Question about Whirlpool GEW9250 Electric Dryer
Control lock button is locked on my whirlpool dryer
Our whirlpool dryer wont work cause the control lock button is on and we need help solving our problem
  • dayanta Jan 15, 2009
    The light on my Duet front loader gas dryer says control is locked,I have unplug it and even held button in for 3 seconds nothing is working! Please Help
    Problem Solver:
  • 3 Answers
For me it was the far right button but it reads, "end of cycle signal"
good luck,
Posted on Jan 20, 2009
  • Whirlpool Master
  • 2,651 Answers
Look to the far right of the control panel there is a button marked " control lock hold for 3 secs", i believe its the far right bottom button.
Posted on Dec 01, 2008
The control lock button is light up and the washer won't work.
There is a button on the control panel with a marking under it that says "Press and hold for 3 seconds to lock/unlock control". Look for the said button then press and hold it for 3 seconds or until the control lock light turns off. The button is usually the Auto Dry Level button for Kenmore Elite dryers and the Drain/Spin button for Kenmore Elite Washer. Whirlpool Duet Washers and Dryers use the End of Cycle Button to lock and unlock the control.
Sometimes the problem is due to electronic glitch and unplugging the machine for at least 30 minutes may solve the problem. But if the control cannot be unlocked by pressing and holding the button specified above or by unplugging the machine, the control panel electronics may need to be replaced.
Dec 23, 2010 | Whirlpool Washing Machines
The front light lit on my Whirlpool dryer is showing control locked
If the front light lit is control locked, that means that your Whirlpool electric dryer had been set in control lock mode.
Control lock is a special mode that will prevent user from changing settings or using control until the dryer gets unlocked again.
The machine is set to control lock mode by holding down the CONTROL LOCK/UNLOCK button for several seconds. In the same way you can stop the control lock mode when the machine is already set to Control Lock.
When the dryer is running and Control Locked is on, the dryer can still be stopped by pressing the Pause/Cancel button, but cannot be restarted until the control is unlocked.
If the front light lit is control locked but the dryer door opens and it does not turn off, then you are probably in this situation. In that case, the door will be opening , but the machine still stays locked.
Disconnecting the machine from power, either unplugging power cord or tripping circuit breaker, won't help. The control lock system is designed to stay on in case of power failure.
If the machine is control locked, try unlocking it with the following procedure.
To unlock: Press and hold the CONTROL LOCK/UNLOCK button for 3 to 5 seconds to turn the control lock feature off.
If that does not work, try disconnecting power for five minutes to reset the machine, and eventually do unlock again. As said, cutting power alone will not cause the machine to unlock.
If the machine is still not responding, the lights stay on all the time, the dryer panel does not respond to control unlock procedure, and the door does not lock anymore, then it may be a defective control board.
If you are in this situation, before replacing the control board more parts, including the door lock must be tested. In that case the best option may be contacting the Whirlpool support number listed on the Dryer use and care manual, usually in the last pages.
In this case try resetting control lock as explained above, as told the dryer is more likely control locked and then stopped.
on Feb 01, 2010 | Whirlpool GEW9250 Electric Dryer
The control locked light is on and the dryer will not work
The lock is turned on/off by pressing and holding the end of cycle signal for 4 seconds. It is there so you can clean the unit with out activating the buttons or so children wont turn the unit on while playing.
Apr 23, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Control lock light won't go off and dryer wont work. What do i do?
The Control Lock is a designed safety feature that enables the us to lock the control panel to prevent small children from manipulating the controls and accidentally starting the appliance.
The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds to 10 seconds.
Please do refer this link for a detailed explanation for your knowledge.
Apr 07, 2010 | Whirlpool GEW9250 Electric Dryer
Help! I have a whirlpool frt load dryer it is locked (controls)
You need to press and hold the "End of Cycle Signal" button on this model to lock or unlock the control panel. The instructions should be printed directly below the button.
Jun 30, 2009 | Whirlpool GEW9250 Electric Dryer
Control lock
bottom button on last row on right side of control panel depress and hold for 3 seconds it should activate or deactivate control lock if this does not help you could have a faulty control panel
Dec 14, 2008 | Whirlpool GEW9250 Electric Dryer
Control locked light on dryer wont work.
ck buttons for small lock emblem think end of cycle signal ..hold down 3-5 secs
Nov 20, 2008 | Whirlpool Duet 3.8 cu. ft. Front Load...
Whirlpool YGEW9250PW1 Electric dryer control locked problem
I had the same problem, but my husband, who is an engineer, figured out that if you pull out the light bulbs that are not reading the correct volts on his volt meter, the control lock light will shut off and the dryer will start working. If you do not know how to do this, you can always buy a new control panel. I know this sounds to simple to be true, but we have bought several new "brains" (control boards), tried unpluging the dryer for days at a time, had an certified whirpool technician come out (who recommended buying a new control board), and nothing worked.
Sep 01, 2008 | Whirlpool GEW9250 Electric Dryer
Control locked on ghw920 can u help me unlock
Press and hold the End of Cycle Signal button for three seconds. This will turn off the Control Lock feature.
Jul 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet control locked
Whirlpool GHW946PLO locked controls light is on and will not respond. Have tried to unplug to reset default codes.
Jul 09, 2008 | Dryers
Whirlpool GEW9250 Electric Dryer Logo
96 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
