Question about Dell E172FP 17" LCD Flat Panel Monitor
Picture is sideways
Upon starting the dell logo and windows xp logo are horozontial a couple of seconds later the desktop comes on all everything is now vertical. Tried fixing, to no avail . I've rebooted, disconnected and re connected theelectric and peripheral wires. I nhave thwe monitor standi9ng sidewaqys to see. Afraid it will fall to the floor.Help
  • 44 Answers
The problem is most likely not with the monitor it is the computer. Some graphics cards have shortcuts to turn the display. Most likely you accidentally hit this shortcut. Most are done with Cntrl/ALT/Delete. Regardless lets get it back to normal. If you right click on the desktop somewhere and select Properties from the box pops up you should get to the display properties. From here select the Advanced button from the settings tab. You should get the Plug and Play display box. Selet the Display adapter tab. Mine happens to be Intel it is usually the tab on the top and takes up the whole length of the box. From this box there should be button for display properties ot something similar. If you check the different tabs in display props there should be a setting for rotation. Set it back to zero. I would deselect the Enable rotation so it does not happen again by accident. I hope this helps. You may find things a different on your PC but this should get you to the right place to fix it. I see this happen a lot. I always disable this on people PC's that I repair for them to avoid calls like this. It is easy to mess up.
Posted on Dec 01, 2008
  • Scott Jelt
    Scott Jelt Dec 03, 2008
    An luck fixing it.
  • Scott Jelt
    try again, any luck fixing it?
    Scholar:
  • 91 Answers
Clarification:
What type of video card is installed in your computer?
Solution:
Go to Start, Control Panel, and look for a 'video' Control Panel icon. My particular one is "nVidia Control Panel". Double click the icon. Take a look at the settings and look for one for the display. Look in this section and see if there are settings that will let you rotate the display.
Please let me know the video card and OS that you are using. Let me know if this has helped. Thank you, Binary Bob
My Dell Dimension 8400 desktop computer using Windows Xp operating system. The monitor shows the Xp Logo at first. Then the screen goes blank about 30 seconds into the boot process. What can I do to g
If you hit <F12> key upon boot-up and the monitor displays a boot menu, then you probably have an issue with your XP software. Meaning that you may have to re-install XP (by the way, XP is no longer supported).
Jan 28, 2012 | Dell Dimension 8400 PC Desktop
RECOVERY FACTORY
Hi there!
Here are the steps to restore your computer to factory default:
Windows XP
- Turn on Computer
- during startup you will see the Dell logo, press <Ctrl> <F11>
- click Restore then Confirm
- let the computer finish starting
Windows Vista
- Turn on Computer
- during startup you will see the Dell logo, press <F8> several times
- select Repair your computer
- select keyboard layout then next
- log-in as local user
- click Dell Factory Image Restore
- Click Next and confirm data deletion
- wait until it finish
Apr 11, 2011 | Dell Vostro 1710 Laptop Computer PC...
Black screen with blinking cursor upon start up
You don't say what Windows are you using.
Anyways, it seems like you have a corrupted BOOT problem.
On Windows Vista and Windows 7, you can insert your Windows installation CD, and choose the "Repair my pc" option.
Windows will do it automatically fro you, and you'll be up and running in a couple of minutes.
Dont forget to rate this answer if it helps.
Jul 18, 2010 | Dell Inspiron 531s Desktop Computer
I want to factory restore my dell dimensions 3000.
There are three methods available.
1) Use Windows XP System Restore.
If you cannot access Windows XP, the following two methods are available.
2) Use the Dell Operating System CD, and the Dell Resource CD.
If you do not have these restoration CD's,
3) Use Dell Restore by Symantec
With this method all personal files you have, and any programs, or applications you have installed, or downloaded, will be GONE.
(Personal Files: My Pictures, My Music, My Videos, and personal files you have created)
Turn the computer on. AS SOON as you see -
www.dell.com, appear in the blue bar, Press -
the CTRL key, AND the F11 key -
AT THE SAME TIME. (Not shouting)
If you do not press both keys at the same time, and in time, let the computer load. It may stop at a blank screen, with a blinking cursor.
It's okay. Now press the CTRL key, ALT key, and DELete key at the same time.
This will restart your computer. Try again when you see the www.dell.com logo.
If upon pressing the CTRL key, and F11 key, you go to the next screen, left-click on - Restore
On the next screen click on - Confirm
Takes about 6 to 10 minutes.
After the restoration has stopped, click on Finish.
Your computer will now reboot.
Should you need help with Windows XP System Restore, or using your Dell restoration disks, please state so in a comment.
Jan 31, 2010 | Dell Dimension 3000 PC Desktop
How to access bios on Dell Inspiron 546
As soon as you turn your computer on, and see the Dell logo, start tapping the F2 key.
If you miss this window of opportunity, wait until Windows has fully loaded, then restart your computer. Try again.
(The Dell logo comes up pretty fast. If you miss entering BIOS Setup, {System Setup is Dell's term}, then as soon as you press the Power On button, start tapping on the F2 key. Tap in 2 second intervals)
http://support.dell.com/support/edocs/systems/xlob/dtg/en/systemse.htm#wp1211139
Jan 23, 2010 | Dell Inspiron 546 MT PC Desktop
No Dell Logo on the LCD screen while starting the computer
I would suggest you to try doing a BIOS default settings
Immediately after you start the computer start hitting F2( or Delete key in some systems), It will take you to BIOS. Just load the default settings for BIOS save settings and exit.
This should resolve your issue
Oct 03, 2009 | Dell Latitude D620 Notebook
15" Dell monitor
You have your video card set to rotate the screen after Windows loads.
Go into your display properties using it's control panel and look for the rotate section. Set it back to 0 degrees. Make sure you click apply and then OK, not just OK.
Apr 18, 2008 | Dell E151FP 15" Flat Panel LCD Monitor
Dell 3000
can you start it in safe mode?
Nov 16, 2007 | Dell Dimension 3000® Pentium® 4...
Dell E172FP 17" LCD Flat Panel Monitor Logo
109 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
