Question about HP Pavilion dv6000z Notebook
Hp pavilion dv6000
I have just bought a new hp laptop and I cannot seem to get internet connection. How do I know if the wireless button is turned on. If it is turned on is the light red. When I turn it to the right or the left the light is still red. Can you please please help me We have been using our wireless laptop for 2 years now and today I can't get an internet connection. The wireless light is red whether it is moved to the left or right position. Our other laptop in the house works fine so I know it is this computer. I have tried to turn things on internally, but to no avail. Please help!!! We have Vista on this computer. We have an HP Pavillion 6000.
  • 29 Answers
I have an HP Pavillion dv9000, but they are similar.
Now if you are moving the Wireless switch on and off and the light stays red on both sides you probably have a dud of a wireless card. I had the same issue with mine at one point, what I did was get a hold of tech support, they mailed me a box with a prepaid shipping label to send them my laptop. They put in a new wireless card and shipped it back for free(of course it was still under warranty).
If you recently purchased this laptop you can usually log onto www.HP.com, go to the support section and do the chat with an HP tech or call 800-HP invent or 800-474-6836 24/7 and they will walk you thru the whole process.
But again just from your description, you have a dead air card. Call or online hp and have them fix it for you, especially if its still under warranty. If its not under warranty, then hit me back and i can give you a step by step on how to open up the laptop yourself and replace the card
Posted on Dec 01, 2008
Cannot connect to wireless internet
First, do you have a wireless router button that enables or disables wireless internet? If so than it might have got accidently turned off. push it and see what pops up on screen. If it says enabled than it was turned of try connecting to internet again. If it says disabled than push again until it says enabled clearly that wasn't the problem. Next try going down to the two computers (right hand bottom corner) then double click them. This will bring up a wireless networks available, try refreshing this page. After refreshed if no networks are available than it may have to do with your internet provider. Try calling them to get a better detailed explanation.
Jul 19, 2010 | HP Pavilion dv6000t Notebook
Tip
How to Disassemble an HP Pavilion DV6000
The HP Pavilion DV6000 is one in a popular line of consumer-oriented laptops produced by HP. Relatively inexpensive, the Pavilion DV6000 is a good all-around value for most users. Taking apart an HP Pavilion DV6000 is not an easy chore and if you plan to use the laptop again, it is important you know what you are doing or you have a large appetite for risk. If the above doesn’t describe you, consider taking the HP in for professional repair or upgrade. Otherwise, follow the steps below to disassemble the HP Pavilion DV6000.
18385245_1.jpg?w=200 1、Prepare a clear workstation. Turn off the laptop and remove all power components including the cord and the battery. (Turn the laptop over and you will find the tab to push and pop out the dv6000 battery.) Also remove any peripheral attachments like card readers and USB devices.
90-04208-003_original-hp-pavilion-dv8000z.jpg?w=250 2、Turn the HP Pavilion dv6000 upside down and unscrew all the screws you find. Try to keep them separate by size so you can put them back in the same spot when and if you decide to reassemble the laptop.
3、Remove the hard drive and memory modules by pulling up on the rectangular compartments. The memory is located in the central compartment (remove by spreading latches and pulling up), and in most HP models the hard drive is located to one side.
4、Remove the optical CD/DVD drive by pulling on the drive face to the left and out of the laptop. Remove the WiFi card by disconnecting the gold connectors on the antenna and pulling the card from its slot.
5、Turn the hp dv6000 back over and remove the keyboard and power panel/media touch pad. Carefully pry the power panel up with a piece of hard plastic near the power button on the left side. Be careful when pulling not to yank the power connection as you might accidentally rip out a wire. Pull back the keyboard to reveal the connections. Disconnect the connections by carefully pulling on the tabs with your thumb and forefinger. If they are tight, wiggle them back and forth while pulling on them to loosen them.
6、Remove the screws that were underneath the power pack/media touch pad. Carefully pry up the top casing and set it aside.
7、Detach all visible connections to the motherboard by pulling gently on them, wiggling them if they are stuck. Gently pull up from the right side of the motherboard and remove. The HP laptop is now fully disassembled.
on Jan 21, 2010 | Computers & Internet
I have an hp pavilion dv6000 and i caint seem to get my webcam to work it keeps telling me a network has occured while connecting to the server please can someone help me(its built in my laptop)just to let...
This is because your internet network connection is not that strong, so i'll advice that you get your computer to a stronger internet server. Once this is done you can connect to webcam. I bet you this is just a connection speed problem. Please upgrade your internet speed and your cam would be able to connect faster to the server.
Hope this helped.
Regards
Sep 24, 2009 | HP Pavilion dv6000z Notebook
Wireless network card
Hi there.
The wireless switch on the front bottom of the laptop, it's suppose to be blue when the button is on the right.
Right click on computer and select manage, go to device manager, and go to Network Adapters, try to see a network adapter called Broadcom, if it doesn't appear, it means that your computer doesn't recognize the wireless card and you may have to reinstall the drivers.
Please let me know how you get on.
Good luck
May 28, 2009 | HP Pavilion dv6000z Notebook
HP Wireless Assistant
I just had the same problem with my wife's HP Pavillion dv6000 laptop.
It was working fine, then just stopped recognizing the wireless card. My daughter had been using it, so I was in doubt as to what had/hadn't been done to it software-wise (virus?). So I ran the complete recover to restore everything to the state when it was new.
Still can't recognize the wireless. The indicator light stays orange no matter which position the switch is in.
So I google "HP dv6000" looking for a manual, and the FIRST thing I find is a Recall notice http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c01087277 Yeah, I know, they're covering their butts by calling it a
"Limited Warranty Service Enhancement" but they basically know that these machines were defective from the date of manufacure. They told me that my machine didn't qualify for the free service because it was 9 months past the warranty extension and tried to get me to shell out $250 for a new mother board.
Maybe I'll try the external wireless card solution, but it sounds like the MB will probably go bad next. I've owned a bunch of HP computers (have four of them working in the house right now) but I'll probably be looking at Dell next time around.
Jul 27, 2008 | HP Pavilion dv6000z Notebook
Hp pavilion dv6000
This is a manufacturer trouble.
Starts with WiFi troubles, then no screen and no start with 1 long and 2 short beeps.
Here are those who came with same problem>
http://www.tabletquestions.com/notebooks/53305-hpdv6000-beep-codes-no-display-startup.html
Hp resolve this problem by changing the mainboard on good warranty notebooks
i have the same problem but can\t go to the supplier, had no warranty.
icq 475653626
Sep 01, 2007 | HP Pavilion dv9205us Notebook
HP Pavilion dv6000z Notebook Logo
213 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
