain valve under the tank and make sure its closed.
Apr 17, 2013 | Air Tools & Compressors
My compressor runs all the time. what can i do to make it build up pressure the shut down
I believe its called a pressure sensor Had the same problem probably best to take it to a professional
Mar 28, 2013 | Stanley Bostitch 2hp 6gal Air Compressor...
I have a flotec 1 hp pump. Wife washed 3 loads of clothes in a row and noticed we run out of water a while later. I shut pump off and noticed pressure tank low on air. I put 18 lb. air in tank and...
If in the past your system can build-up pressure up to 40 psi even if the supply valve is open and water is being used in your house, then your pump impeller maybe already worn out that's why its pumping capacity was reduced.
Nov 12, 2012 | Flotec Corrosion Resistant Shallow Well...
I have Bostich CAP2040-OF compressor that initially would not shut off after building pressure. I would let it build up until the needed pressure then shut it off for use then turn it back on etc. Now...
You could have a combination of both, but most likely worn cylinder. Easy to check. Remove cover, with compressor running spray soapy water on all fittings including under pressure switch. Repair as needed. If no leaks, unplug compresor from power and turn crank until piston is at top of stroke. Look for scratches / worn area close to top of cylinder. If worn, replace cylinder / piston ring (pressure is leaking past cylinder/ring). If it looks ok, then most likely problem is head gasket or reed valves. Parts are available at www.bostitch.com Good luck!
Feb 10, 2011 | Stanley Air Tools & Compressors
I have a bostich cap2060p that stays at 80 psi. it wont build pressure past that but doesnt shut off either. there are no leaks that i can find in lines etc. and head gasket is good. could the pressure be...
My guess is the pressure switch is stuck. Unplug it take the cover off where you turn it on and tap around the contactors lightly with a screwdriver. Then plug it back in and try it.
Feb 03, 2011 | Stanley NEW Bostitch 2 HP 6 Gallon...
I have a bostitch 6 gal pancake compressor that won't build pressure past about 20 lbs. when I turn it off I don't hear air leaking out anywhere and when it's running it runs at a higher pitch ( similar to...
I'd pull the cover off to expose top of cylinder head and have a look at any intake air filter. In parts diagram, It appears there is a small one that would likely clog during the texturing process.
Jan 26, 2011 | Stanley Bostitch CAP2060P 105 Amp...
My compressor won't build pressure over 90lbs
Small leak will prevent the unit from building proper pressure. Check all connections with soapy water and repair as needed (including under cover). If no leaks are found check cylinder for scratches. Push piston to top of stroke and check walls for fine scratches. If scratched, pressure is leaking past vinyl piston ring. If no scratches or leaks, most likely reed valves, head gasket or combination of both. Easy test, with compressor running and attained 90 lbs, place finger over air intake and check for good suction (carefull could be hot) . If good suction, then air is leaking somewhere, of no suction suspect reed valves/worn cylinder, if air seems to be blowing out of intake, suspect reeds /gaskets. Good holidays
Dec 13, 2010 | Stanley FactoryReconditioned Bostitch...
WILL NOT BUILD UP AIR PRESSURE PAST 20 LBS.
Check to see if air is leaking past 'pressure relief' valve. It's probably leaking and that's where all the air is going.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Sep 11, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Stanley Factory Reconditioned Bostitch U/CPACK270 Finishing Nailer, Brad Nailer/Stapler & Compressor Combo Kit Logo
899 people viewed this question
Top Stanley Air Tools & Compressors Experts
John Trevino
yoopertech
Mike
Are you a Stanley Air Tool and Compressor Expert? Answer questions, earn points and help others
