Question about Brother LS-1217 Mechanical Sewing Machine
Walking Foot for Brother LS-1217
I purchased a generic walking foot, but it will not work on the model I ?have. Has anyone used a walking foot on their LS-
  • 65 Answers
Beckster, it may simply be that the walking foot needs to be tweeked a bit, perhaps screwed in further, or less.
If that doesn't help ...
Check out this site. All the Q&A answers in simple language, as well as a GREAT cust. support staff. (its a Brother after all!)
Posted on Jan 24, 2009
Brother sewing machine LX 2500
Walking feet attach much the same way on most machines. They can be boogers the first couple of times. It helps to tilt the foot and guide it toward the needlebar from the side in order to get the fork (if your foot has a fork--some just have a bar that sets on top of the needleclamp screw) around the needleclamp screw. In cases of extreme frustration, I've removed the needleclamp screw and then reattached it once the foot is in place.
Just use patience. If frustrated, walk away. Whatever, do not force or bend the foot in order to install.
How do attach the walking foot Brother
How to use the Brother SA140 and SA188 Even Feed Walking Foot
How to Use the Brother SA107 Walking Foot
Attaching Walking Foot
How to attach walking foot to your sewing machine Elizabeth Ruffing Art...
Problems installing my walking foot
Jun 07, 2016 | Brother Sewing Machines
Does a singer model 188U have a walking foot?
No that is not a walking foot machine. There are no industrial walking feet that will last.
Jul 09, 2014 | Brother LS-1217 Mechanical Sewing Machine
Brother cs6000i thread tension issue
Logically, the top thread should not be affected by a walking foot as the thread operates independently of the presser foot.
Suggest removing the top thread totally from the machine. ALWAYS RAISE the presser foot and rethread from the beginning. Verify the thread path is correct.
Check that your walking foot is installed correctly--the fork-shaped piece needs to encircle the needle clamp screw.
If you continue to experience problems with the walking foot but none of the other feet, recommend contacting a Brother technician.
Jun 26, 2017 | Sewing Machines
Pfaff varimatic 6091 What type of walking foot can i purchase for this model and are they very expensive ?
You could probably get away with a generic walking foot. They are available in the fabric store for a little under $20. Once you use one, you will wonder how you got by without it before!! I've attached a sample of a product that would work for you. Just be sure to NOT get the "slant" walking foot. That is for the Singer machine, and they have a different setup. Enjoy!!
Amazon com Distinctive Even Feed Walking Sewing Machine Presser Foot...
Mar 10, 2014 | Sewing Machines
I purchased an Elna 7000 on E-Bay.Wonderful machine. I also purchased a 492000-20 walking foot for it. I can not find instructions on how to attach the walking foot to the machine.
I'm assuming that this is a generic style walking foot for low shank machines and it will fit your Elna?
To attach it, you will see a long lever arm at the front of the foot and the little curved bracket at the back of the foot.
Remove your usual foot and the clip on foot holder by undoing the thumb screw. Now fit the walking foot on instead by putting the lever arm around the needle bar and the curved bracket around the pressure bar and then putting the thumb screw back into place and screw up tight to hold the foot in place. Now lower the pressure foot and manually wind your machine forward a few stitches. As the needle bar goes up and down, it should move the long lever arm too which works the walking foot teeth gripping the top layer of fabric with each stitch.
Trust this helps.
Mar 24, 2011 | Elna 8007
I don't know how to attach the walking foot to my LS 2125.
When installing the walking foot, you must make sure that the arm that moves up and down is resting on the needle clamp screw. That arm controls the movement of the foot and that allows it to do its "walking" if it is not resting on the needle clamp then it will not work at all.
Feb 22, 2009 | Brother LS-2125 Mechanical Sewing Machine
Attaching walking foot
you probably purchased the incorrect walking foot for your specific machine. check and make sure if you have a high shank or a low shank....the way to determine if you have a low-shank is to measure the screw from the plate and look at the distance if it is 5/8 then you have a low, any higher about 1in. then you have a high shank, so you would purchase a foot depending on your shank.
Mar 20, 2008 | Brother LS-2125 Mechanical Sewing Machine
Brother LS-1217 Mechanical Sewing Machine Logo
363 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
