Question about HP iPAQ rx1950 Pocket PC
PIM ino lost from ipaq 1950
Have a ipaq rx 1950. Tried to use pim from my other PDA - ipaq 2950 as it is the one I use all the time. Put onto SD to transfer, copied across to 1950, overwriting original. Didn't seem to transfer info so did soft reset and now it won't sync with PC or even open calender or contacts on PDA. OOPs!
What do I do now?
Did a hard reset. booted up ok. did activesync with my other PDA onto computer and then sync'ed with 1950.
Posted on Dec 01, 2008
SOURCE:
Does MA5800 support the Multicast?
Yes, it supports Layer 3 multicast networking, also supports IPv4 PIM SSM.
Protocol Independent Multicast-Source-Specific Multicast (PIM-SSM) enables a user host to rapidly join a multicast group if the user knows a multicast source address. PIM-SSM sets up a shortest path tree (SPT) from a multicast source to a multicast group, while PIM-SM uses rendezvous points (RPs) to set rendezvous point trees (RPTs). Therefore, PIM-SSM implements a more rapid join function than PIM-SM.
Different from the any-source multicast (ASM) model, the SSM model does not need to maintain an RP, construct an RPT, or register a multicast source.
The SSM model is based on PIM-SM and IGMPv3. The procedure for setting up a multicast forwarding tree on a PIM-SSM network is similar to the procedure for setting up an SPT on a PIM-SM network. The receiver's DR, which knows the multicast source address, sends Join messages directly to the source so that multicast data streams can be sent to the receiver's designated router (DR).
http://www.thunder-link.com/HUAWEI-MA5800-X7_p928.html
Jan 06, 2017 | Computers & Internet
User Guide for HP PDA
http://h20000.www2.hp.com/bc/docs/support/SupportManual/c00504883/c00504883.pdf heres a link, let us know if you need anything else, more specific like.
Sep 19, 2007 | Computers & Internet
I had to a do a hard reset on my phone.(HTC Touch Pro2) The tech supposedly saved my contacts in a pim file. Now I cant open it. It is showing as pim.menc...PLEASE HELP! Thanks,
hi friend
PIM Backupv2.80
click here to download
Summary: PIM Backup allows you to backup/restore the Personal information of the Pocket PC like Contacts, Appointments, Tasks etc.
PIM Backup allows you to backup/restore the Personal information (PIM FILE) of the Pocket PC like Contacts, Appointments, Tasks etc.
Sollution 2
for PC use Pim manager
Free Download
please rate me
Mar 29, 2010 | HTC Touch Viva Cell Phone
Ipaq h2210 won't sync with desktop
Usually the simplest solution with Microsoft software such as active-sync is to uninstall it and install it again from scratch. When you reinstall it will ask you what programs you want to sync with, your old PIM software has been lowered in priority in favour of Outlook because MS think everyone should want to use it, so it's often easier to start using Outlook as your main PIM.
Aug 13, 2007 | HP iPAQ H2210 Pocket PC
HP iPAQ 210 calendar and contacts won't open
Somehow, the file that stores all of your contact and calendar data got corrupted, and the Calendar program crashed when opening. To fix the problem, rename the pim.vol file on the system root (it's a hidden file; I use Total Commander for file browsing on my device, which shows hidden files by default) to something like pim.vol.bak. You should now be able to open your Calendar, Contact, and ActiveSync again.
I don't know if you are still around and checking this, but it came up at the top of a google search, so hopefully, anyone else who finds this problem will be able to see the solution without having to hard reset their device.
Apr 05, 2009 | HP iPAQ 210 Pocket PC
PIM SYNC NETWORK ERROR on F480 Touch Screen Phone
Samsung are rubbish for this!
You need to go to Menu - Settings - Memory Settings - Clear Memory.
Select Calendar, Tasks and Memo and press ok.
You should now be able to connect to your pc and the sync will work.
Oct 26, 2008 | Samsung Tocco F480 - Pay Monthly Cellular...
PDA Does not go on
Plug it in and use the soft reset. Wait 10 seconds and then turn it on.
Sep 03, 2007 | HP iPAQ rx1950 Pocket PC
Does the DiMAGE 7 camera comply with PIM (Print Image Matching)?
Yes, the DiMAGE 7 is PIM-enabled. The camera records necessary information as it stores every image captured, and passes printing option information to a PIM-enabled printer to create optimum results. The PIM-enabled printers process the image automatically for excellent print quality.
Sep 15, 2005 | Konica Minolta DiMAGE 7 Digital Camera
HP iPAQ rx1950 Pocket PC Logo
151 people viewed this question
Top HP Computers & Internet Experts
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
