Question about Amana ARGS7650SS Gas Kitchen Range
Amana ARGS7650 Keypad has no power
The keypad on the Amana ARGS7650 has been working for about 10 years, until now. There is power to the pilot electronic ignition and the oven light, but the keypad controlling the clock, oven temp, timer, etc seems to have no power. Is there a fix for this?
  • mjoc Jan 04, 2009
    I have the same problem. AMana Gas Range ARGS7650LL is the model. The touchpad just stopped working. Rest of the stove works just fine. Now I can't use the oven, because I can't use the touchpad. Do I need a new one? How do you open the stove top to get at it?
I had the same problem, same model. The electronic panel has to be replaced. This part is ~$215 before tax and shipping. With labor, I was looking at over $400. I bought a 4 yr old used GE gas oven for $75. That was my solution.
I believe the part to replace is labeled Erciii, gas
Part Number: AP4041311 made by WHIRLPOOL
This would have taken at least a week to ship (no one seems to have them in stock).
From now on, I will never own a range in which the oven or stovetop controls are electronic. Knobs and associated mechanics can be replaced MUCH more easily and cheaply!
Posted on Apr 06, 2009
What ge gas oven was purchased for replacement part
Posted on Aug 01, 2009
My amana model number amv1150vas is not working after a power outage
Unplug for 60 seconds to see if it will reset, if no! the fuse in the microwave has opened/ or if the model is the new type, it is the keypad control board or smart board.
Apr 05, 2012 | Amana Microwave Ovens
My Amana ARGS7650
Turn the power off to the range.
If you have the duel fuel model, remove the burner knobs and remove the screw behind each knob.
Open the oven door and reove the four screws that hold the bottom of the control panel to the range.
The panel should pull out and down at the bottom.
You will probably find the ears that hold the board have broken. Some of these models only used two screws to hold the board to the panel, which left two ears that you can put the screws in to fasten it back in place. If all four ears are broken, I have used flat washers under the screws to fasten it back if there is enough of the ear left for the washer to catch.
Oct 16, 2007 | Amana ARGS7650 Electric Kitchen Range
I have a Lynx system with a 5828 wireless keypad that I have connected a 5v transformer to it to keep the keypad lit always. The keypad does not stay lit always and it keeps going to sleep after 10...
It sounds like your 5V transformer isn't working. It could be the outlet it is plugged into isn't working, or the outlet is on a light switch that is turned off, or there is a problem with the keypad itself. The user manual says:
"AC-Powered Operation: When powered by the
optional AC adapter, the keypad remains active at all
times. If AC power is lost, the keypad reverts to
battery-powered operation until AC power is restored
On AC powered units you can get the status by viewing
the display."
The only way I know of to keep it active is by using the transformer.
Hope this helps.
Mar 22, 2011 | Ademco 5828 Wireless Keypad Lynx / Vista...
I have a Craftsman opener with security plus (18 months old-blak transmitter button) and the wireless keypad will open the door by simply hitting enter (no code required). I would assume it had to be the...
Opener can be closed by pressing only the ENTER button if the One Button Close feature has been activated. This feature has been activated at the factory. To activate or deactivate this feature press and hold buttons 1 and 9 for 10 seconds. The keypad will blink twice when the One Button Close is activated. The keypad will blink 4 times when One Button Close is deactivated.
Aug 02, 2010 | Sears Craftsman LiftMaster Chamberlain...
Amana adb1500aww3 dishwasher will not turn on
amana dishwasher keypad has power BUT lights are dim and will not work. tried doing a rest and nothing.
Feb 27, 2010 | Amana 24 in. ADB1500AW Built-in Dishwasher
My Nokia 5200 (Number keypads) will Not Working
u need to change the key pad until then it wont work.
two keypad IC's under the keypad and next to the keypad connector unfortunately all the keypad points are linked to the IC's and so even if one key doesn't work it is related to these IC"s in question UNLESS the keypad connector is dirty or sticky please do service your phone or take it to a reliable technician
Jul 01, 2009 | Nokia 5200 Cellular Phone
Moved oven. Keypad can not set time. Amana RRL 9TC
After so many years, the electrolytic filter capacitors dry out and these become more susceptible to disruptions and glitches.
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, I would say your control unit (called the "net module") needs to be repaired or replaced.
If this item is available anywhere, it may take several weeks to get and will likely run well over $150.00.
If you decide to look for parts, the proper model number format is RRL-9TC and it also has one of four manufacturer numbers on its tag: P7553302M, P7553303M, P7553304M, or P7553306M.
Be sure to have both numbers handy.
The original part numbers for the net module seem to have been R0163049 and then R163079A.
Good luck.
Feb 02, 2009 | Amana AMV5164 Microwave Oven
Clicker garage door keypad works inconsistently
no relation. did you plug rpm sensor and logic board connectors on well.
Dec 11, 2008 | Sears Craftsman LiftMaster Chamberlain...
Uniden cordless model DC7758-4
Does the Uniden cordless phone model DC7758 have an answering machine?
Sep 30, 2008 | Uniden Cordless Phone
Amana gas range ARGS7650 oven not working, stove top working
check clock has not accidently been switched to Auto this can also happen if someone has interupted the power supply
Dec 25, 2007 | Kitchen Ranges
Amana ARGS7650SS Gas Kitchen Range Logo
839 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal DeAngelo
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
