Posted on Jun 12, 2012
In canon ir 2016 there is no scanner movement & also the laser lamp is not glowing & the machine is indicating check document
Ranjith kumar kannamvayal
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Oct 04, 2013
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
776
Points
In canon IR 2016j, if you get error " check document", its a communication error. so you check the flat cables in control board ( is a board in the scanning section)
* Change cable from scanning lamp
* change 2 cables from ip board.
5 Related Answers
Anonymous
  • Posted on May 25, 2009
SOURCE: i have System error E007 problem in my Canon iR-2016 copier machine
System error e007 for canon copier ir2016j copier needs solution
Anonymous
  • Posted on Sep 21, 2008
SOURCE: Troubleshooting, Error Codes
I have problam Canon IR 2016 error message SYSTEM ERROR E 007
Sunil Rathod
  • 199 Answers
  • Posted on Mar 05, 2009
SOURCE: Error E007 canon IR 2016
An error in the rotation of the fixing film is detected.
The reading of the main thermistor is 100°C or higher and, in addition, the fixing film sensor does not detect the rotation of the film for 6 sec or more while the fixing motor is driven.
To clear the error, execute the following in service mode: -
COPIER>FUNCTION>CLEAR>ERR.
to open service mode press star press 2 and 8 key same time then press star again.
Is there a fault in the fixing film edge rotation detection mechanism?
YES: Replace the fixing film unit.
Anonymous
  • Posted on Apr 09, 2009
SOURCE: Canon iR-2016 System erro E007
hi how do solve this problem system error E007
Anonymous
  • Posted on Apr 20, 2009
SOURCE: canon ir 2016 cannot/wont connect to computer via usb
I have a machine it write DOWNLOAD STANDBY.Hw may i do it.
E110 - 0000
Full 'make model (what it is) in ALL questions please.
Error Codes > Canon > i-SENSYS MF8360Cdn > Code E110 ...
printcopy.info > code=E110-0000
Code: E110-0000 · Description: Error in primary pseudo-BD correction · Causes: Scanner failed to be ready after starting up pseudo-BD control Cause: Problem in ...
Error Codes > Canon > i-SENSYS LBP251x > Code E110 0000
printcopy.info > code=E110 0000
Code: E110 0000 · Description: Laser Scanner error · Causes: The Laser Scanner did not become ready although a specified period of time had passed. · Remedy: ...
Error Codes > Canon > iR3300 > Code E110-0000
Code: E110-0000 · Description: The motor ready signal does not arrive within 15 sec after the laser scanner motor drive signal is generated · Causes: The wiring ...
How to solve ir 2202 error e110-0000 - Fixya
www.fixya.com > Forum > Office Equipment & Supplies
Jul 17, 2019 - The main power supply PCB is faulty. The DC controller PCB is faulty. Caution To clear the error, execute the following in service mode: COPIER> ... How do i fix error code E110-0000
Mar. 29, 2016
Error Code: E110 0000 canon lbp3500
Sep. 21, 2016
SOLVED: Canon LBP5970 E110-0000 error solution?
Apr. 22, 2015
More results from www.fixya.com
Ir 7095 showing error E110-0000 - Copytechnet
www.copytechnet.com > ... > Canon
Hi guys, I have been facing a problem with Ir 7095 showing Err E110 -0000, I have tried resetting the error n also clear the mn con but it still dun give any cure, ...
2answers
My canon ir 2016 is showing adjusting waiting to scan after I want to do photocopy Please help me
Dear, check all the ccd flat cables of scanner unit and dc boards back side and replace them which are faulty due to long time which lost the metallic strength for which this issue comes .One flat cable is fitted from scanner lamp unit to its board which is long cable and two flat cables are fitted with this scanner board to back side pcb which are long and another one is connected to two pcb boards at back side one comes from mother board to other board,
In my ir3300 xerox in very light if any setting is there make to dark print?.... what is the setting can u help me ?plz
Check your drum. if drum is ok clean the laser unit and clean the drum unit and chraging roller.
And clean the laser scanner lamp and the Mirror.
You must alert while cleaning the mirrors(Reflectors) don't use thinner, alcohol and stain removers for cleaning scanner lamp and mirror don't do that to movements the reflectors just open the copy board glass and clean with a cotton.
1helpful
IR 400 E220 in Starting Machine
these means that you have problem with scanning lamp or scanning section.
Open the document cover and turn ON the copier, see if the lamp will glow, if not, probably you need to change the scanning lamp, but if it glows and you still has the E220, remove copy glass and put the scanning lamp in home position ( to the left side ) - NORMALLY BEFORE REMOVING THE LAMP TURN THE COPIER OFF AND PULL THE POWER PLUG FROM THE POWER OUTLET!!!!!
Hope that helps!
Canon iR 2016 system error 000 and 003 Machine Serial No.MDA03225
problem `with the fixing unit or power fluctuation try reseting the machine, or call a technician to check your heater lamp, thermostat or the thermo fuse.
Canon ImageRunner 2016 - scanner Not working properly
Ir 2016, can be onlly pull scanner, so that means that you must have installed scan gear, selected in scan gear, and over microsoft word or similar insert scan ( INSERT PICTURE FROM SCANNER OR CAMERA ), but the machine must be in scan mode, put original on platen or dadf, and then "pull it"from PC.
Hope that helped
pls.rate
10helpful
2answers
Canon ir 2016 copier on display says ( Download Standby) thanks
We have a Canon IR 2016 J and in a beginning in the dispaly appears the message "Download Stanby" then after we replaced the PCB board appeared the message "System Error E354" what should we do to solve this problem, and if it is possible to send us the Service Manual with error codes for Canon IR 2016
63helpful
6answers
k24674
ADMIN Andrew
ADMIN Andrew
