Question about Dell Dimension 3100 PC Desktop
Dell System DV051 Not working prop. after storm
I ersed the hard drive with a eraser disk. Now
I get this error.
UNABLE to locate
media Direct Bios table
Error w/ MD3 Power Button
When I try to reload software from orig. disk
    Master:
  • 461 Answers
I believe this is due to Media Direct requiring a 2G hidden partition and entries in the MBR. As I understand it you have to boot from the Media Direct disc first for it to recreate the partition assuming it has been deleted then install your OS. If you do not want the Media Direct then you should be able to use the OS disc recovery console to repair the MBR.
More info can be obtained from the Dell Forum
Posted on Dec 12, 2008
Dell 8400 Boots to Black Error Screen in XP States to reinstall System 32
This might be caused by hard-drive failure. You should run hard drive test from BIOS to make sure hard drive is ok. You can access BIOS by pressing F2 during start up, from there start hard disk self test and wait for it to complete.
If hard drive is ok after test, insert in your original Windows installation media and reinstall OS.
Oct 02, 2012 | Dell Dimension 8400 PC Desktop
Dell inspiron 1545 laptop wont boot. Error unable to locate hard disk drive
First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Jan 21, 2012 | Dell Inspiron 15 1545 Notebook
I am unable to format my 40 GB Hard Disk (samsung) with WinXP Installation CD. After Doing Patition and format it comes unable to format
you have to format your hard drive using a third party disc to erase everything on your hard drive
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
note this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system
(note after you have loaded the operating system you should go back and change the first boot device to your hard drive)
hope this helps
Aug 06, 2011 | Samsung (SP0411N) 40 GB Hard Drive
I turn my computer on, it shows the dell startup screen and then goes strait to a blank screen, no cursor nothing. when i try start in safe mode, and push F8 it beeps. Please help
Well what i can figure out is that your OS is not being loaded, thats the primary issue because of which you are getting a blank black screen and there can be 2-3 reasons why it is not being loaded.
1. Issue with the Hard drive
2. Issue with the RAM disk
3. Issue with BIOS
Here is some troubleshooting you can do :
At the system start up press Pause and check to see if POST has succeeded for all the hardware devices. If it is failing for any device that means that device is not getting powered on so you have to fix that first.
If it succeeds then you need to check our BIOS, at the DELL Stratup screen press F2/F12 (what ever works on your system) to enter BIOS menu. If it is entering that means BIOS is also ok.
So now you need to check your RAM and Hard Disk so for that try booting up from a CD, if it boots from CD and is going to installation screen then it means that your RAM is also perfectly fine and there is something wrong with Hard drive because of which BIOS is not able to locate MBR on the hard disk and so is unable to load OS.
It generally happens if there are some bad sectors on the hard disk so For that you can perform Disk Checking on the hard disk. Disk checking will repair the soft errors on the HD if any but if there are Hard errors which means if some sectors are damaged permanently then you can't anything and have to purchase a new HD.
Hope it helps you.
Plz vote and comment if you like the soluition.
Thanks !!
Nov 30, 2010 | Dell Inspiron Mini 10 Notebook
DISK BOOT FAILURE, INSERT SYSTEM DISK AND PRESS ENTER... i have a mother board K7S741MG-6L, bios version 426wp225, i have this problem BIOS CHECKSUM ERROR , KEYBOARD ERROR or NO KEYBOARD PRESENT (which is...
your hard disk is disconnecetedor loose . pls check the hard disk power cable & IDE or SATA cable. Then check BIOS hard disk detected or not if hard disk is not detected your hard disk is faulty.
Dec 11, 2009 | Foxconn WinFast K7S741MG Motherboard for...
Dell DV051 - message no boot device
Go into your BIOS by pressing F2 and see if the hard drive is being recognized in there. If it is then reset defaults in the BIOS and reboot and see if the computer will boot back into windows. If it doesn't then you'll need the discs to restore the computer back to factory defaults. If the hard drive is not being recognized in the BIOS then make sure the hard drive is hooked up properly. IF it is and its still not being recognized in the BIOS then the hard drive is bad.
At that point then you'll need to replace the hard drive and use your discs to restore the computer back to factory defaults.
Aug 07, 2009 | Dell Inspiron 530 Desktop Computer...
Dell media direct won't work
Here is the steps,
1.Turn on your computer.
2.Insert the reinstallation media (Dell Media Direct CD/DVD) into the CD/DVD drive, then restart the computer.
3. press F12 when the bios page comes up and then select CD/DVD drive from the boot menu.
"Option 1" from the menu if you wish to use all of the hard drive for you operating system installation. This is the most common selection and how is your computer was originally shipped to you, unless you specified an operating system partition size at the time you ordered you computer.
"Option 2" to designate a size for your operating system and have a data partition. This allows you to specify a size for the operating system partittion, leaving the remainder, of the hard drive configured as a "data" partition ("D")
4. Once you have prepared the drive and you have returned to the main recovery menu, remove the installation media and replace it with you operating system reinstallation media. Select the option to reboot your computer. If your computer does not automatically start the media, press <F12> to access the boot menu and select the Cd/DVD boot option.
5.Install your operating system, select the Primary partition when prompted. If you have two hard drives, select the primary partition on the same disk where hte media direct partition resides. Once the OS is installed and the necessary drivers are installed you can begin the reinstallation of the dell mediaDirect software.
Good Luck,
Austin
Feb 12, 2009 | IBM ThinkPad T30 2366 Notebook
Media Direct Problem witn more then 2 disk paritons.
Usually Media Direct is pre-installed on a Dell Portable System. It is installed on a media direct partition. If you reinstalled windows and if you formatted yor hard drive then you may have to reinstall media direct in 2 different ways.
Media direct 2 requires to have windows installed first.
Media direct 3 requires to have the Media Direct CD run first.
Feb 06, 2009 | Dell XPS M1530 Notebook
Dell Dimension 3100 PC Desktop Logo
482 people viewed this question
Alun Cox
