I have Konica 7022 copy machine and have F28-3 error massage from minitor. paper jam is occur soon after hit copy button.
I am not an expert. I am someone that is lucky a lot when I have to fix something. I also had the F28-3 error code. The copier would begin to copy. However, when the unit began the printing process, the error code would indicate.
1) I downloaded the Service Manual (not the user manual) and checked the error code. This is what it says: Abonormal separation spark detected 5 times in 20 ms intervals, 5 times in succession for the same job.
2) I went on-line and found a couple of blogs from techs which stated that it in their opinion, it was one of three things, the T/S Corona Unit; an insulation failure which should be indicated by discoloration and a burnt smell where arcing has occurred; and the high voltage unit.
3) After removing the drum assembly and inspecting around all corona units, I could not see or smell any signs of arcing. So, I inspected the T/S Corona Unit and found one of the wires broken.
4) I removed the T/S Corona Unit, disassembled it using the instructions in the Service Manual.
5) I reinstalled the T/S Corona Unit and gave it a try. So far, so good. Copies normally again and no more error codes.
Good luck.
Posted on Dec 24, 2008
Closed 1st side cover konica minolta bizhub 185
Check the 2 actuator at Right Door assy, may be broken, so while closing it is not blocking/hitting the sensors on body.
check properly - at Rear-Top & Front-Below on Right Door assy.
Dec 09, 2016 | Konica Minolta bizhub Office Equipment &...
My Konica Milnolta c224e display massage bye pass try could not be loaded
Sure it say that exactly never heard that before doesn't say "Replenish paper"? or does it give a code or jam indication
Is there any paper on it does this happen when printing or copying ? Trying to print paper or envelope? Do the draws work OK? If printing send the print job to the machine first the when the copier states replenish paper for the bypass tray put the paper there. insure your printer perfrancies match your setting on the copier for the bypass tray, such as THICK 1 or what ever
Feb 03, 2015 | Konica Office Equipment & Supplies
Konica 7022 error F35-1
F 35-1 pertains to Abnormal Low fixing temp TH1. Try to clean the thermistor and reset the code by entering mode 25, software switch 3-1, make it zero. If the problem occur again, try to replace thermistor. Make sure that AC supply from mains is okay.
Aug 27, 2014 | Konica Minolta 7020 7022 7025 Copier Drum...
Konica 7022 26-3
Yes I stated what I recommended to do in your last post!
Jul 12, 2014 | Konica Minolta 7020 7022 7025 Copier Drum...
Clear error message
clean the rollers for that draw or have them replaced
Feb 07, 2014 | Konica Minolta bizhub Office Equipment &...
F-28-1 curently appears on my screen
F 28-01 High voltage power supply abnormality.
Ihe charging ON/OFF operation has been performed five consecutive times since the charging trouble detection signal was detected at start of charging.If there is a paper in copying process when this jam occurs,the machine stops after completion of copied paper ejection.Verify the charge wire,change and the holders.Check the high voltage unit.
F - 28 -02 Toner transfer wire malfunction
F - 28 -03 Toner separation wire.malfunction
Feb 11, 2013 | Konica Minolta Konica 7020 7022 7025 7030...
F-28-3 knoica error
F 28-03 The toner separation ON/OFF operation has been performed 5 consecutive times since the separation trouble detection signal was detected at start of toner separation.Please check the HV2 unit,the transfer/separation corona unit.If there is a paper in copiymg proces when this jam occurs the machine stops after completion of copied paper ejectiom.
Oct 01, 2009 | Konica Minolta DiALTA Di200 Copier
Replaced Konica 7022 toner and add toner light stays on
Remove the toner bottle carefully, pwr off and unplug the machine , then plug it in and turn it on do not put toner bottle into machine until asked for.
Jun 30, 2009 | Konica Minolta Office Equipment & Supplies
Konica 7022 with Problem code F-26-1
There is toner/starter spilled onto a sensor near the drum, it mite just need to be cleaned, this sensor monitors the drums abililty to develope a image, if the cleaning does not work it mite be the sensor or the drum. The drum needs to be removed to clean the sensors.
Mar 23, 2009 | Konica Minolta Office Equipment & Supplies
Konica 7022 (code F-26-1) Pls call service 0870-2425050)
i have a konica 7022 it say call service code F-35-3, what's wrong with it, help me.
Mar 21, 2009 | Toshiba 2060 Copier
617 people viewed this question
jasbo
jasbo
