Question about HP Deskjet D1430 InkJet Printer
Hp deskjet d1430 not printing
Printer is on. Cover is closed. Printer icon shows on bottom right corner. Print job shows in que. Does not print.
  • 33 Answers
If you double click on the print que, look at the status heading...what does it say? If it says printing and then windows gives you a "this document failed to print", then you probably have a driver issue. Delete the printer and re-install. If it says paused then right click on the job and clickon resume. You might also want to check in the printers and faxes folder, right click on the driver for the printer, see if an option is there that says resume printing, click it if it does. Also right click on driver and select properties, under the ports tab see if the correct port is selected. Best I can do without knowing more detail.
Larry
Posted on Dec 01, 2008
Cancel print job with a linux operating system
HI,
You've sent a print job to your printer and the green light is blinking, but the printer is not printing. The light blinks for a very long time.
The blinking light indicates that the printer is recieving your print request and will print shortly. If the document you are attempting to print is very large or contains many graphics or images, the printer must spool this data into its memory before printing. This can take quite a bit longer than usual. PDF files are notorious for taking longer than other document types.
In this case, it is best to wait a period of time before taking action. Give the printer 10 minutes and see if it prints.
If it does not print within this window of time, do the following.
1. In the bottom right corner of your screen, you will see a small printer icon. Double click on this icon to open the printer job menu.
2. You will see your print job located there, with other information, including its status.
3. Select the job by right clicking on it and select Cancel.
4. The job should cancel itself.
5. Unplug the printer, removing all power and leave it sit for a couple of minutes.
6. Plug the printer back in and allow it to go through its start up phase until the "Ready" indicator light is solid. This indicates that the printer is ready to recieve jobs.
7. You may now attempt to print again.
Thanks,
HP Printer Support
Jul 16, 2014 | HP Office Equipment & Supplies
I entered a print job that I want to cancel. How do I cancel printing?
Click on the printer icon at the lower right hand corner of your screen.
This will bring up the print spooler dialog. Make sure the print job you want to cancel is selected.
You will find the Cancel command in the menu.
Hope this helps.
Jul 21, 2011 | HP DeskJet 970cxi InkJet Printer
Have hp d1430 printer, I only use the color print cartridge, the printer will print color but will no print normal black lettering, have tried two different hP22 cartridges. Is the printer done for?
YOU SHOULD USE HP 21 BLACK INK CARTRIDGE FOR BLACK PRINTING.IF YOU USE 22 COLOUR CARTRIDGE YOU WILL GET ONLY GREAY PRINTING ONLY.I AM RIGHT?IF YOU USE COLOUR CARTRIDGES MAY YOU WILL GET MONEY LOSE. BECOS IT WILL FINISH EARLY.BLACK INK COST IS LESSTHAN COLOUR INK CARTRIDGES. SO YOU SHOULD BUY BLACK CARTRIDGE FOR REAL BLACK PRINTING.
Jun 29, 2011 | HP Deskjet D1430 InkJet Printer
Printer keeps printing same file even though i want to print a different one
My friend, the computer and printer do what you tell them to.
Jobs are sent from the computer to the print Que and are printed according to the instructions you have provided. This is a very long shot. I suggest you open the print Que and see if there are any jobs pending. Sometimes jobs get stuck and are waiting for manual instruction from you. If jobs are stuck there - cancel or delete them. In a few very unusual cases, they will not cancel nor delete. What I do in this case is I remove the printer from the system, reboot my computer and reinstall the printer. I don't think this is necessary in your case, however.
Find the printer icon on the bar at the bottom of your window ... to the right side. Click on it and the que will open up. If it is not there, there are no jobs pending - so - send a job to the printer which will cause the icon to appear.
I think your trouble is you are not sending the job that you think you are. Assure the file you want is open then print it from within that application for best results.
Thanks for your question at FixYa.com
Jan 28, 2011 | HP DeskJet 970cse InkJet Printer
Job in printer que will not print or delete
go to safe mode and then delete the queue in printer
May 18, 2010 | HP Deskjet 6940 InkJet Printer
I stopped a print job and do not want it to continue.
Well, go on to print que on the bottom right side corner and look for the Printer Icon when found it double click onto it and delete the one you would not like to print..!
All the best..:D
Feb 13, 2010 | Brother HL 1440 Laser Printer
How do you clear out all memory of a printing job for a deskjet 895cse printer?
Click on Start, Click on Printer & Faxes, Click on Your Printer, it should be with the one that has a check mark on it. Double click on that Icon, and then click on Printer, then click on Cancel all Documents. If you find this information helpful, please rate me.
Thanks and good luck.
Jan 02, 2010 | HP DeskJet 895cse InkJet Printer
HP P1005 PRINT JOB SITS IN QUE, WO'T PRINT
Does it show "Printing" or "Spooling" in the job queue window?
Open the Job queue window, then highlight and cancel the print job. Send a small print job to the printer and make sure that the PC and the printer are communicating.
If the failure re-occurs, then clear the queue again and close it and restart i=the queue.
Don
Dec 14, 2009 | HP Hewlett Packard LaserJet P1005 Printer
My HP Deskjet D1430 won't print in color anymore
Try going to the printers properties page, go to the color tab, and be sure that "print in grayscale" is unchecked....keep me posted...
Mar 10, 2009 | HP Deskjet D1430 InkJet Printer
HP Deskjet D1430 InkJet Printer Logo
257 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
