Question about Toshiba Regza 32LV67U 32 in. LCD HDTV
Can't get DVD screen off after ejecting DVD.
The DVD screen says no disc. Can't get to the TV cable screen.
Output button on remote was on wrong setting.
Posted on Dec 01, 2008
3 Suggested Answers
ripleymojica
  • 643 Answers
SOURCE: DVD won't eject
leave tv unplugged overnight. that should reset it.
Posted on Jun 04, 2009
bluenadas
  • 203 Answers
SOURCE: the dvd disc is stuck and won't eject
Bring the unit to a repair center to get the disk out. Trying yourself could ruin the unit.
If you brought it to me I wouldn't even charge you.
Posted on Sep 27, 2009
Is there a way to get the disc out without dismantling the entire TV? Disc is stuck, lock icon shows when eject button is pressed. Can TV be reset to factory specs?
Try the following. kindly update result here in comments
Depending on the model number of your DVD player, simultaneously press the POWER + STOP + EJECT buttons.
If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons.
NOTE: This step may not apply to all models as DISC1 is not available on all DVD players.
If this does not work and if the DVD player has DISPLAY and PREV buttons, press and hold the DISPLAY+PREV buttons for two seconds to unlock the drawer.
Mar 21, 2016 | Toshiba Televison & Video
Coby tfdvd3295-32in720pwidescreen lcd hdtv with dvd player hdmi input
All TVs have a tuner and a set of AV inputs for connecting other sources. A combi TV such as the Coby has one of those inputs dedicated to the built-in DVD drive. Press the Input button to see the list of sources.
The disc can be ejected either by pressing the eject button on the set itself, or possibly from an eject button on the remote if there's one fitted.
Sep 03, 2014 | Televison & Video
Bush tv/dvd combo disc will not eject
the best advice i can give you on this mater is unplug the unit for 10 seconds plug it back in and try to eject the DVD, if this dos not work then the unit has to be dissembled and serviced
Jan 09, 2012 | Bush Televison & Video
The DVD player is in constant eject mode - discs will not stay in to play. It has worked perfectly for years. Tonight I was watching a disc, finished, ejected it and put in another and the player just...
Two possible scenarios: First the optical pick up assembly that read the disc has malfunctioned or the eject button is faulty. Either way it is just cheaper to replace the DVD player with a standalone dvd player connected to one the tv input(s). Too expensive to repair just the dvd player if it is tv/dvd combo. The cost for labor and parts is more expensive these days to repair tvs or dvd player. For around $30 you can just replace...much more cost effective.
Aug 15, 2009 | Sylvania 6620LDF 20 in. EDTV-Ready LCD...
Won't eject disc
I use a produce bag twist tie or a very thin pearing knife. After you push the eject button slide the twist tie in the bottom of the disc slot and the dvd should pop out.
May 10, 2009 | Mintek LCD TV Progressive Scan DVD Player
DVD input channel reads "no signal" when I try to play a DVD
First I would run a dvd cleaner in unit! Second you could take tv apart and look to see if signal cable is loose. the power wire seem fine as it powers up, and accepts an eject dvd.
Feb 28, 2009 | Proscan 32LB30QD 32 in. LCD TV
Dvd player wont play
I found this on the PROSCAN website under customer support manuals.The website is www.oncorpus.com.I hope this information helps you with your problem. IMPORTANT THE LABEL SIDE OF THE DVD MUST FACE THE BACK SIDE OF THE TELEVISION 1. Press the ‘INPUT’ button to select ‘DVD’ mode, if no disc is inserted yet, the display shows ‘No Disc’.
2.Insert a DVD with the printed side facing towards the rear of the TV/DVD Player (see below)
3.The TV will first display ‘Loading’, then change to ‘DVD-video’. Most DVDs will show some preliminary
information then stop at a main menu screen.
4. Press PLAY/PAUSE to play it directly. Or press the DVD-MENU button to access the disc menu during
playback.
5.Use the direction button on the remote control to select the desired option. Press ENTER to select the
option or press the ► button. Playback will now commence.
6.After playback, press the EJECT button on remote control or EJECT button on TV/DVD to remove the
disc.
Note: No function‘’ will sometimes appear on the screen after a button is pressed. This indicates that the
function is not supported at the current time.
Feb 14, 2009 | Proscan 32LA30Q Television
Go Video VR 1940 DVD Recorder + VCR - DVD disk will not eject from slot on top of flat screen TV
My sugestion is to open the dvd player cover, then after you remove it the disc cover you screw out it to remove your disc.
Apr 24, 2008 | GoVideo Go Video DVD/VCR Combo
46w500 hitachi tv-dvd
My Hitachi 46W500's DVD tray will not open. My son about 2 - 3 years ago said he had done something to he tray that may have caused this, is there any way to fix it at home ?
Jan 10, 2008 | Hitachi 46W500 46 in. TV/DVD Combo
Toshiba Regza 32LV67U 32 in. LCD HDTV Logo
100 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
