Kenmore Elet he3t Model# 11042936200 will not start its wash cycle.
  • 6 Answers
SOURCE: kenmore elite HE3t
Unplug your machine, remove the top panel, doublecheck all of the wires are securely connected. Sometimes the wires are loosened due to the vibration of the washer. Hope this works for you! It worked for our Kenmore Elite H3 when no cycles would start and flashed the error code "dL/F" (door lock failure).
Posted on Jan 02, 2008
  • 12 Answers
SOURCE: Kenmore model 110 washer will not drain at end of wash cycle
It could be the lid switch or the timer.
Posted on Jan 31, 2009
  • 79 Answers
SOURCE: error code F9 for kenmore elite washing machine He3T
it will not let you unlock the door because the machines full of water?--the machine will not finish its cycle because the vacume switch is still detecting water , The water will not drain because the pump is blocked with something , probably a wire from your underwire bra,all you can do is undo a pipe undernieth and let the water drain away and take the pump to bits ?There may be an inspection cap somewhere on the front at the bottom
Posted on May 23, 2009
SOURCE: I have a Kenmore HE3t
There is a black plastic piece that sticks out from the machine. It is located at about
2 o'clock. You probably broke off the piece as I did with mine. If you have a wooden skewer (or something like it), stick it in and depress the button. You can glue the skewer in place.
That should fix your problem.
Posted on Aug 17, 2009
Testimonial: "the post on August 17th fixed my machine. It was the button on the door that was broken off."
jsrock516
  • 5911 Answers
SOURCE: Kenmore 80 Series Model 110-25862 that won't start wash cycle
Check your lid switch. This is the most common cause of the problem you are experiencing. Symptoms may include, filling and stopping on the intial fill cycle, a wash tub that will not drain, and stopping right after the wash cycle and not advancing to rinse or spin cycles.
The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r3557193-replacing_a_lid_switch
On some models, the lid switch is located under the top casing by one of the lid hinges. You will know if you if you have this type of switch, because It does not have a lid strike and the small hole on the right hand side of the wash tub will not be present. This switch is actuated (toggled) by a rod on the lid hinge. With this type of switch, if you locate it and it can be toggled by hand, you may only need to adjust the actuator by bending it slightly.
A replacement lid switch (if required) can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
This is a very simple and inexpensive repair that you can do without the assistance of a repairman. The average price is about $20 - $30 if you perform the repair yourself. Prices differ between sites so shop and compare. The part number for a replacement for your washer is 3949238.
NOTE: You DO NOT need to drain the washer to replace the lid switch. Once a defective switch is replaced, the washer will drain.
If you have questions, or need additional assistance, please post back and let me know. I hope this information is helpful.
Posted on Mar 19, 2010
My HE3t Kenmore washer will not start. All the lights come on and you can select the cycle but the start button will not start the machine. We did unplug it to reset the machine but that did not wor
This may be a stupid question...but is the water turned on? Stranger things have happened!
If the drum inside doesn\'t turn, it may be an electronic issue. Hopefully the washer is under warranty. Best of luck!
Oct 09, 2014 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Whirlpool washer duet is flashing after adding garmet. Will not return to washing
April 8 2002 DIV 26 SOURCE 110 KENMORE ELITE HE3 & HET WASHERS "ADD-A-GARMENT" INDICATOR LIGHT ON DOOR WON'T UNLOCK WHEN PAUSE/CANCEL BUTTON IS DEPRESSED.
MODELS: See additional page for Kenmore model numbers
COMPLAINT: Due to a Microcomputer Machine Control software error , the ADD-A-GARMENT feature becomes inoperative.
CORRECTION: The Microcomputer Machine Control must be replaced with a service part that has been reprogrammed to prevent ADD-A-GARMENT feature loss.
PARTS: Order electronic control listed on this service flash by model from Division 26 , Source 110 following normal ordering procedure.
MERCHANDISE CODES: WASHER Service Flash - Model Nurnbers for: Kenmore Elite HE3 & HE3t Washers: "ADD-A-GARMENT" indicator light on door won't unlock when Pause/Cancel button is depressed. Kenmore models with serial Numbers beginning with CSL23 through CSM04 11042822200 11042824200 11042826200 11042832200 11042834200 11042836200 11042922200 11042924200 11042926200 11042932200 11042934200 11042936200 Electronic conrrol p/n 8181900 Electronic control p/n 8181899
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 29, 2010 | Whirlpool GHW9300 Duet Washer
Kenmore h2 error code
Jan 11, 2010 | Kenmore 46462 Front Load Washer
I have a whirlpool ghw9100lw the light is flashing but it will not start
Aug 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I have a Kenmore HE3t 2002 model washer that the buttons light up but the washer will not start when the start button is pushed. You can select any cycle ad it lights up.
Aug 07, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Kenmore he3t door locked cant reset or open
Kenmore HE3t sanitary cycle setting has changed. Water temp selection only allows Hot/Cold selection but should offer the Extra Hot selection. All other settings test out properly. Is there a way to reset factory settings for cycles?
Jul 08, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Kenmore Elite HE3t model 42922
After the complete wash cycle is finished, the clothes are still soaking wet sometimes. This is not an every load problem.
Aug 12, 2008 | Kenmore 46462 Front Load Washer
HELP my clothes and sheets are being held hostage !!!!
first unplug the power cord and plug it back.
select drain/spin with no spin after the cycle completed the door will open.
Jul 29, 2008 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Washing Machines Logo
102 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
