Question about Craftsman 26 Hp 54" Deck Yard Tractor
Gas flooding breather,cylinders and fills oil pan.
The first mower of this model was returned to sears 2days after purchase with the same problem.I have had this one for a few months with no problems till now.After being parked for a few weeks gas has flooded the breather housing,cylinders and oil pan.
  • Anonymous Mar 21, 2014
    the carb is flooding and gas is getting into oil thru the breather tube. any fixes?
    Guru:
  • 674 Answers
The needle in the carb is leaking by
you will need to remove the carb ad the float bowl and and check for somthiing in the needle and seat and check for damage and that the float moves freeley. then change your engine oil
turn your gas on and watch for leaks
Posted on Dec 02, 2008
Craftsman lawn mower smokes
Has the mower been tipped up? if so sump oil can travel through the breather and into the air filter soaking it in oil which then in turn burns and smokes, remove the air filter and see if is soaked in oil.
There are other reasons, engine over filled with oil, engine breather blocked, engine worn.
Jun 02, 2018 | Craftsman Garden
My 2000 r6 is now shutting completely off after only making it a block down the road. Sounds like it is bogging down or flooded before it shuts down and fills the crankcase with gas and oil
dont know this vehicle is it a two stroke or four stroke. if its a two stroke then gas and oil in the crank case is quite normal, it the method of lubrication for a two stroke.
Oct 03, 2016 | GAS Motorcycles
Breather problem?
If gas is mixing with the oil you have a carburetor issue.. The flost is not shutting the fuel off and its flooding into the engine and mixing with the oil making it thin. You will have to have the carburetor removed, inspected and either cleaned or a new seat or flost, (if defective) replaced. The oil will also have to be flushed, oil filter (If equipped) replaced.
May 25, 2013 | Briggs & Stratton Garden
Gas leaking from crankcase breather hose 750 honda aero 2005
Most likely cause is carb flooding due to sticking/leaking float valves...
Sep 22, 2012 | Honda Motorcycles
I GOT A SEARS CRAFTMAN riding lawnmower 17 hp 42 inch cut kohler engine.and when i start oil come out of my exhaust what causes that
Either over filled with oil, valve stem seals leaking, engine breather blocked, or the engine is badly worn.
Mar 13, 2012 | Garden
White smoke blowing from front cylinder on my 79 harley ironhead
Hi Anonymous, and the usual suspects are:
1. Oil tank/pan overfilled.
2. Restricted oil return line to oil tank/pan.
3. Restricted breather operation.
4. Restricted oil filter.
5. Piston rings badly worn or broken.
6. Valve guides or seals worn or crushed.
7. O-ring damaged or missing from oil pump/crankcase junction.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Mar 07, 2012 | Harley Davidson XLH 1000 Sportster...
I have a 1982 yamaha 650 seca turbo. I just bought it and was gone for two week on vacation. pon returning, my motocycle leaked gas from the exhaust pipes. So I cleaned my carb. Boiled it in lemon...
When the carburetors over flow enough to fill the exhaust, It is possible that the gas also went into the cylinder and flowed past the rings and into the crankcase. With the engine overly full of gas and oil you could easily pop a seal or blow out a gasket. Check your oil level. If it is too full , change the oil, it will not lubricate properly with all the gas in it. Check that your shaft seal has not popped out. Check the air filter, the breather may have blown oil and gas all over it when you started the bike. Empty your pollution tubes behind the motor( they will drain the air box). Get in the habit of turning your fuel petcock off when not riding. This gas flooding happens randomly in certain models but can happen to any one.
Sep 07, 2010 | 1981 Yamaha XJ 650
Engine oil appears to be discharging through the air breather. Came on all of the sudden and seems to foul the breather within a short period of time. Rode about 20 miles and stopped within half an hour...
Check your oil level . If it is too high smell the oil to see if it is fouled with gas. If your carb needle sticks the carb may over flow filling the engine. When the engine is too full the breather blows the oil and gas into the air box. Another way to get gas in the oil is if the fuel petcock malfunctions and pours gas into the intake manifold. If the diaphragm of a vacuum petcock gets a hole in it , the engine may flood with gas. The gas flows into motor and past the rings. If you look under the engine in front of the rear wheel you may see a tube with a plug in it. Place a pan under the tube and pull the plug. It is a pollution tube for emptying the crud out of the bottom of the air box. Some Honda's used to fill there engines with gas randomly. If it happened you just changed the oil & air filter, and kept on driving. It just happened for no logical reason. So check your petcock and carbs for problems, change your oil and air filter, and always turn your petcock off when not riding.
Aug 29, 2010 | kawasaki VN 2000 Classic LT Motorcycles
I have a Sears Craftsman mower with Tecumseh, major oil leak
On many Tecumseh engines, there is a crankcase breather located under the flywheel. It has a cork gasket to seal the top plate of the breather. Either the rubber breather housing is cracked, or the cork gasket needs replaced.
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Nov 07, 2009 | Craftsman Garden
Craftsman 26 Hp 54" Deck Yard Tractor Logo
369 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
