Question about Sharp Microwave Ovens
My sharp microwave oven sparks and pops when in use.
It doesn't do it all the time. It is only a year old. It sparks like there is metal in it, but there is not.
  • 78 Answers
1. You have to clean m/w inside from all kind of grease and food resedue.
2. Inspected m/w cavity inside and clean all burning spots with sand paper.
3.Apply touch paint on this spots.
Different color touch paint you can buy at any appliance patrs store.
I’m happy to help further over the phone at https://www.6ya.com/expert/vitaliy_f406165329c75ede
Posted on Dec 01, 2008
Sparking
The magnetron is arcing or bare metal is exposed on the interior, since it is under a year old your item should still be under warranty.
Jul 24, 2012 | Microwave Ovens
Sharp R-405H microwave turntable doesn't rotate and makes strange noise
Replace the turntable motor, it is defective and will only get worse.
Mar 17, 2012 | Sharp R-405H 1100 Watts Microwave Oven
Sparking all the time I turn it on. Stopped using it. Help
That's a worn out waveguide port cover. You'll need to replace it.
Years before the internet took off my Sharp R-9A20 had the same problem, I didn't have Amazon.com so I went to a shop that fixed vacuum cleaners, microwaves, etc. He had to grab a sheet of special cardboard and cut it to emulate the old one.
Don't use oven cleaners that aren't microwave safe. They eat right through the metalic coating on the port cover that keeps the microwaves from reflecting back into the tube, I suspect that's what is up.
Sep 13, 2011 | Sharp R-1490 Microwave Oven
A number of days ago we put two plates of food in the microwave to reheat them. There was a snap, crackle, pop noise. We checked to see there was no metal object in the unit....there wasn't ...we know...
Are you sure the plates were Microwave oven safe? Some dishes have metal in the colors of the design. A snap, crackle, pop noise normally means there is metal present in the oven.
Jun 05, 2011 | Microwave Ovens
Sharp r1214f sparking New issue sparks with microwave popcorn, butter and microwavable ice cream.
the container of these items probably contain some metal which doesnt go with the microwave
Jul 19, 2010 | Sharp R-1214 Microwave Oven
Sparks are coming from the bottom of the microwave
generally the microwave will only spark if there is metal on the container you are cooking with or you are operating it without anything in it. as it is that old and with all the advances they have made with microwave ovens ... if it is in the budget i would certainly suggest getting a new one
Jan 17, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Sparks pops odd burned smell
I would certainly take it to a repair shop if you want to try and salvage it. Until then keep it off and unplugged.
Feb 14, 2009 | Frigidaire PLMV168 Microwave Oven
Dacor Microwave
Quite often this is due to grease or food particles stuck to the inside of the oven or stuck on or behind the waveguide cover.
The waveguide cover is usually about the size of a playing card and often held in place by a plastic rivet.
It can be fragile, and the metal edges of the oven behind it can be sharp, so be careful!
The cover and the metal behind it should be cleaned with a mild, non-ammonia cleaner.
If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
If your waveguide cover is burned, it will need to be replaced.
The part would be much cheaper if you get the Sharp version (these ovens are made by Sharp) instead of the Dacor branded part.
The model DMT2420 is essentially the same as model R440D / R540D.
The Sharp part number is PCOVPB085MRP0 (zero on the end) and you can order Sharp parts from Tritronics at http://www.wehaveparts.com
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 17, 2008 | Dacor DMT2420 1200 Watts Microwave Oven
Sparking / Popping Microwave
GE had a rash of "underperforming" magnetrons on these units. They replace the magnetron, stirrer and high-voltage diode at no charge for parts as long as a GE-authorized service center does the work. Sometimes the unit gets run too long in a failing state and the waveguide and chassis of the oven get damaged. To see if yours is covered, see this bulletin: http://www.microwavedisplay.com/ge_mw_mag_kit_bulletin.pdf Otherwise, you need to contact GE Customer Relations at 1-800-386-1215 as soon as possible and tell them your problem and they will put you in touhc with a local authorized servicer.
Apr 01, 2007 | GE JVM1650 1000 Watts Microwave Oven
Microwave Ovens Logo
237 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
