Question about HP Office Equipment & Supplies
For the HP printer, i uses the disk to download all the updates for the printer and it said it cannot continue using Run As as a command, and said to log of and return on a computer profile with administrator privileges -its a HP Deskjet F300 series
Try deleting the program from control panel>add/remove programs then reinstall it then go on HP's website and update it online.
Posted on Dec 01, 2008
I installed recently HP officejet Pro L7480, but hP solution center failed to detect any device and closed. the officejet also failed to scan - error message: No scan option
Hi There, This is a known issue with this device. Please follow the below steps to fix this issue : Try to do a complete uninstall
*first step*
-run installation media (CD / Download) software
-select uninstall and on the process, select uninstall all hp softwares associated the with the device
-after uninstall , select restart later to reboot the computer later
-go to start > control panel > add/remove programs (XP) programs (Vista)
-uninstall any existing HP softwares (note: for hp computers, skip this process)
-restart later
*2nd step*
-open contents of the installation media
-if you're using the installation CD. go to my computer, select the drive which has your cd in (eg. E:/ , D:/ ) right click on the icon and select open / explore.
-if you're using a downloaded software, click on start and click on run (XP) startsearch (vista), on that box, type in the command ( %temp% ) and press enter. it will open up temporary files folder.
-locate the file that starts with 7z (eg. 7z001cs1) and open it and now you are in the contents of the installer
-on the contents of the installer, locate UTIL folder and open it then locate CCC and open it as well
(note: check your operating system if it is running on a 32-bit or 64-bit . you can check it going to start>control panel>system)
-on CCC folder , locate uninstall L1 (for 32-bit) uninstall L1 64 (for 64 bit) and run it. (note: there will be a command prompt box that will launch, press enter to continue) restart later
-on CCC folder , locate uninstall L2 (for 32-bit) uninstall L2 64 (for 64 bit) and run it. (note: there will be a command prompt box that will launch, press enter to continue) restart later
on CCC folder , locate uninstall L3 (for 32-bit) uninstall L3 64 (for 64 bit) and run it. (note: there will be a command prompt box that will launch, press enter to continue) restart later (repeat uninstall L3 steps for 3 times)
**********important**********
(do not run uninstall L4)
contiunued in the next post ..............................
Nov 14, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
Recently downloaded an driver update, printer stopped printing. using windows XP PRO OS. Lost the original disk software for the printer
You may have downloaded the incorrect driver. I would try using the driver directly from the manf. website. You can find the download here: DOWNLOAD
May 05, 2009 | HP PhotoSmart 7760 InkJet Printer
Error8007000b
Here's a fix for Windows Vista Update Error 8007000b and it works (I tried it)
1. Open an Administrator command prompt by right clicking on Start -> All
Programs -> Accessories -> Command Prompt and selecting "Run as
Administrator" and clicking "Allow" for the elevation prompt
(or use run->cmd)
2. In the command prompt, type the command below
cd\
3. Then type fsutil resource setautoreset true c:(If your vista installation is in C: drive)
4. It should say it was done successfully
5. Reboot your system
Jan 16, 2009 | HP Photosmart C6180 All-In-One InkJet...
Cant conect hp psc 1315v printer to Vista computer
Hi m_andrews2, try this method. Do not use your CD that came with the printer. Go to this HP link;
http://welcome.hp.com/country/us/en/welcome.html#Support
Make sure the HP PSC 1315 printer is connected to the PC & powered on. In step 1, click your mouse in the empty circle next to
"Download drivers and software (and firmware)". Than in step two click the button, "Start Detection". Allow HP to scan your system. HP will find your printer & start downloading the proper software & install it. Watch your screen you will have to give permission to HP. You shouldn't get an error message.
Good luck m_andrews2!
If for any reason you do just let me know.
Mike
Jan 01, 2009 | HP PSC 1315 All-In-One InkJet Printer
Error 2738 when attempting to install HP F4180 printer software
Hi Stargateforg,
Try the solution from HP.
Solution one: Restart the computer
  1. Turn off the product.
  2. Restart the computer.
  3. Turn on the product.
  4. Use the HP software CD or the downloaded software file to install the HP Software.
Solution two: Register VBSCRIPT.DLL
  1. Search for the VBSCRIPT.DLL file on the computer. It is usually located in the C:\Windows\System32 folder.
  2. Click the Start icon (c01319360.gif ) , click All Programs , and then click Accessories .
  3. Right-click Command Prompt , then click Run as Administrator .
  4. In the command prompt, type CD C:\WINDOWS\SYSTEM32 . If the VBSCRIPT.DLL file is located in a different folder, use the appropriate folder location.
  5. Press the Enter key.
  6. Click Continue in the window that appears on the computer.
  7. Type REGSVR32 VBSCRIPT.DLL in the command prompt and press Enter . A message appears on the computer indicating that VBSCRIPT has been installed successfully.
  8. Use the HP software CD or the downloaded software file to install the HP Software.
Solution three: Download and install the latest version of the software
  1. Click here to go to the software download page on the HP Web site.
  2. Type the product model name in the text box and click the gray arrow button.
  3. Select the appropriate product model from the list that appears on the computer, then select the appropriate operating system from the list that appears on the computer.
  4. Under the Drivers section, click Full Feature Software and Drivers .
  5. Follow the on-screen instructions to download and install the HP software.
Solution four: Custom Install Use Custom Install to install the basic print drivers only.
  1. Use the HP software CD or the downloaded software file to start installing the HP Software.
  2. When prompted, click Custom Install .
  3. Clear all the entries in the list of software to install except Photosmart Officejet and Deskjet Drivers and Imaging Device Functions . Click Next to continue.
  4. Follow the on-screen instructions to install the basic print drivers.
Dec 22, 2008 | HP Office Equipment & Supplies
I have an HP Photosmart C4250 All in One printer. I was offered a printer up date on line, so I said yes to the up date, and when it finished I received a window that said the up date could not be...
HP also provides tools on HP's Web site that make downloading drivers much easier. HP's browser tools work by integrating with the Internet browser and running scripts to collect important information needed to perform the task. One example of an HP browser tool is the HP Printer Check. HP Printer Check quickly scans your computer for any printers that may be attached and provides links to any drivers or driver update that an attached printer may need. Internet Explorer might block scripts like these and flash the information bar at the top of the viewing window. The information bar displays more information about the item that has been blocked so that you can decide if you want to allow the script to continue. In order to use many of the tools that are available from the HP Web site, you must allow the items that Internet Explorer blocks to install or run. Run or install the items that Internet Explorer blocks by clicking the shield on the left side of the information bar. For more detailed information, use the following step-by-step example to learn how to use the HP Printer Check utility with these security features:
  1. Click an HP software download tool link to install the tool. For this example the link occurs at the top of many Deskjet printer driver download pages and appears as: Click here to have HP automatically check to see if you need a driver update.
  2. Once clicked, an informative window opens telling you more about the tool. To continue, click the Check Now button.
  3. To install the HP software tool, you must click the upper left corner of the information bar (by the shield) and authorize the first item in list. In this example, select Install ActiveX Control (see Figure 5). You can feel safe installing the ActiveX control because you know that it comes from the Hewlett-Packard Web site. CAUTION: Before installing ActiveX controls or authorizing scripts, read the text in the information bar and think about the Web site where the script is coming from. Do not continue if you do not know. Continuing could make your computer more susceptible to viruses or spyware.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 22, 2008 | HP Office Equipment & Supplies
D-Link DP-301U Print Server
try to do a normal install first. once that works you'll be able to use the driver that is installed to install via the print server.
Jul 30, 2008 | D-Link DP-301U (790069251979) Print Server
Printing problem
Hi ,
if u face this problem continuously please check u r printer with new print cartridges if the problem get same please use blew link for u r printer firmware to update it
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=441125&lc=en&cc=us&dlc=en&lang=en&cc=us&y=3&x=3
if u install all printer drivers then select u r OS in above link
after Os selection u get all utilities for printer .go in update ---->& select "Critical update to correct diagnostic performance"
Download this patch & install this patch when u r printer in online
It should be working .....
If this information is useful for u please Rate me........
Jun 05, 2008 | HP Officejet 5610 All-In-One InkJet...
23 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
