Question about Akai PDP4225M 42 in. Plasma Television
Akai PDP4225M red std/by light on
What values should I get when testing the schottky diodes? I've changed all 20+ caps on the power board. Thanks for the advice there where several bad ones but they were leaking from the bottom not the tops.
    Problem Solver:
  • 8 Answers
Stevenson
There is a difference between diodes and capacitors. The role of a diode is to rectify and some cases regulate voltages. Meanwhile, a capacitor is there to hold charges. Back to your question, to check an schottky diode, you need an ohmeter with a diode symbol, the reading starts like this .500, .600, .300. 125. still consider good forward bias. .1200 or infinite reverse bias is consider good still. But it shows 0 continuity then that diode is bad. You can also use ohm's law, resistance to also check a diode. Please e-mail me if you some further lesson at Stevebuy31@hotmail.com
Posted on Jan 22, 2009
Red power light comes on but when i push the power botton the light flashes once but tv doesnt turn on
Check for bulging caps in the power supply, replace with same value but higher temp.
Feb 18, 2011 | Akai Televison & Video
My Akai pdp4225m does not turn one green light is on but no pic or sound..There is a double clicking sound when I try and turn it on also when it does work it shuts off after and hour or so..Any info would...
Power supply filter capacitors and smoothing capacitors have warped. There will be some bad FET's, Diodes, and pull-up resistors too that need replacing. You can send us the board and we can repair it for you if you like.....
Your having a DC switching and regulation problem, its very common in these Akai models. I have repaired over 800 Akai LCD tv's so far since 2006. they all seem to have had the same fault scenario related to a similar problem like the one your having....
circuitworld@comcast.net
http://www.corkin.com/Profile/view.cfm?userid=77703
http://www.google.com/profiles/circuittvrepairs
http://circuitworldrepair.com/cwr.html
-Contact Us 443-802-7251
CWR-on_line Tech Rpt
Oct 29, 2009 | Akai PDP4225M 42 in. Plasma Television
MY BLACK COLORS ARE RED
steenson
To be honest with you. Do not waste your time change the main input board, your problem is solved. Because the main input board coul be defective. I can help you get the input board. Please, my e-mail Stevebuy31@hotmail.com
Dec 10, 2008 | Akai PDP4225M 42 in. Plasma Television
Akai PDP4225M std/by red light only
1st your power supply needs replaced. But you could have issues with the sustain boards and or your panel that is causing your power supply to fail. once you replace your power supply you should be able to power up the set, but if you don't get a picture then you will have to trouble shoot the sustain boards and panel.
Jun 30, 2017 | Akai PDP4225M 42 in. Plasma Television
AKAI PDP4225M HAS RED LIGHT BUT WILL NOT POWER ON.
this is because R001 is not 5.6 ohms, it's 560K ohms
Nov 10, 2008 | Akai PDP4225M 42 in. Plasma Television
hi isolate ur power unit out replece ur resisitor & every other burnt items then check the schottky diodes in the secondary side &the electrolytic capacitors if bulgge or leak. if all this are ok , power then use voltmeter to test ur output voltages if ok , unplug your inverter  & power
Nov 10, 2008 | Akai LCT3201AD 32 in. LCD Television
Akai Lcd TV
If Z3 was shorted, there are 2 surface mount resistors that were damaged when Z3 became shorted and they have to be replace as well. The reference designator for the resistors is R65A and R65B, their value is 10 ohms and 1206 is the body size of the resistors.
If you need further assistance or to get the power supply repair, write to jah2mil@hotmail.com
Nov 07, 2008 | Akai LCT2701TD Television
Akai LCT2715 No Power
I have a different thread going, but saw yours and had a question. Is your light blinking steady and then off? or is it a blinking erraticly or even flickering? My bad caps (15 of them) were all on the secondary side of the PSU. I have been told (thanks to Jaimie Hernandez) if you have a steady blinking, then it is very likely that you have a bad zener diode Z3(27v/1Watt) shorted in the primary side of the power board. If that diode is shorted, it's very likely that 2 10 ohms resistors might be open, these resistors are connected to the cathode of Z3. Also check for bad caps on the Primary side.
I had a huge incentive to fix the TV, it is my wife's TV and she has been in my Man Cave since it died. How about that incentive.
Good luck
Gallagher68
Oct 19, 2008 | Akai LCT2715 27 in. LCD Television
AKAI MLT168A Power Supply
If I give you the values of Z3, Z4 and Z5, would you return the favor by telling me what are the values for R104, R106, R107 and C17?
I have posted this request 5 times for 2 months and no body gave me an answer. Would you be willing to work with me? E-mail me s69joe@hotmail.com and use MLT168A-fixya as subject
Thanks
Sep 27, 2008 | Akai LCT2715 27 in. LCD Television
Akai PDP4225M 42 in. Plasma Television Logo
129 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
