Question about Dishwashers
F p dishdraw f1 code when using top draw - Dishwashers
Most likely its the upper and lower lid motors, fisher and paykels poor drain hose is the main cause for these problems its a Y shaped connector and when the both drawers are being used the water rushes into it self and causes it to back up which in case causes these error codes
Posted on Jan 05, 2009
F1 Error code
F1 is flood error. basically water has arrived at the bottom board. you can unplug the dishdrawer, remove the bottom drawer and dry the board at the bottom, maybe with a hair dryer carefully. this will reset the fault, but this is a fault that may appear again. replace the actuators that close the lid of the drawer that is leaking (look for signs of water running our of one of the drawers).
Jul 13, 2014 | Fisher and Paykel DishDrawer DS605FDSM...
F1 code
F1 is a flood sensor fault code. The problem sometimes comes from loading the machine above the top of the drawer. When the inside lid comes down before the dishwasher starts, it cannot seal completely and water can spray into the outer cavity. The water accumulates in the inner bottom where there is a sensor. The sensor protects the electronic components from getting wet by warning you of the water which you cannot see. The solution is to remove the bottom drawer and wipe out, then dry the compartment with a fan or a small space heater. Once dry, the machine will function as usual.
Jan 24, 2013 | Fisher DD603FCSS Dishwasher
I have a 10 year old dishdraw (Model No DD601v2). It is displaying a fault message "F1" on the top draw display and will not start. What fault is this indicating?
Normally F1 should display in both drawers.
But this is a bit unsual. Please confirm if you are still able to operate the bottom drawer.
Nov 25, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
FP DD603 fills water, stops error 01 crossed faucet symbol
I had the opportunity to work on a Fisher & Paykel DD632 dishdrawer a couple days ago. By the way, I am a big fan of Fisher & Paykel equipment--if you ever have the opportunity to work on one, you'll see why. The engineering is elegant in its simplicity. Well-engineered equipment is actually much easier to work on because they have designed serviceability into the product.
Anyway, the problem with this particular dishdrawer was that the top drawer (with an 11 minute wash) was giving an F1 error code after the initial rinse, about five minutes into the cycle. The F1 code indicates an overfill condition. One of the most common causes for an overfill fault is that the dishwasher cannot pump out the dirty water due to a plugged drain hose.
So, I put the dishdrawer into diagnostic mode and tested the fill and pump out functions--everything was peachy. I ran the top drawer in a normal wash cycle and, sho 'nuff, the drawer faulted out on F1 after the first rinse. Well, Houston, we had a problem and it was time for the Samurai to break open a can of whup-*** on this dishdrawer. First thing I did was pull the front panel off the drawer.
Fisher Paykel DD603 dishdrawer with the front panel removed.
With that front panel off, I pulled the wire harness connectors off the main control board (lower right-hand side) to inspect for gook us. None found--my quest continued.
The next step to remove the bottom drawer from the unit so I could inspect the flood switch. In order to do this, I had to remove the wire harness cover on the underside of the drawer. This is what the underside of the dishdrawer looks like with the bottom cover panel removed:
Fisher Paykel DD603 dishdrawer, looking at the underside of one of the drawers with the wire cover plate removed.
With the bottom cover off, I could unclip the wire harness, fill hose, and drain hose. Then I unclipped the linkage at the back of the drawer and lifted the drawer off the slider arms.
After noting the positions of the wires on the flood switch and removing them, I unclipped the switch housing from the base panel. The switch housing contains one switch for each drawer. The switches are wired normally closed (NC) and each switch has three spade connections, so it's important to note where the wires went. With the switch housing out, I could ohm out both switches and both checked good. I inspected the contacts and noticed that one of them was oxidized, evidenced by discoloration.
I had a flash-back to my Navy days and heard Petty Officer (AT1) Crowe's voice in my head, "Here, take this ruby red eraser and clean off them contacts. That'll restore the current flow for that circuit. Good to go, Sailor." You gotta understand, Petty Officer Crowe was my technical guru in the Navy--he taught me many of the practical and theoretical troubleshooting skills that I still use today.
So I cleaned the contacts as instructed by Petty Officer Crowe's mental image in my brain and reassembled the dishdrawer. I ran the top drawer and...no F1 error code! I ran it several more times just to be sure.
OR ,if this is not the case next thing to look for is
If you have problems with a plugged drain hose
Dishwasher Drainology
Your dishwasher sounds like it's working up a storm, draining all that yucky dirty water out, but you open the door and all that dirty water is still there. Houston, we have a problem. OK, grasshopper, go grab you a cold one and hang on for a magical mystery tour into what causes dishwasher draining problems, also called the ancient and mystical art of dishwasher drainology. Let's take 'em one at a time:
* Using Too Much Detergent
Some fancy dishwashers with electronic controls have sensors that detect when the pump is not pumping water. Using too much detergent creates a great head of foam in the dishwasher basin, like pouring a beer too fast into a glass. So if you use too much soap in one of these so-equipped dishwashers, the sensors think the dishwasher is empty and cuts off the pump (For you gadget geeks out there, it senses the pump work by using a sensing resistor in series with the motor main winding.) While we're talking about detergents, that store bought stuff you're using is screwing up your dishwasher
* You Forgot to Remove the Disposal Drain Port Knockout Plug
# This usually only applies to the situation where you just installed a disposal and connected the dishwasher drain hose to the drain port on the disposal. Believe it or not, this happened to me on my first disposal installation job, too...no, not really. But I have seen many a grasshopper stumped by this.
# Drain Solenoid Not Opening
Some brands, notably GE/Hotpoint and Magic Chef, use a drain solenoid to open and close the dishwasher drain port. If this solenoid isn't opening during the drain cycle, could be a bad timer or solenoid.
# Worn Pump Impeller
Other dishwashers, like Whirlpool and KitchenAid, don't use a drain solenoid but instead reverse the motor to drain the basin. One possible reason for poor draining in this type of dishwasher is a worn pump impeller. You usually figure this by elimination...no, not that kind of elimination you dawg! I mean, if all the other suspects listed here check out OK, then you've got a worn pump impeller. The rebuilding kit for this repair is very inexpensive and is a great beer drinking project.
# Kinked or Plugged Drain Hose
Drain hoses can become kinked or crimped from poor installation, stuff being moved around, lots of reasons. It happens.This page on drain hose configuration shows you several approved drain hose layouts. Drain hoses can also get plugged from gookus. Plugs usually occur at the one of the drain ports--either on the dishwasher or at the other end. The best test is to take the drain hose off at the dishwasher and pucker up and blow like a fish. Yep, it can be pretty nasty putting your mouth on that stuff but, hey, that's why we appliance techs make the big money.
# Air Gap Plugged with Gookus
Plumbing codes may require an air gap in your dishwasher drain hose and many houses have 'em. These air gaps do a great job of keeping sewer water from backing up into your dishwasher but they can become a source of problems, too. Sometimes, they'll get plugged with gookus and they'll need to be cleaned out. If it's real bad or corroded, do yourself a favor and install a new air gap kit.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jul 10, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Our F & P dishdrawer keeps coming up with f1 and a picture of a spanner have tried turning the machine of at the switch for 24hr but is still doing it
Water has collected at the base of the dishwasher under the drawer.
This triggers a flood switch and causes the F1 error.
Turn the mains power off and extend the drawer out as much as possible. Take towels to dry the base from inside. Also use hair dryer ot dry out the flood switch mounted at the base.
Turn the power on and see if there is any difference. The cause of water collection could be many. Foam in detergent or kink in drain hose or drawer door gasket leaking etc.
May 11, 2010 | Fisher and Paykel DishDrawer DS605FDSM...
DISHDRAWER IS SSHOWING FAULT CODE F1. WHAT ARE THE
F1 means the flood switch has been activated. here is a trouble shooting flow chart.
1. did a flood occure? yes. q-2 or no q-12
2. is the lid sealing on the tub correctly? yes Q-3 no=Answer
3. Is there a high water level in the tub. Yes-q4 no q-6
4. is the water valve leaking? yes=Answer no-Q 5
5. Is the dish drawer priming correctly? yes q-11 no q-6
6. Is the spray arm split. yes=answer, no q-7
7. is the spray arm running freely. yes q-8 no q=answer
8. is the water leaking from a split inlet or drain hose? yes = answer, no q9
9. is the water leaking around the heater plate or o rings. yes=answer, no q10
10. carroy out more testing to locate the source of the leak.
11. drain hose may have been blocked or partially blocked.
12. is there water or condensation around the chassis flood switch pcb.
13. if power fails to the bottom tub, it will cause the top tub to f1
Jan 04, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
HI I HAVE A F2 CODE ON MY TOP DRAW OF MY DELONGHI DOUBLE DRAW
You will need.to remove the draws and dry the under tray as it has a flood.warning sensor to detect water, this is due to lime.building up.around the tub top.seal and will.need.cleaning off as it causes leaks to run down into the tray
May 12, 2009 | Fisher and Paykel 24 in. DD-602 Built-in...
Dishdrawer DD601 v2 Error F1 on the bottom draw.
Below is the link to the service manual
http://www.scribd.com/doc/6462163/DD601V2-Manual
This will be able to explain the problems better that I can in the tiny space I get to write in.
Mat
Please rate me
Mar 15, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
I'm Not sure of the model number, Fisher & Paykell double draw dishwasher
My dishwasher's doing exactly the same thing. What was the solution?
Apr 30, 2008 | Fisher DD603FCSS Dishwasher
Dishwashers Logo
220 people viewed this question
Top Dishwashers Experts
