Question about HP OfficeJet 6110 All-In-One InkJet Printer
Hp 6110 won't receive faxon single line phone with dsl
I have hp officejet 6110 all in one printer my printer is working but not ricevie fax
Posted on Jul 04, 2011
  • 628 Answers
Have you tried to use the machine on a normal phone line? A dsl line shouldn't be any different as far as fax machines are concerned.
Posted on Dec 01, 2008
I have a hp officejet all-in-one and I can't get the fax function to work. I have comcast digital voice with a rca modem. The fax machine dials and the line goes dead. If I call the fax number on the...
Since you have a DSL ( Digital Subscribers Line ), the HP Fax printer works on Analogue Signals.
To make the GP Printer work on Digital line, First step you can do is to Reduce the Fax Speed from Fast/Medium to SLOW.
To Do so, Click on Setup button on printer front panel - Choose Fax Settings - Choose Fax Speed - Set it to Slow and try to fax
If this does not work, you will have to connect a DSL Filter ( this is a 2 way port - 1 port for Digital line and another for Analogue )
You will have to connect this Filter to DSL Phone line - in the IN port and from the Analugoue Port - Connect Phone cable to Printer Line 1 EXTN Port at back of Printer
Jul 02, 2010 | HP OfficeJet 6110 All-In-One InkJet...
How do i find out the phone number for my dsl line so people can fax to me
Are you using Single line with 2 seperate no. for Telephone and Fax ? If so, You can contact the Telephone provider to check the Dedicated No. for Fax ( Usually Called as DRP [ Distinctive Ring Pattern ] or special no. on the same line )
There is a way to set this up on your printer. you have to set the DRP on printer under Fax Settings DRP.
Jun 23, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Fax set up -I've used this model for years and now
do you have dsl filters installed? the fax should go to unfiltered line not the filtered dsl line.
Jul 17, 2009 | HP OfficeJet 6110 All-In-One InkJet...
My hp officejet v40xi says off hook when I try to send a fax. I hear not dial tone. can you help me I am using sbcglobal service
It will say 'off the hook' if the line is in use. There should be dial tone on the line before you can fax something.
Mar 06, 2009 | HP Office Equipment & Supplies
Set up fax and dsl using one phone line
You can buy a splitter to put on your line so you can run both devices. They sell them at the dollar tree big lots and everywhere else usually, and range from .59 to $2. as far as another DSL filter ask a friend neighbor or co-worker if they have or had dsl and have an extra filter. If not then you can pick them up for a couple of bucks at radio shack
Feb 18, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Cant receive a fax
Your voice mail is probably answering before the fax can grab the line. Try setting the number of "rings to answer" on the fax to 1 or 2 rings less. The best solution if you only have one phone line is to buy a device called a "comswitch". I use one. They automatically detect if the incoming call is a fax and switch the call to the fax machine. If its not a fax it switches the call to the proper device. They are not that expense. Look on e-bay.
Larry
Dec 01, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Faxing with a digital phone line
I looked up fax problems at HP.com and my guess, based on what I read, is that the 6110 is able to detect the broadband data connection at the higher line frequencies, even though all you hear on the line is a normal dial tone. If you haven't done so already, you'll need to install a line filter on one of your phone jacks (this should have come in the kit with the rest of the hardware you were sent to set up the DSL line). This isn't an issue with the 6110, but a natural "consequence" of using DSL.
Here's the web page I used as the basic for this opinion:
Phone "Off the Hook" Status
On that page scroll down to the "Checking the phone line" section and read the material there. See if that info helps. Good luck.
Nov 04, 2008 | HP OfficeJet 6110 All-In-One InkJet...
FAx Line will not pick up or send faxes on HP 6110 All in One Officejet
it seems like you have lots of services on your line. here are the things that i want you to follow to somehow resolve the issue.
1. Press the setup button on your printer, then use the arrow down button to scroll down and go to ADVANCE FAX SETUP.
2. Press okay on Advance fax setup, then it will give you options.
3. The first option is DISTINCTIVE RINGS, press okay on that.
4. It will give you first option "DISTINCTIVE RING", scroll down and look for "answer on double rings" then press okay. then try letting someone send you a fax.
Note: make sure that your answering machine is using your home telephone line so that it wont affect the faxing functionality.
1. if the issue still not resolve, try to press setup, then go to TOOLS.
2. press okay on TOOLS and it will give you options, scroll down using the arrow down button and look for RUN FAX TEST.
3. Check the result of the test if everything passed!
Let me know if the issue still not resolve so that i can go ahead and give you additional steps.
thank you so much.
adonscott
May 30, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Will not auto detect incoming faxes
Review the information below to determine why faxes cannot be sent or received. Review the symptoms below carefully and then select the symptom that best fits your problem. If the solution links you to a different document that does not resolve the problem, return to this document to continue troubleshooting. The fax machine doesn't receive or send a fax and prints an error report (bpu02549). Faxes cannot be received but they can be sent . Faxes cannot be sent but they can be received . Faxes fail intermittently or with only one fax number . Faxes cannot be sent or received or you're not sure of the problem . Faxes cannot be received but they can be sent Review the information below to determine why faxes are not being received. Phone company services: Do you have any of the following telephone line services from your telephone company: Voice Mail, Privacy Block, Security Screen, Anonymous Call Rejection, and Privacy Manager. These phone services are meant to prevent unwanted calls, but they will also stop faxes. Contact your telephone company for their recommended solution for receiving faxes on the same line with these services. If you wish to receive faxes automatically, verify that automatic answering is enabled on models that have an Auto Answer button, or that the Rings to Answer setting is set to a number equal to or larger than one for models that do not have an Auto Answer button. On models with an Answer Mode setting, it should be set to Fax, FaxTel, or AnswerMachine depending on your setup. If you have a HP PSC 2200 or an Officejet 6100 that interrupts calls or will not receive faxes, download and install the HP Firmware update for these products. Visit the HP Support and Drivers Home page . Select Download drivers and software. Type in your model number (HP PSC 2210xi for example). Click the search arrow to the right of the text entry box. You may be asked to select your product from a list of models. On the software download page, select your Windows version. Locate and select the firmware update. Follow the directions to download and install the update. If an answering machine is connected to the same line, fax reception problems can occur. These problems may be corrected by changing settings or phone line connections. For more information on using a TAM or distinctive ring service, go to Using the HP All-in-One and Fax Products with a Telephone Answering Machine (bpu04072). If you have a PBX phone system, or an ISDN or DSL modem connected to the line, there may be some phone line configuration problems. Fax machines are analog devices and cannot be used on a digital phone service such as those used in many businesses (PBX systems). Install an analog phone line for a fax machine. Refer to document Using an HP All-in-One or Fax Product on a PBX, ISDN, or DSL Phone System (bpu50333) to learn how to correct these problems.
Aug 02, 2006 | HP OfficeJet 6110 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
180 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
