Everything else works with the fob except the passenger door not even trying
The problem is not key fob but the lock actuators in door. Does the door open when you try the lock on the door? If not then you have a bad lock actuators
Get remote checked wires might need re soldering or replace remote with new one. Cheapest place to purchase one is at a key cutting place or lock retailer.
is it still doing it,does it happen more when wet or dry if its wet then its a falt with the earth wire,if its dry then 2 ways to fix ,if your handy 1 is to remove and reflow with flux and the other is to replace you can get cheep at car yard cheep reflowing is easy you just need to keep the heat moving on the new fl.
