Question about Toshiba Satellite A205-S4617 Notebook
L355-S7812 missing wireless adapter driver
I have a L355-S7812. At one point the computer went into hibernation mode and when I turned it back on again an error message of not being able to locate the wireless internet adapter occurred. I can not longer view any wireless connections. when i try to troubleshoot the problem it tells me that I do not have a wireless driver installed when it is built into the computer. The only disk the computer came with is the recovery disk. How do I get my wireless working again?
    Problem Solver:
  • 10 Answers
Http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=1998632&rpn=PSLD0U&modelFilter=L355-S7812&selCategory=3&selFamily=1073768663&selModel=1998632|PSLD0U here is your link i assume you can download you will need two files
security utility wifi and bluetooth lan utility wifi they are to be downloaded.open file and run the software
it will reload your wifi. kawuna
Posted on Dec 01, 2008
Toshiba Satellite L355-S7812 keeps restarting with AC Adapter plugged in
Your OS has a corrupt element in it that makes unit shut down every once in a while. Try repairing the OS. Or try a system restore. If nothing works and it still bugs you reload the unit.
Sep 06, 2017 | Computers & Internet
Toshiba satellite L355-S7812 keeps restarting when AC Adapter is plugged in
Hi Craig,
The car adapter may be the culprit.
If it's not the adapter recommended by Toshiba, than You are heading the quick way to pickling your Laptop.
Always use the brand recommended for you PC/Laptop.
Cheers,
Peter
Feb 18, 2013 | Lifetime Toshiba Satellite L355-S7812...
Toshiba satellite L355-S7812 keeps crashing
You might have some viruses and malware.
Start your PC and press F8 several times until the boot menu comes up. Then select "Safe Mode with Networking". Now get some or ALL of the FREE programs below...
Download, Install and Run Malwarebytes Anti-Malware:
http://majorgeeks.com/download.php?det=5756
When Installing choose the non-pro version.
Download, Unzip, Install and Run TDSSKiller:
http://majorgeeks.com/Kaspersky_TDSSKiller_d6895.html
Download, Install and Run Super Anti-Spyware:
http://majorgeeks.com/SUPERAntiSpyware_d5116.html
If you have an outdated Anti-virus program then Download, Install and Run Avira Anti-Virus:
http://majorgeeks.com/Avira_AntiVir_Personal_-_FREE_Antivirus_d955.html
Make sure to select ALL of the "threat categories" when you install or configure Avira...
You should be in pretty good shape if you run and install all of these programs.
Jun 30, 2012 | Toshiba Satellite L355-s7812 C2d...
One bad lead or faulty connection point can cause a computer to shutdown continue restarting on a cycle or fail to detect your hard drive boot up
test all leads that attach to your hard drive including electrical extensions SATA
the leads from your (motherboard to your hard drive) make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty
even something as small as an electrical extension or a faulty fan lead can cause you problems computer needs all of the data and power to travel through every working device and to have an end for a computer to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive check all electrical extensions make sure they are securely seated even the cd/dvd drives need to have current go through make sure these devices are working
check the CPU make sure it has thermal paste and dust free secure seating
also check your computer ram modules and cmos battery make sure it has charge and they are dust free and securely seated some motherboards cmos batteries are soldered in
hope it helps
Jun 30, 2012 | Lifetime Toshiba Satellite L355-S7812...
I have a Toshiba L355-S7812 laptop. I've recently replaced the hard drive and re-installed the OS. The driver for this CD/DVD drive won't install. The Device Manager indicates the driver is missing or...
HI
Have you uninstalled it in device manager if not uninstall it restart the laptop and hopefully windows will install it correctly when it re-installs it and if it dosent
follow this link and type in your make model and os hopefully you will find the driver
good luck
Nov 18, 2010 | Computers & Internet
Hi my computor just recently went into hibernation mode and it won't turn to my original screen.I'll tell you what happend.It went to a black screen last night and i don't know if it crashed or not because...
when your computer boots up press F8 after the boot screen, its easy to miss the short period you can press this. This should prompt a screen which allows you to choose how to boot windows. Booting windows normally (without restoring hibernation state) or in your last good configuration that worked (it saves restore points pretty much every day your on it and will revert to that restore point) will be your best bets. Hope this helps, let me know if it gets tricky.
Apr 28, 2010 | Compaq Presario R3000Z Notebook
I have a gateway laptop, not sure what model. it
My computer does this too. Turn off hibernation mode, then restart computer.
Go to start menu
control panel
maintenance/performance or display
go to screen saver
advanced options
power
turn off hibernation mode and apply settings, restart pc
Aug 17, 2009 | Computers & Internet
The SM Bus controller is the Intel Chipset Utility
http://www.csd.toshiba.com/cgi-bin/tais/su/su_sc_dtlViewDL.jsp?soid=1871244&moid=1998632&rpn=PSLD0U&BV_SessionID=@@@@1676394158.1218026637@@@@&BV_EngineID=ccchadeelddefdicgfkceghdgngdgmn.0&ct=DL&all_docs=false
Once that is installed, the NIC might install to. I see no discrete download for the Network Driver
Aug 06, 2008 | Computers & Internet
XP DRIVERS for Toshiba L355-S7812
here are the XP drivers I have found for that model system:
http://www.csd.toshiba.com/cgi-bin/tais/su/su_sc_modItemList.jsp?BV_SessionID=%40%40%40%401773750978.1210856642%40%40%40%40&BV_EngineID=ccceadeedkhgjelcgfkceghdgngdgmn.0&ModelDLOS=Windows+XP%7C132594&ModelDLCat=null&BV_SessionID=%40%40%40%401773750978.1210856642%40%40%40%40&BV_EngineID=ccceadeedkhgjelcgfkceghdgngdgmn.0&ListType=Model&ct=DL&moid=1998632&rpn=PSLD0U&OrderBy=D&PublicStartIndex=25&PrivateStartIndex=0&PublicCutOff=&PrivateCutOff=&AddOldPublicItems=false&AddOldPrivateItems=undefined&all_docs=false&x=39&y=12
If you cannot find a specific driver, then post the driver you need and I'll see if I can find it.
May 15, 2008 | Computers & Internet
Toshiba Satellite A205-S4617 Notebook Logo
512 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
