Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Cold water keeps filling even when knob is pushed in
All the cycles work but cold water wont turn off even when konb is pushed in
    Genius:
  • 1,028 Answers
Replace fill valve trash has gotten past screens in valve or screens are missing..remove screws each rear corner of console ..lift console ..remove lid switch plug remove clips each corner of top pull cabinet forward and off
Posted on Dec 01, 2008
I pull the knob to do a regular wash and nothing happens, no water no agitation. However, when I turn the knob to rinse it that works. This suddenly happened, was working before. Is it the knob?
Rinse on most washers is cold water your wash cycles can be cold hot and even warm. Problem You may have is a bad water feed valve Or Timer and possible bad wire harness at motor to timer
check water valve Turn washer to regular wash cycle pull knob on will washer fill ?
if water starts to fill then change washer temp if washer has this.
if water comes out on all settings water valve is fine.
Check the water both hot and cold that it is turned on;at faucet.
Your Kenmore Most likely has a bad water valve check for hot water side clog or not working.
Apr 25, 2015 | Kenmore 2982 800 3.5 cu. ft. Top Load...
Water wont go in washer when on cold /cold or warm cold but will fill on hot cycle. Only cold water is connected. i dont even have hot hose connected---has worked fine for a year on cold/cold. Now has a...
The inlet valve on the cold water inlet is clogged, dirty or jammed. You need to remove the inlet valve and clean the valve and filter. use back flushing with brushing to clean the filter.
the hum you hear is of the coil working but is not opening to allow water into the system.
Also you can switch the inlet valve from the hot line if needed .
check this link for removing the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Sep 13, 2011 | Washing Machines
Our gibson washing machine stops filling water from cold valve and when we turned the knob to warm, it fill normal for washing cycle, but it does not fill for spin cycle.. Is this because of defective...
check the cold fill hose screen for silt or dirt. also check at water valve for the same and clean. you must have at least 20psi of water pressure for the water to come in. also on most washers cold water is used for rinsing.
Feb 09, 2011 | Washing Machines
My 21882 top load Kenmore washer will start the cycle but stops after filling up; i can restart the cycle by pushing the knob in and going a little further in the cycle then starting again. But after a...
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
  • Jan 29, 2011 | Kenmore 24032\24036 Top Load Washer
    The washing machine won't start if "cold water" only is selected. It will only work when "warm water" or "hot water" is selected (and even then there is only hot water filling the machine, the cold water...
    Check the cold water solenoid. If a meter is not available you can swap the hot and cold wires and see if the symptom changes to hot water when cold is selected. If so the mixing valve needs replaced. If no then further testing of the wire harness and timer circuit are needed.
    Eric
    Apr 13, 2010 | Kenmore 13202 Top Load Washer
    Washer tub won't stop filling with cold unless tap is off
    Sounds like jammed open solonoid valve on hot or cold......water?,,quite simple to fix parts about *£8.00
    Nov 02, 2009 | Washing Machines
    Cold water constantly runs even when the knob is pushed in to turn washer off.
    If it fills with water and starts the cycle and the water keeps running in then your water inlet valve on the back where the water supply comes in is sticking. It needs replacing. The cold side can fail independently of the hot side.
    Oct 14, 2009 | Frigidaire FWS833A Top Load Washer
    Maytag neptune front loader
    check the following
    power cord plugged into a grounded 3 prong outlet
    the inicator on the cycle conrol knob proprely lined up with a cycle? turn the knob to the right slightly then pull the knob
    are you using a extention cord if so dont
    washer overloaded
    Jul 19, 2009 | Maytag Neptune FAV6800AW Top Load Washer
    Washer wont complete cycle. its full of water and I cant drain it
    if this a manuel timer,,you either stripped the ,,knob,,or you broke the timer its self...make sure that timer can be pushed and pulled,, pull ----on push is off
    Nov 30, 2008 | Kenmore 24902 Top Load Washer
    LTE6234 Whirlpool Twin Thin Timer Broken?
    Check for voltage at the water inlet valve with the timer dial pushed in or in an off position. If no voltage replace the water valve. If you do have voltage you'll have to trace the circuits back from the water valve to the line. One point of demarcation is the water level switch. Pull the violet colored wire and see if it still fills while off. If it does it's likely the timer's bad.
    Jan 31, 2008 | Whirlpool LTE6234D Top Load Stacked...
    Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
    42 people viewed this question
    Sal De
    Marvin
    Marvin
    Gerry Harvey
    Gerry Harvey
