Question about HP Photosmart 2410 All-In-One InkJet Printer
On off light keeps blinking
The on off light keeps blinking.  When I turn power off and on it continues to blink and goes through printing a printing cycle.  It then stops and the light continues to blink.  When the light stops blinking you can resume regular printing.
How can I get it out of this cycle, it sometimes stays in this mode for hours.
Dwayne Martin
  • 781 Answers
Try the following:
1. restart the printer spool service in by going into the services applet in the administrative tools section of control pannel
2. check if there's an updated driver for your printer:
uninstall the old driver and printer, reinstall the new driver and printer then test
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&rule=8638&product=303753&
(copy the entire link in the browser address box and hit enter)
post your findings!
Posted on Dec 10, 2008
My tv wont turn on by power button or remote. white light keep blinking.
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/. If the blinks continues, and non-stop, the fault should be with its main system control IC, and with the memory IC.
Dec 14, 2013 | Sharp AQUOS LC-60LE632U 60-inch 1080p LED...
Tip
Resetting Blinking Toner Light HL-2140
Here is the procedure for resetting the Toner flashing light on Brother HL-2140 (sources for other answers here and self testing - specific to HL-2140)
  • Open the front cover and leave open.
  • Turn the printer off.
  • Hold the "white button" while turning the printer on. (All panel lights should be on.)
  • Release the "white button".
  • Press the "white button" 2 times (Pause, wait for all lights to come on.)
  • Press the "white button" 5 times. (All lights to come on again, then go out.)
  • Cancel "maintenance driver" install, if prompted
  • Close cover.
  • Power cycle printer.
This will:
  • reset the toner light (stop blinking)
  • restore the printing darkness (when toner light flashes, printer prints lighter to save toner)
  • keeps the printed page counts and drum life info
on Mar 06, 2011 | Brother HL 2140 Laser Printer
TV won't turn on. flashes a series of 5 red lights instead of turning green
Usually Sony and LG Blinking Codes are the same. Here is what I have.
  • Unit is dead, No blinks - Problem in the standby power section. Might check fuse,
  • Continuous blink once a second, no pausing - No reply from the jungle IC301 (data bus is busy, shorted to ground, or held high), IK video path is defective.
  • One blink - not used for the self-diagnosis
  • Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
  • Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit,
  • Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted.
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. In addition, unit could be in IK blanking, try turning up screen slightly.
  • Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately.
  • Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
  • Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code.
  • Nine blinks - Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing Make sure the regulator is -12 or -13 (negitive).
  • Ten blinks - Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board.
Nov 26, 2011 | LG 42LC2D 42 in. LCD HDTV
Green light blinks continuously, printer will not print. Has always worked well until now. Cartridges are in place, printer has paper, is connected to power and to computer. Is there a reset?
One or both print head are defective.Open cover put out color cartridge then close cover.If blinking stops replace color cartridge.If blinking continues put out black cartridge and put in color.If blinking stops replace black cartridge, if not stop replace both cartridges.If this not help your printer need service.
Oct 29, 2009 | HP DeskJet 3650 InkJet Printer
Keeps blinking. I've shut it off, and cancelled all print jobs - even unplugged it. Keeps blinking. Says there is an operator error
Try this:
1. Turn off printer (use button, don't unplug)
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
If this not help may the print head is defective.
Oct 07, 2009 | Canon BubbleJet i560 InkJet Printer
Sep 29, 2009 | HP DeskJet 3650 InkJet Printer
Kenmore Ultra Wash Dishwasher LIghts are blinking....
I suspect for either of these units that the timer control boards are bad.
Jan 24, 2009 | Dishwashers
Power light keeps blinking and will not print
Just keep pressed the power light button until the light goes off.
Dec 16, 2008 | HP Officejet 5610 All-In-One InkJet...
Brother 2040 all lights keep blinking
Just got the following solution that worked for me:
1. Power Unit off
2. Open front cover
3. Press and hold GO and turn power on
4. When all 3 lights lit release and press GO twice
5. All lights turn solid
6. With all solid, press GO 5 times
7. Ready light GOes red
8. Close door and you're all set
Got it from here:  http://www.fixya.com/support/t612015-print
May 05, 2008 | Brother HL-2040 Laser Printer
HP Photosmart 2410 All-In-One InkJet Printer Logo
373 people viewed this question
Ben Johnson
