Question about D-Link AirPlus Xtreme Super-G DI-624 Wireless Router (di-624/b)
Lights are solid green: WAN, local network 1,2,3,4
I have model # DI-624 and just recenlty I am getting all solid green lights on WAN and Local Network 1,2,3, and 4.
The following lights don't turn on when the unit is connected: Power, Status, WLAN. It doesn't allow me to connect to the internet. Please help. Thanks.
  • D-Link Master
  • 6,487 Answers
If that is status of the lights on your router there's a big possibility that its already bad and needs a replacement, but you can first try to reset it and check if that will correct the problem
, To reset the router just press and hold the reset button for 30 seconds while the power is ON then after that check if the lights are back to normal if still the same light router is already bad...
Posted on Dec 01, 2008
Nothing works whit the d-link
seems like it gets stuck while its booting the config and stays that way. How are you resetting your device? Try to hold the reset switch for about 5 seconds and then all the lights should flash. At this point disconnect the power cord and let it sit for about 10 seconds. Power up the device again.
Apr 12, 2010 | D-Link AirPlus Xtreme G DI-624 Wireless...
Router won't connect, reset doesn't work?
If there's nothing in the manual about this condition, I hate to say it, but it sounds TOAST.
If it's any consolation, nothing you stated you were doing could've been the cause. Either it was gonna blow anyway or you had a power surge, something...
If possible (in its current state) like with SFTP etc., and you're SURE this condition isn't normal - through the manual, the website, forums and FAQs on the site and elsewhere - you may as well try to reFLASH it before you throw it away.
AND, (if it does have SFTP FLASHING or another "unattended" process, I would actually STILL have quite a bit of hope at this point. (even 33% or so)
And in 1 more step it will either be 100% good as new, Hallaleuah, brought BACK FROM THE DEAD, amen OR it'll be about like it is now, huh?
GL!
Aug 24, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
My D-Link Xtreme G DI-624 worked quite well for 5 days -- then failed to connect with Internet while I was using it 2 nights ago. "Network Connection Disabled" was the message. Can you tell me which cables...
From modem's ethernet, connect the wire to the router's Internet/WAN port. From your PC, connect the wire to port 1 of the router. If it says network connection is disabled, right click on Local Area Connection and click on Enable.
Jun 04, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
I can't connect to the internet or router, only wan and 1-4 local network lights up
Check the power cable,try to connect it to a different power socket.
Change the powercable and check whether the power light is up
if still the same problem then it should be the hardware issue.
Contact the manufacturer or service provider if it is under warrenty
{If it is connected through USB and getting power from the computer itself then uninstall and reinstall the USB software}
May 26, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
Ok i do all the set up right when i turn off my dsl modem the turn it back on it says i dont have internet and wen i plug it in normaly it works i have the d-link di-624 air extreme ....i dont kno why does...
You need to power cycle your devices. Make sure the modem is connected to the WAN port of your router and your PC to port 1. Unplug the power to the router and modem. Wait for 30 seconds. Turn on the modem first, wait for the lights to be solid, then turn on the router. That should do it.
Apr 02, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
My D-Link AirPlus Xtrame G is dead
Your power adapter may be dead, check the power connector with a multimeter to see if you have the correct voltage as per the label on the adapter. If not you may only need to buy a power adapter.
You may be able to borrow another adapter with the same voltage and current rating and plug it into your D-Link and if you get a POWER and STATUS lights it proves you have a dead power adapter. If you don't get any lights then it looks like your D-Link is dead.
Nov 25, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
DI-624 problem with wireless network
Buy the N router! That is the only solution. My signal weakened and went from the whole home to less than two feet if that at times. I bought the N router and it worked just like the G one did when I first bought it. Ya think somebodies got the limited life span worked out?
Jul 10, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
I need to configure my d-link for wow downloader
To configure D-Link DI-624 Wi-Fi access point to work with BitTorrent you have several options. One of them is to use trigger ports.
Steps to follow:
  1. Open web control panel of D-Link DI-624 by connecting to http://192.168.0.1 (this is default direction, which can be changed by administrator).
  2. Enter login and password for administrator. Default login for administrator is admin.
  3. Go to Advanced, select Applications.
  4. In Applications screen:
    1. Check Enabled.
    2. Fill BitTorrent in Name.
    3. In Trigger Port put 6881 and 6999.
    4. In Trigger Type select TCP.
    5. In Public Port put 6881-6999.
    6. In Public Type select TCP.
    7. Press Apply.
  5. The DI-624 will reboot.
Now you can use BitTorrent from any computer on both LAN and WLAN local networks in automatic way.
BitTornado Setup If you use latest experimental BitTornado client you can give a good use toUniversal Plug and Play (UPnP). You just need to enable UPnP on D-Link DI-624 and BitTornado will work on any computer in your local network without any requiered intervention from your part.
In BitTornado:
  1. Run BitTornado
  2. Click on Prefs
  3. Locate UPnP Port Forwarding and select type1 (fast)
In DI-624:
  1. Log in as administrator
  2. Open Tools (main menu)
  3. Select Misc. on the left
  4. Locate UPNP Settings and select Enabled
Jun 30, 2008 | D-Link 802.11g Wireless Router WBR-1310...
Dlink Di-784
You can try to reset your Router by using a pen or a paper click there is a little whole in the back of your router that you can click with a pen. This should restart the modem. If this doesn't work you can hold the reset button but this will restore the router to factory default settings
Jul 05, 2007 | D-Link (DI-784) Wireless Router
WAN settings
The WAN settings should be configured by Verizon personnel only. If you reset the VDI-604 or VDI-624 to factory defaults, you will need to contact Verizon to reconfigure your WAN settings.
Feb 16, 2006 | D-Link AirPlus Xtreme Super-G DI-624...
D-Link AirPlus Xtreme Super-G DI-624 Wireless Router (di-624/b) Logo
628 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
