Question about Casio Parts Cash Register PC Desktop
Casio 3700 is showing e11 and freezing any help ???
Can anyone help with casio CE-3700 showing E11 ??
  • Anonymous Dec 08, 2008
    still having the same problem,,,if i type the x or z reading it works,,but everything else you ring ,,it keeps noise ON,,bbeeeeeeeeeepppppppp.
  • 737 Answers
Hi. The machine has been set to disallow sales with the drawer open. Close the drawer and try again.
Mark
Posted on Dec 01, 2008
  • 45 Answers
Cut the brown wire in the drawer
Posted on Dec 07, 2008
M frigidaire washer model gltf2940fs1 shows me a e11 code
Thanks for your post, friend!
From my understanding your Frigidaire frontload washer, GLTF2940FS1, is displaying an "E11" error code. Typically, "E11" stands for fill time too long which means you could have an issue within your pressure sensor or control board. I would recommend a reset on your washer and that can be done by flipping the household circuit breaker off for ten minutes. If that does not help correct the issue you may want to consult with a technician for proper diagnosis. I hope this is helpful. -Matt
Oct 15, 2014 | Frigidaire GLTF2940ES Front Load Washer
MY CASIO CE-3700 CASH REGISTER SAYS E33 WHEN IT IS TURNED ON. How do I correct
Hi Josie. E33 means you have not entered amount tendered.
turn key to REG
Press SUBTOTAL
An amount should show on the display. Note this amount.
Type the amount shown on the display with no decimal e.g if display shows 12.30, type 1230.
Press CASH
Drawer should open.
If you cannot clear the error (try the clear button C) or no amount shows when you press SUBTOTAL, it probably means the memory has become corrupted due to a flat or faulty battery.
If anyone needs more information, C-tech collective have the Casio CE-3700 manuals here:
http://the-checkout-tech.com/manuals/cashregisters/Casio1.php
May 24, 2012 | Casio Parts Cash Register PC Desktop
Casio ce-3700 showing some percentages on it's reading.how take that out?
Which percentages? Which reading? You will need to be more specific. If it is part of the daily report, the user manual should be able to show you what they mean. If you need more information, the Casio CE-3700 manuals are here:
CE-3700 Operation/ programming manual:
http://the-checkout-tech.com/manuals/cashregisters/Casio_CE-3700_operators_and_programming_manual.html
CE-3700 Service (repair) manual: http://the-checkout-tech.com/manuals/cashregisters/Casio_CE-3700_and_CE-3750_service_manual.html
Sep 19, 2011 | Casio Parts Cash Register PC Desktop
Have a ce-3700 raized keyboard the till resets and can set date and time but the departments won't work one needs to open the department so that ne can work the till how
If you have performed a RAM (MAC) clear, then the departments should work as soon as the MAC code has been set. Make sure you aren't using a decimal point for prices. -----------------------------------------------------------
The Casio CE-3700 User and Programming manual is here: http://the-checkout-tech.com/manuals/cashregisters/Casio_CE-3700_operators_and_programming_manual.html
The Casio CE-3700 Service (repair) manual is here: http://the-checkout-tech.com/manuals/cashregisters/Casio_CE-3700_and_CE-3750_service_manual.html
Aug 30, 2011 | Casio Parts Cash Register PC Desktop
How do i programme/set new plu prices for a casio ce 3700
Are you sure you are using PLUs? The machine comes with departments on the keyboard as tsandard. If you are calling PLUs up by PLU number then you will need PLU programming. Otherwise, you need to set department prices. -----------------------------------------------------------------------
If anyone needs more information, the Casio CE-3700 manuals are here: http://the-checkout-tech.com/manuals/cashregisters/casio1.php
Jul 12, 2011 | Casio Parts Cash Register PC Desktop
I have a casio CE3700 cash register. The machine locked up. I followed the normal procedures to resolve this, however when I turned the power back on from the socket the machine fails to turn on at all...
It sounds like there is a good reason for it locking up the first time then. Most commonly it is caused by a printer problem. Most Casio models will run the printer before they turn the display on, so if you can't hear the printer run at turn on, I'd start there. Look for paper jams. make sure the motor can turn freely. If the motor is okay, check the battery. You can experience weird problems if the battery has not been replaced on time. ------------------------------------------------------------------------------------
If anyone needs more information, the manuals are here:
Casio CE-3700 Service (repair) manual: http://the-checkout-tech.com/manuals/TOC/cashregisters/Casio/CE-3700%20and%20CE-3750%20service.TOC.pdf
Casio CE-3700 User and programming manual: http://the-checkout-tech.com/manuals/TOC/cashregisters/Casio/CE-3700%20operators%20and%20programming.TOC.pdf
Jun 10, 2011 | Casio Parts Cash Register PC Desktop
My casie ce-3700 is showing error code 08, how can i resolve this problem?
You have logged yourself off. Try pressing 1 then CLK#
If anyone needs a Casio CE-3700 manual, C-tech has them here: http://the-checkout-tech.com/manuals/cashregisters/casio1.php
Dec 14, 2010 | Casio Parts Cash Register PC Desktop
I have acquired a casio CE 3700 without a manual and need to change the company name that is printing on the receipts - please help
A very rare but great machine. You need to pull the stamp out from the back of the receipt side of the printer (there is a small black handle that you pull just under the paper entry). Then take the stamp to a stamp maker to get your name, tax number etc cut into a new stamp.
If anyone is looking for a Casio CE-3700 manual, there is a user and programming manual here: http://the-checkout-tech.com/manuals/cashregisters/Casio_CE-3700_operators_and_programming_manual.html
Oct 11, 2010 | Casio Parts Cash Register PC Desktop
Its a casio ce 6100 cash register ad the memory seems to have gone, now when i press the clerk key E011 appears on the screen
You have to close the cash drawer to make a sale. E11 means drawer open while sale in progress. If that doesn't fix it, check the wiring to the drawer, especially the brown wire. -------------------------------------------------------------------------------------------------------
For anyone needing a Casio CE-6100 manual, go here: http://the-checkout-tech.com/manuals/cashregisters/Casio1.php
Jun 04, 2010 | Casio Parts Cash Register PC Desktop
Casio Parts Cash Register PC Desktop Logo
226 people viewed this question
Top Casio Retail Supplies Experts
Electroboy
Electroboy
jackcity
jackcity
Level 1 Expert
Are you a Casio Retail Supply Expert? Answer questions, earn points and help others
