SOURCE: Panasonic dv player keeps stopping
Does it freeze in play also? Might be an optical pickup issue and require a replacement pickup.
SOURCE: Player Does not play any type of Disc
Press case lid where it attaches to player. If this makes unit react you have a defective lid switch. You can probably put some weight over it to hold lid down and it will operate. Otherwise switch must be repaired
SOURCE: LG V8824w DVD/VCR no video
rtfm.
Once the setting for progressive scan output is entered,
an image will only be visible on a progressive scan
compatible TV or monitor. If you set Progressive Scan
to On in error, you must reset the unit.
1) Remove any disc from the unit and close the disc
tray. See that "NO DISC" is displayed on the display
window.
2) Press STOP and hold it for five seconds before
releasing it. The video output will be restored to the
standard setting and a picture will once again be visi-
ble on a conventional analog TV or monitor.
SOURCE: DVD Freezing / skipping
It almost has to be the discs. Try them in a friends unit.
I had a similar problem with DVD's I burned and had printed labels and put the label on the discs. It caused the disc to be out of balance. I peeled them all off (what a job) and the discs play fine now. I'm now a "magic marker" person... :)
Geno
SOURCE: Sony CD/DVD Player DVP-NS50P not playing my avi files DVD+RW
You need to convert avi files to dvd format before burning, otherwise the player won't recognize them. Google "avi to dvd" and you'll find a number of free or pay programs that will do the conversion for you.
