My tv is stuck in the DVD mode and i cannot disable it. Any thoughts?
My tv shows up but does not show a bright picture
That set is a beauty if it is equipped with the built in DVD player--they were all poor quality---only possible but not easy thing is it can be got at by removing entire front grill beneath the front screen and has only a few plugs to actually remove the unit.
I presume you have tried to change inputs with the remote etc.
SOURCE: dvd stuck in dvd
Lay the TV, face down on a folded towel. Remove all the screws. Note: there is one perimeter screw with machine threads; all the others are the same.
Remove the four black screws from this area:
Then you can pop the back loose and slide it towards the end where the black screws were. It just lifts off and there are no wires attached.
Now you can see the DVD player. I used the end of a plastic pen to shove against the edge of the DVD that you can see through this slot.
Press on the DVD's edge until you see it come out the entry slot.
You can see the DVD slide out the entry slot as you are pushing.
When done, slide the back into place and replace the screws.
