Question about Kenmore Dryers
Dryer not heating
My wife dropped a spoon down the lint trap hole on our dryer. I disconnected the power, removed both shields and removed the spoon. After replacing all the shields, I plugged it back in and started it up. It is working, however it is not heating up. I double checked to make sure I did not remove a wire when I took off the shields. Any suggestions.
  • 1 more comment
  • cfd156925 Dec 01, 2008
    Kenmore Model#110.66862501
  • Geoff Siegel
    Geoff Siegel May 11, 2010
    make and model?
SOURCE: Whirlpool Gold Dryer GEQ9800PW1
take a screwdriver and push it in below the door at the top of the bottom panel, near each end of the panel, there is a springclip to pry on that that releases the panel and it will fold out and then lift off. then you can get access by removing a few screws.
BE SURE TO UNPLUG BEFORE WORKING ON IT.
Posted on May 18, 2008
JR JR
  • 116 Answers
SOURCE: check lint screen light on and dryer not turning on
check belt might be broken,,,,
Posted on Nov 30, 2008
rickzilla
  • 706 Answers
SOURCE: Frigidaire dryer, lots of lint getting past screen.
Here is a link to an exploded view and parts list for your dryer. http://www.pcappliancerepair.com/model-display.php
If you are certain that the filter is not compromised or damaged and is properly seated into the housing , you may have a problem with the housing itself whereby lint is getting into the blower thru a break in that housing.. I would examine that area for damage.. and make sure when you reinsert the filter, it is seated all the way down.. Hope this helps you... BTW: over time, it is not unusual for lint to build up in the duct since some of that lint is smaller than the filter media and will work its way thru.. If you are getting that degree of lint build up very quickly then you may have a problem as mentioned above..
Regards,
Rick
Posted on Dec 04, 2008
  • 221 Answers
SOURCE: dropped something in dryer trap
You can gain access or remove the lint trap by popping the top of the dryer up, then remove the front panel.
Posted on Apr 18, 2009
  • 77 Answers
SOURCE: lint fell back into lint trap. how can i get it out? already looked in back.
An appliance store can sell you a brush that is attached to a long wire. It is made specifically for removing lint from dryers. I have seen them at walmart and other places but for sure at an appliance store. Good luck.
Posted on Apr 20, 2009
How do I retrieve a stick dropped down the lint chute?
if there is no water any where I would first use the wand of a vacuum cleaner that is going ( not the head just the pipe section)
Oct 11, 2015 | Dryers
Clothes not getting dry
sounds like perhaps you are losing your heating element...could be electronic, but it's most likely the actual element needs to be replaced...
Apr 25, 2008 | Whirlpool GGQ8831L Gas Dryer
How do you wire the dryer MDE300AYW
Instructions
    • 1 Remove the lint screen from the dryer. If you are unsure how to remove the lint trap, refer to your owner's manual, as removal directions vary among Maytag models.
    • 2 Use your fingers to remove large chunks of lint from the lint screen. You should remove the lint from the lint trap after every load.
    • 3 Run the lint screen under the faucet. Use hot water and thoroughly wet down both sides.
    • 4 Scrub both sides of the lint screen with a wet nylon scrub brush. Rinse the screen again under hot water to remove loosened buildup. Allow the lint screen to air-dry on a towel before putting it back inside of the dryer.
    • 5 Make a paste of powdered laundry soap and warm water into a small bowl. Use three parts powdered detergent to one part water. Stir with a spoon until a paste forms.
    • 6 Dip a soft rag into the paste. Wipe down the entire interior of the dirty Maytag dryer with the rag and paste. Apply more paste to the cloth as needed.
    • 7 Rinse the interior of the dryer with a damp rag to remove the paste.
    • 8 Dry a load of damp towels in the Maytag dryer. Run a complete dry cycle to remove any residue left inside.
    • 9 Wipe down the exterior of the dryer with a rag moistened with all-purpose household cleaner. You can also use the household cleaner to remove certain stains from the interior of the dryer. Make sure the cleaner you are using is noninflammable.
Jan 15, 2013 | Maytag Dryers
Model DLE2301R LG dryer. I think the 15 amp circuit board fuse is blown because th wife dropped a fork when cleaning the lint filter cavity. The dryer made a noise and shut down, she turned the drum and...
check to see if the dryer is getting power, and you will have to open the dryer up and remove the fork, Disconnect Power First. I am assuming that something shorted out, so check the main fuse. Tim
http://www.ehow.com/how_6437684_open-front-panel-lg-dryer.html
http://lgrepair.info/dryer_repair_los_angeles.shtml
Jun 04, 2011 | Dryers
My electric dryer runs for awhile then it just shuts off after about 15 minutes of running? Its a neptune.
a couple of things here may be the problem.. First I would check to make sure my lint trap and the dryer exhaust is not full of lint causing the dryer to heat at a higher temp throwing the high limit switch into disconnect due to the amount of heat generated by the coils. This hi limit switch is a safety device to prvent fires. If you find a lot of lint in the dryer vent or the dryer lint trap, once cleaned, see if the machine doesn't operate like you want. Second. The motor bearings or strator may be going out and the motor is going into thermal overload and shutting down to prevent, as you guessed, a fire. I would check the lint trap and dryer exhaust first since it is more than likely the problem and is cheaper to fix. A wet/dry vac should do the trick. Also remove the back of the dryer to clean out the lint paying special attention to the area around the motor vent which can get blocked causing the motor to over heat. Once these vents are cleared the motor may be fine. Make sure to do all of the above with the dryer disconnected from the power source..
Good luck hope this helped you some
Dave
Jan 28, 2010 | Dryers
The dryer is heating but clothes aren't drying. There isn't much lint on the filter and the inside door and lint area is damp with wet lint spread around that area. It is a MDE5500AY model. Serial...
This just happened to us a couple of weeks ago, and we called a repair man. I might be able to save you $45 for a service call. In our dryer, the lint can fall out of the lint screen and clog up in the back of the dryer. Remove the back of the dryer (you might have to unscrew the lint screen too) and the ductwork inside the back (it's quite easy, I've now done it since my daughter dropped my sunglasses down the lint screen hole) just keep an eye on your screws. Remove the trapped lint, and vaccum out the hose, making sure there's no kinks in the hose as it runs to your house exhaust. Put the dryer back together and see if it works. If not, you've got a fan problem and will need a repairman. But apparently this is the most common dryer problem and will take about 20 minutes of your time to straighten out.
Nov 09, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Combination washer dryer full laundry center does not heat to dry clothes
1) check the lint trap, and reach way into the dryer to remove all lint.2) Look at the dryer motor, and make sure that it spins freely (toys and small objects fall into the lint trap and drop into fan. While there make sure you remove all lint
Aug 29, 2009 | Frigidaire Dryers
Dropped scissors down lint trap dryer won't run
take back off remove screws from fan cover remove scissor...thumbs up
Aug 16, 2009 | Dryers
Dropped something in dryer trap
Apr 18, 2009 | Dryers
Plugged venting causing low heat and poor lint output?
you need to check the dryer vent hole on the back of the dryer,make sure it's not blocked,also check the wall vent for the same thing,most of the time if there is a clogg it holds the moisture in the dryer and it take forever to dry,you can use a shop vac to **** out any clogged lint in dryer and wall ,then if you have a leaf blower put it on the wall side and blow it it all out.let me know how you do-mike
Oct 30, 2008 | Dryers
Dryers Logo
50 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
