Qsc 3604 no highs on channel one - Audio Players & Recorders
2 Suggested Answers
  • 166 Answers
SOURCE: qsc mx 2000a left channel go into protek mode
Does it do it with nothing connected to the inputs and outputs? If yes, something internal.. anything loose in there (is it moved alot and something could have fallen inside of it)
Posted on Mar 28, 2010
Not putting out sound fan on light on
A common issue with the QSC RMX series amp is faulty volume pots, so i would recommend go this way first of all, let me know a bit more to improve help.
Feb 04, 2013 | QSC Audio Products QSC RMX 850 RMX850...
How do I bridge my QSC GX 3 amp to run one speaker cabinet?
For QSC amps the GX series are not bridgeable. You will have to run one speaker to each channel.
Mar 22, 2011 | QSC GX3 Amplifier
One of my channel stop working in my qsc mr 1500a is this fixible and how much rounding of would it be to fix it
sounds like the output chip has been fried just take it to a tech not unless u know what u r doing then just fix it youself
Mar 15, 2011 | QSC MX1500A 2-Channel Amplifier
MAckie 1604 VLZ Pro Mixer, running QSC 1850 with jbl's from main outs. I would like to hook up powered subwoofers. What is the correct pathway? kenshireman@msn.com
The best way is to use a two-way crossover between the mixer and the amplifiers. In your case, the low output from teh crossover would go to the powered subs, the highs to the QSC. Use the crossover adjustment to set the frequency crossover point to get the sound quality you require.
Dan
Mackie 1604 ---> Crossover --- Highs ---> QSC --->Speakers
-----> Crossover --- Lows ---> Powered Subs.
Jan 27, 2011 | Mackie 1604 Vlz3 16 Channel Mixer
Qsc mx 2000a left channel go into protek mode
Mar 28, 2010 | QSC MX1500A 2-Channel Amplifier
My QSC GX3 has a red light that turned on (on the front panel). The channel is not working. Is this a fuse or something else?
You should check the speaker set, maybe it's short circuit.
Try remove the speaker set from the unit, than switch on the amplifier again, if the red light still on, surely the final drive is damages( Transistors or IC's).
Replace it with new ones.
Oct 18, 2009 | QSC MX1500A 2-Channel Amplifier
Soon as i turn on my QSC RMX2450 the clip light comes on for Ch 2
Sounds like an output going bad. Try to get some electronic contact cleaner and spraying on the circuit board. If its corroded this will help clean the circuit..
Sep 07, 2009 | QSC RMX-2450 Car Audio Amplifier
QSC ISA 280 Stereo Power Amp stopped working
This is a very precise questions as QSC amp are pretty rare and high end electronics equipment. There is no way getting an answer other than getting the amp at a sound shop for repair, wich might go for a visit at QSC anyway. From a sound shop repairman...
Sep 07, 2009 | QSC ISA 300Ti Amplifier
QSC 1420 pwr amp
The weaker signal caused by leaky capacitor and change value resistor is need to replaced with a new one so it's works normal again. Your tech did is re soldering the cold solder he did not replaced some defected parts.
Hope it may help you;
Regards;
VOTIT
Jan 07, 2009 | QSC MX1500A 2-Channel Amplifier
49 people viewed this question
 Grubhead
Grubhead
