Question about GE Profile JGP636 Gas Cooktop
Ge stove top lock buzzer
I have a ge stove top with a burner lock. The lock light remains lit whether in the locked or unlocked position. When a burner is lit the alarm buzzer sounds. I need to unplug the stove top or switch off the breaker to make it stop.
  • 842 Answers
SOURCE: GE gas cooktop modelJGP970BEK2BB. The
The lock switch will need to be replaced. Lock switch, the switch has failed and causes the buzzer to run. Not a difficult repair but the top will need to be remover to fix this. This is not advisable to repair if your not knowledgeable with the installation part of this unit.
Good Luck
Posted on Oct 10, 2011
Wha is the small red light and buzzer for on the GE JGP975SEKSS gas cook top?
Red light normally means it on. Usually also means the stove is on and the buzzer is probably to let u know when oven is ready or is part of a timer.
May 29, 2015 | GE Cooktops
GE gas cooktop modelJGP970BEK2BB. The unit is in the unlocked position, burners will light, but "lock" light remains on and buzzer/alarm sounds the whole time?
Good Luck
Jul 19, 2011 | GE Profile JGP636 Gas Cooktop
When you turn on any burner on the spark igniter will stay on after the burner is lit and the knob is turn from the lite position.
You could of possible got the stove top wet causing the problem.This problem although sounds like your spark ignitor module went bad.
Feb 10, 2011 | GE 30 in. JGP328 Gas Cooktop
My ge monogram stove top burner( model zgu366h)continues to ignite. even after the flame is lit
If you are saying the clicking continues you must move the burner knob past the LITE position.
If it continues clicking with the knob past the LITE position the ignitor switch behind the knob is bad.
Nov 30, 2010 | GE Cooktops
Holiday Stove Pilot Light won't stay lit.
Wow this problem sounds exactly like my landlords problem only he is just now saying he is learning of the problem. You even have the age of the stove correct.
Jun 16, 2009 | Cooktops
How do I unlock the burners?
there should be a key that you have to press and hold to unlock. find it and press till the light is gone let me know how it goes
Jun 12, 2009 | Dacor Millennia ETT304 Electric Cooktop
All 4 ignators are spaking with the contrtols on off position on my GE JGP328 cook top
It's the Switch Harness. Do not remove the stove and disconnect it from the gas. Turn the gas off under the stove. Take off the: knobs and the plate; burners; hxw screws. Pull burners out and disconnect igniter burners. Lift the top of the oven off. The Switch Harness is on the right, under where the knobs are located. Replace the Switch Harnes.
Mar 30, 2009 | GE 30 in. JGP328 Gas Cooktop
Can't get burners lit.
1. make sure the gas is turned on.
2. Make sure unit is pluged in.
3 make sure all burner and burner caps are aligned.
If you hear a spark and you small gas it should light.
Make sure the burner heads are not clogged.
If this top has pilot lights make sure the pilots are lit
Nov 23, 2008 | Cooktops
Just bought a house, no manuals
After a pot spillover, the cleanup process triggered my stove top to "control lock"
I removed the pot and once the stove top cooled I pressed and held the "control lock" button.
It began to blink, I released it and then the light went off and the stove top operated normally.
You might not have to wait for the stove top to cool. I don't know.
Aug 24, 2008 | GE Profile JP930 Electric Cooktop
Stove-top burners
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range RepairBurners Keep on Clicking
heatman101
bvn
Jul 10, 2008 | Belling 27 in. CTC465 Electric Cooktop
GE Profile JGP636 Gas Cooktop Logo
79 people viewed this question
Top GE Cooktops Experts
Dan Webster
Dan Webster
meztang
meztang
Are you a GE Cooktop Expert? Answer questions, earn points and help others
