Question about Price Pfister Marielle Kitchen Faucet with Matching Spray and Soap ...
Handle on faucet shuts off on its own
I have a Price Pfister Marielle kitchen faucet which shuts off by itself. If the lever is not pulled up at least half way, it will come back down on its own. It does it on both hot and cold sides. what is the problem?
  • zulu7618 Jan 31, 2009
    Same here. It shuts off automatically when we try to adjust to half of a stream or less. I pulled the handle off and looked for an adjustment screw. There is not one.
    It appears to be a design flaw. The weight of the handle is heavy enough to shut it off if it is not in the full upright position. Any ideas.
I had the same problem. The Price Pfister web site recommends removing the handle (unscrew the dome cap, then remove the phillips screw to get the handle off) then tightening the retaining ring (I used channel lock pliers on largest setting. It worked. However the retaining ring is plastic on some models, and they recommend replacing it with a brass one. I haven't taken that step yet, we'll see how it goes (mine is plastic).
Posted on Feb 20, 2009
  • Buster Irby
    Buster Irby Feb 25, 2018
    5 minute fix, did exactly as bodorj and it fixed my problem. Water can now be set to drizzle. I have a plastic retaining screw and I just tightened it with channel lock pliers set to wide. Pfister makes a retaining screw tool bot I did not need it.
  • 101 Answers
Diverter is not tight. Turn off water. Take out set screw holds down handle . Pull off handle, tighten down diverter screw. If the faucet is older it should have new washers installed too.
Posted on Dec 14, 2008
2 Suggested Answers
SOURCE: I have a price Pfister Marielle kitchen faucet.
There is an o-ring around the valve body inside the outer shell. This needs replacing -- sometimes you can match these at hardware stores.
Shut water off, remove handle, pull up outer shell, you'll see the o-ring.
More info, let me know.
Charlie
Posted on Aug 28, 2009
Testimonial: "Thank you...problem solved :-) No more leaks. "
How to disconnect the quick connect spray hose in a Price Pfister Parisa
I also needed to remove the "hidden" flow restricters from my Price Pfister Parisa Kitchen Pull out faucet. The hot water side had never flowed the same as the cold side. Now both sides are flowing the same as should have been all along.
Nov 30, 2012 | Price Pfister Marielle Kitchen Faucet with...
I need a replacement handle, including all the parts and hoses, on my Price Pfister Marielle kitchen faucet model # T26-4NEE
Most new kitchen faucets feature single-handle control levers and washerless designs that rarely require maintenance. Additional features include brushed metallic finishes, detachable spray nozzles, or even push-button controls.Connect the faucet to hot and cold water lines with easy-to-install flexible supply tubes made-from vinyl or braided steel. If your faucet has a separate sprayer, install the sprayer first. Pull the sprayer hose through the sink opening and attach to the faucet body before installing the faucet.
Where local codes allow, use plastic tubes for drain hookups. A wide selection of extensions and angle fittings lets you easily plumb any sink configuration. Manufacturers offer kits that contain all the fittings needed for attaching a food disposer or dishwasher to the sink drain system.
Jul 26, 2012 | Price Pfister Marielle Kitchen Rustic...
Avalon cartridge faucet handle sticking
I would try replacing the cartridge. Handle has a set screw (probably an allen head) There should be a retaining nut holding the cartridge in. Unscrew it and pull the old cartridge out. You might have to pull pretty hard.
Jul 27, 2011 | Price Pfister Marielle Kitchen Faucet with...
Looking for a price pfister marielle faucet installation instrucction. Model number026-4nzz
Call price Pfister at: 1-800-PFaucet
They have excellent customer service and can point you in the right direction.
Sep 30, 2010 | Price Pfister Marielle Kitchen Faucet with...
The top fell off the faucet, doesn't this faucet have a life time warrenty
Price Pfister Marielle Kitchen Faucets Do come with a limited lifetime warranty from Price Pfister-to the original home owner. You can contact Price Pfister on line at www.pricepfister.com, call them toll free at 1-800-PFAUCET or Email. The faucets warranty can be downloaded at http://www.pricepfister.com/support/warranty.aspx.
Sep 28, 2010 | Price Pfister Marielle Kitchen Faucet with...
Replacement Price Pfister sprayer/hose
I called Price-Pfister and they sent out the parts free under their warranty, plus a few dollars for postage.
Apr 10, 2010 | Price Pfister Marielle Kitchen Faucet with...
I have a price Pfister Marielle kitchen faucet. The valve body leaks when handle is in off position.
Charlie
Aug 28, 2009 | Price Pfister Marielle Kitchen Faucet with...
KITCHEN FAUCET (single handle PRICE Phister ) suddenly quit flow
Take it apart and clean out calcium lime or rust build-up. Also check to be sure your shut-offs are clear and running well
Jan 09, 2009 | Price Pfister Marielle Kitchen Faucet with...
Price Pfister Marielle Kitchen Faucet with Matching Spray and Soap ... Logo
3,730 people viewed this question
Top Price Pfister Plumbing Experts
Marvin
Marvin
john h
Mike
Are you a Price Pfister Plumbing Expert? Answer questions, earn points and help others
