Question about PPI DCX-600.4 Car Audio Amplifier
Protect light flashing on and off, sub cuts in and out
My fuses both blew, so i changed them with the same fuses. Once i turned my car on the sub worked but it cut in and out, if it hit harder it would cut out, not as loud bass would play. Also when the sub would cut out the protect light would come on, when they'd play the power light would be on.
  • 160 Answers
There is a wire crossed somewhere in the system or the sub is damaged how old is the amp
Posted on Dec 01, 2008
My protect light is flashing from red to the green power light it makes a thud noise in the sub when it flashes i have checked my ground and power it all seems to be fine does any1 have a idea on what...
You either have a short in your wiring (between the amp and the sub) or have wired the sub(s) at too low of a resistance. If for example you have wired it to 2 ohms, when the amp can only support a 4ohm minimum, the protect light would come on once you tried to turn up the volume a bit. This may happen if you have lost the wiring off one of your subs or one of the voice coils, thereby affecting the total resistance.
Mar 06, 2011 | Jensen LXA300 Car Audio Amplifier
Was loud, now quiet, never changed any setings.
there are many possibilities here:
-one of the subs came unplugged?
-you blew one of the subs
-your amp is over-heating
-some wire has been fried in your amp
-the RCA outputs on your cd player are going bad.
May 09, 2010 | Kicker 06ZX750.1 Car Audio Amplifier
I have 2 kicker cvr12s and a legacy predator 2400 watt amp and when I turn the radio up the amp goes into protection once they hit a decent time. I just down graded from 15s so I know its not a power...
you prolly have the subs wired to a too low of an ohm load...thats what happend to me. i had the same subs, and a 500.1 watt amp...and they still blew up..whire EACH sub to a 4 ohm...that should work.
Nov 18, 2009 | Car Audio & Video
Subs cut out
although an odd thing to have happen it does sound like you blew your amp. check the fuses in it to see if you can avoid having to replace the amp and instead replace a few dollar fuse also check the fuses where you had this pluged in. hope this helps a little. if you give the amp type i may be able to help a little more
Aug 06, 2009 | Alpine MRP-M1000 Car Audio Amplifier
Fuse blew on my lanzar amp and now it won't turn on.
that my find is some am trying to figure out
you say you turn of deck and fuse blow that dont make sense .look at it again
Apr 01, 2009 | Kenwood KAC-7202 Car Audio Amplifier
Changed speakers and now red protect light stays on? why?
the sub might have a short or is blown or the ohms are different
Mar 30, 2009 | Crunch PZi1000.1 Car Audio Amplifier
Protect Light On Subwoofer Cuts Out
some type of over-current protect device in sub amp section gone bad..perhaps a board-mounted resettable circuit breaker or fuse has gone bad? these are hard to locate on the board for a novice.
May 30, 2007 | Verge VGA285 Car Audio Amplifier
Help!!!!
Check your ground wire! Relocate it to another place in the car and try to get a heavier ground wire aswell.
Apr 03, 2007 | Sony XM-2200GTX Car Audio Amplifier
Protect light flashing/ticking
this problem sound like you have too low of power going to your amp, test your battery and make sure its putting out enough power for at least the mininum amount of power that your amp requires, you can find that information in your manual or sometimes they post it on the amp itself. i hope this info helps
Oct 08, 2006 | Infinity Reference 1211a Car Audio...
PPI DCX-600.4 Car Audio Amplifier Logo
164 people viewed this question
Top PPI Car Audio & Video Experts
Jose Velazquez
Jose Velazquez
hoyzee1
Are you a PPI Car Audio and Video Expert? Answer questions, earn points and help others
