Question about Gateway Computers & Internet
Dual video drivers
I have a Gateway 500s. I bought it in October of 2002. I does what I need it to do. I have a Gateway 20" monitor, thats about 2 years old. My daughter has a Samsung 731B 17" monitor she gave me. I was wanting to conect both to computer. I'm guessing I will need a duel video driver. Is it possible with an older machine? If so what would I need to do it?
Thanks, David
    Sergeant:
  • 207 Answers
David,
If your Video card has two VGA connectors on it, then your all set you just need to plug in the new monitor and your good to go.
If you have one VGA connector on your video card and one on *********** board or a seperate card then you may or may not need a new driver.
If the second video connector has a GPU made by the same manufacturer as your primary Video card then your existing driver will likely work. (Example; If their both Nvidia or their both ATI etc..)
Note of Warning: Mixing video processors is not wise. ATI and Nvidia Drvers don't play nice with each other
Good luck
Dave
Posted on Dec 01, 2008
Display colors on monitor
In windows7 you can go to your device manager and remove and re-install your video drivers.
Also check for flags under that device.
You can get updated drivers for your unit at Gateway
Apr 01, 2014 | Gateway NE56R Dual Core 2.10GHz 4GB 320GB...
How can I use 2 monitors on my GT 4010?
You need a card that will support dual monitor, even if it is VGA and DVI.
Jan 14, 2013 | Gateway GT4010 (RBGT4010) PC Desktop
Need video controller driver for gateway esx 500s bios number RG84510A 0029307386 serial number
Video drivers can be downloaded easily from: Driver Update Software for XP Vista 7 8. Download the tool, and make your update. Wish you best of luck
Sep 06, 2011 | Gateway 500 S PC Desktop
Monitor goes blank.
Did you swap the monitors to see if the problem follows or stays at the same video output port since you have dual monitors set up? Need verify before opening up the monitor.
Mar 30, 2010 | Gateway FPD2275W LCD Monitor
Monitor (no signal) after replacing mother board and CPU
try only connect Monitor and keyboard, and check for booting (disconnect all the rest (HDD, CD DRIVE, Sound Card, Network Card, ....) then try connect one by one and always off to change hardware config.
If dont work with monitor and keyboard, try reset bios(jumper),check again, then replace memory modules (must be compatible to new motherboard), evan dont work, send back the motherboard for defective motherboard.
Jan 14, 2010 | Gateway Intel (El Paso 2) Motherboard P4...
I cannot get the signal on my monitor . I bought a V203H 20 inch monitor. I have connected the VGA, the light comes on the monitor, the intiail Windoes stuff shows and then I get a no signal from the...
Two thing to remember on this situation....
First:
On your laptop make sure you switch the dual mode view on your laptop, if you installed your video driver correctly right click on desktop, select there option switching into dual view or extended view, alternative is hold down the FN button or your laptop keyboard and press the Fucntions key (look for the function key with the monitor icon) press and release it while holding the FN key until there is a video on your external VGA monitor.
Second:
If the settings on your laptop is ready for dual or extended view, look for the SOURCE button or your monitor, if not available look for the AUTO button, pressing the Auto button automatically searches the available signal on the VGA, HDMI, or other sources of video on your monitor.
Oct 21, 2009 | Acer Computers & Internet
My Gateway 500s monitor is stuck in power save mode
Try tapping the F8 key while booting the computer, you will get the start up menu, choose safe mode, when you log on, go to the display settings, that is right click on the desktop, properties, screen saver, advanced and make sure that hibernation is off, along with turn off disks or whatever , probably see turn off monitor after XX minutes, I make ours 15 minutes (150 computers and servers), I don't let the disks turn off. Choose always on also, not home/office. Try this and see if these settings help.
1r1sh
A+
Net+
MCP
Jan 24, 2009 | Gateway 506GR PC Desktop
GATEWAY 500S
hello,
If you hear beeps, there only two possible problem in it. the memory and the video card.
If dont hear then verify the motherboard and the processors.
first, check or clean and refix the memory then test. if not work, then the video card if add remove and clean but if it is built in to the board, then check the board.
pls tell me what happen after youve done. If need more solution tell me.
please don't rate me if the solution not resolve the issue and need more solution but if fix then rate me fixya.
melnavz
Jun 04, 2008 | Gateway 506GR PC Desktop
Video card for Dell 531s
This computer uses a PCIe-16 slot, so any half-height dual-monitor card with DVI would do for you. The XFX Geforce 7200GS with 256MB memory has dvi and vgb outputs. It supports the resolution of your 20" Syncmaster, and is around $40 at Newegg.com at this time.
Nov 04, 2007 | Computers & Internet
Computers & Internet Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
