Question about Whirlpool Dryers
Heat wont stay on
When you first turn it on it heats up. But when it tries to maintain the temp, the glow plug glows but the propane does not get released. also, how do you get to the burner?
    Genius:
  • 1,028 Answers
Remove front to get to burner remove screws under lint screen on top press clips each corner of top remove tne screws each corner inside top front panel.if lint screen in door frame press clips each corner bottom panel ..replace the 2 black coils on burner
Posted on Dec 01, 2008
Glow plug light stays on, engine turns over but won't start
glow plugs dont last for ever
have them visually inspected
they need to heat up to spec or motor wont start
what motor or vehicle ?
May 31, 2016 | Cars & Trucks
2.7tdi newish heat plugs,glow light stays on ,smokes on cranking ,won't start
the glow plug circuit may be faulty, check glow relay and timer function, or connection to glow plugs, the glow plugs may also be faulty, if all is well with them, then you may want to check the fuel injection pump it may have a worn hydraulic head. To start you can try some quick start fluid but disconnect the glow plugs first,
Feb 04, 2015 | 2005 Nissan Terrano 2.7
Glow plug light wont go out
Your diesel vehicle is equipped with glow plugs, and also with a Glow Plug Light that will either come on and stay on, or flash or blink when a fault is detected by the ECU (engine management unit). When the Glow Plug Light comes on, the ECU stores information about the condition that has caused it to come on.4 Jan 2016
Is It Safe to Drive With the Glow Plug Light On? ' YourMechanic Advice
https://www.yourmechanic.com/article/is-it-safe-to-drive-with-the-glow-plug-light-on Glow plug light wont go out Google Search
Oct 25, 2017 | Ford F-250 Cars & Trucks
Glowplug light comes on and goes off quikly, engine hard to start. Changed all 4 glow plugs and coolant sensor. Light stays on for a good 10 seconds when water temp. sensor is unpluged.
The glow plugs work in direct relation to the engine block temp. The relay for the glow plugs is obviously reading the wrong temp, that's why they turn back off. It's most likely that the temp sensor is bad, but trace the wires back and make sure there are no breaks in the insulation and they are well connected at the plug-ins. I have seen a lot of wires at the connector look good but fall off as soon as you touch them.
If the temp sensor is the same on for your your dash, then borrow a heat sensing gun and double check it against the guage. I have seen them read wrong by as much as up to 20 degrees. If the sensor reads rught and feeds both the guage and the glow plugs, then the problem would be either the wire harness or the glow plug relay. Hope this helps.
Oct 26, 2011 | 2003 Volkswagen Jetta TDI
Wont start battery low was changed
it sounds more like bad glow plugs. these heat the air in the cylinders to aide in cold starts and are controled by a temp sencing unit. with a volt meter or if your car is equiped with a gauge turn the ignition on. there should be a very noticable drop in your voltage. if not your glow plugs are probibly bad.
Jan 09, 2010 | 2004 Audi A6
Car wont start diesel engine Could it be the 'glow plug'? what is a glow plug? how can i test?
A glow plug is a small heating element in the cylinder. It heats the diesel so that starting can be made easy. Is your car standing in the open frozen parking If yes, then it would require a lot of battery power to first heat all the cylinders and then turn the engine to start. What we do in such conditions is to light up some fire under the car and heat the fuel system enough for the diesel to warm up a little and thus save the battery for glow plugs. Generally, all vehicles have an indicator light which comes on when the glow plugs are ready for starting. The diesel will ignite on compression, but it has to reach the cylinder and thus has to be flowing. In cold it freezes and hence the need for glow plugs and the heat. If it is parked in heated parking then the need for glow plugs decreases.
Jan 01, 2010 | 1991 Peugeot 405
How do I utilize the self cleaning part? Do I just press ''clean
  1. After self cleaning the range the door won't open
  2. Amana gas range conversion from NG to propane
  3. A tip on cleaning the surface grates
  4. Checking an common oven temp sensor
  5. Checking an common oven temp sensor: What does an oven temp sensor look like?
  6. Gas range repair aid - such as, my oven won't work or heat up, which style of gas oven do I have, the glow coil gets red but my oven burner will not light.
  7. GE gas range conversion from NG to propane
  8. How to change the oven temp on some common electronic controlled ovens
  9. How to re-light a surface or oven pilot light
  10. How to change a common oven glow igniter coil
  11. How a common gas valve works - click here.
  12. How Ranges, Ovens, and Stoves Work
  13. Help for storing an appliance
  14. Important Disclaimer
  15. Installing a gas flex line connector
  16. Maytag, (some) Magic Chef, (some) Jenn-Air gas range surface spark module - new module kit
  17. Maytag ( Magic Chef - Crosley - Jenn Air ) gas range conversion NG to propane
  18. My gas range flames die when I turn on more than one thing at a time
  19. My Range is flashing an " F1 F2 F3 F4 F5 F7 F9 " something, what does this mean?
  20. My surface burners keep "clicking" even after the burner is light
  21. Oven door and door hinge help
  22. Oven temp sensor - how to change helps
  23. Repair tips and information on surface burner spark modules and igniters
  24. Some "how to set the self clean" on my range
  25. Stainless Steel Cleaning
  26. Surface burners wont work
  27. This morning I noticed the range top ignition was clicking all by itself every 15-30 seconds
  28. Test for F1 fault code
  29. WCI - Frigidaire ( some Kenmore's ) gas range conversion from NG to propane
  30. WCI - Frigidaire /open burners/ (some Kenmore's) gas
  31. Whirlpool Direct Spark Ignition (DSI)
  32. Yes, your glow bar igniter can glow red and still be bad!!
Apr 01, 2009 | Maytag MGR5765QDQ CleanDesign Gas Kitchen...
Glow plugs stay and wont shut off
Your problem sounds like the glow plug relay is faulty. It sees to be stuck in the closed position. It is mounted on the fuse board.
John
Feb 21, 2009 | 2003 Volkswagen Jetta TDI
Tappen model TGO356BCW top oven
replace the igintor. its not working properly. no doubt you have a bad ignitor
Mar 15, 2008 | Tappan TGF320 Gas Kitchen Range
Dryers Logo
48 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
