Question about Gateway MX3215 Notebook
My gateway mx3414 keeps overheating and will just turn itself off. It sometimes won't even turn on because of getting too hot.
  • Anonymous Dec 16, 2008
    I've been having the same problem with mine for some time now. I went to their support site for possible new drivers..etc. None to be found that I don't already have. When i run speedfan it shows the gpu/proc temps being off the charts while my laptop is just idling doing nothing. Cooling pad..helps some but not much. My advice..this series of laptop is junk. Gateway makes products and then quits supporting them. Go buy yourself an HP and smash your mx3414. As soon as I get a new laptop I plan to do just that ;)
    Problem Solver:
  • 12 Answers
Take a look at this link http://www.laptops-we-r.com/NEW%20WEB/images/M210.3000%20SERIES/MX3701%20HEATSINK%20B1425028G00001%20.JPG
That is the cooler for the 3414/3417 (which is the model I have). I was having a similar problem with heat, and since mine is way out of warranty, I became irritated enough to open it up and see if some silver thermal paste might do the trick. What i found amazed me. The bottom of the case has no ventilation at all for the processor fan! if you look at the bottom of the case there is a vertical opening next to the wireless access door. That is the only intake even close to the processor fan. I took the heatsink off the motherboard, lapped it and replaced the thermal pads with arctic silver 5. i also added a couple of very thin foam pads to the bottom of the hs fan to keep the 1/8" (or less) clearance between the bottom of the case and the fan opening from closing up if pressure was placed on it. Temp is idling at 41c to 43c, and the fan actually cycles on and off now. I am going to purchase a new bottom shell for the latop and mod it for better airflow. Once I finish it up ill post a guide to show how to open the case up and replace the thermal goo with a better product. Very poor design on gateways part.
Posted on May 06, 2009
Eteirk, I have the same computer wit hthe same problem. Can you tell me how to open the case up? You said you'd post a guide saying how to do this...
Posted on Sep 28, 2009
  • 3 Answers
Get a can of compressed air turn off the laptop and blow the dust bunnies back through where the air exhausts out through the heat sink.In simple terms the fan blows air through the laptop and out. it picks up dust and gets plugged. you need to blow the dust back thru the oppisite way. once this is done it will run cool again. Have fun! turbotim53
Posted on Feb 14, 2009
  • 29 Answers
Most laptops will start to run hot if not used in properly ventilated conditions, by this I mean that the laptop is sitting on a smooth flat surface, which will allow the small fans installed in the laptop to run as they should.
If the laptop is being used directly on your lap or on a pillow, bed, or anything that will obstruct the airflow in or out of the small fans, it will get hot and either shut down or In worse cases just crash with costly fix-up/replacement cost afterward.
One way to keep this from happening is to use your laptop on a desk or small table. Another option is to purchase a laptop/notebook cooler like the one in the link bellow ( http://www.amazon.com/Antec-NOTEBOOK-COOLER-USB-Powered-Notebook/dp/B0000BVYTV/ref=pd_bbs_sr_1?ie=UTF8&s=electronics&qid=1228098566&sr=8-1 ). You can usually find these for under $20, I got the one on the link for $11 as a Black Friday deal. Anyway this thing plugs into your USB port and pretty much creates an airflow that moves away hot air faster and brings in cool air faster to keep your laptop running smoothly.
Posted on Dec 01, 2008
How much does a gateway mx3414. W34oua cost
This laptop has been discontinued it's not for sale as new, a used one is whatever you will pay for it. What ever the market will bare. Depending on condition. It's old technology , but should work fine for some applications and could be upgrades to a degree. Here are the Specs: http://www.cnet.com/laptops/gateway-mx3414-14-1/4507-3121_7-32064868.html I use a Gateway MX 6421 with added 2GB's ram, 7200rpm HDD, Windows 7 64bit Pro N. It works quite will for what I use it for. It has it's limitations.
May 29, 2013 | Computers & Internet
I have a mx3414 gateway notebook with a backlight that turns off after a few seconds.
Step 1:
Rather doing a driver hunt which can take hours http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html Windows XP/Vista/7/8
it might take some time being a freeware driver solution Note: it will find all of your outdated drivers
This will automatically search for and find the correct driver you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point.
Click no to both of these then continue updating each driver free then restart once all of the drivers have been updated.
Feb 08, 2013 | Gateway MX3414 Notebook
Gateway mx3414 wont start, battery red lifgt flashes
Check the voltage to the power box with a volt meter. If it reads the exact current needed as labeled on the power control box you need to replace the battery instead. A dead cell is the most common problem causing this for your computer
Jul 17, 2010 | Gateway MX3414 Notebook
My mx3414 gateway went dead
There is a 15 pin VGA connector on that model so plug it in to an external monitor or an LCD television and see if you have video or not. If you do, then you need to check the LCD power inverter which converts the AC power from the wall to DC power. Since you had a power surge this would be the most likely trouble spot. If there is no video, the likely culprit is the video card.
Jun 22, 2010 | Gateway MX3414 Notebook
2 wieless router keeps turning off by itself
maybe overheating, move to a cooler place eg near floor
Mar 21, 2010 | 2wire Wireless-G 802.11g ADSL Gateway
Gateway laptop mx3414-black screen cannot load windows
Try going into safe mode upon startup by hitting the F8 button. If it does then hit safe mode to get into your computer. Go to start>accessories>system tools>system restore. Follow the wizard to restore your computer to a date earlier than when you started having problems. Let me know if you have any problems or questions.
Mar 19, 2009 | Gateway MX3414 Notebook
Gatweay mx3414 dont start
try removing mem and removing hd check to see if clean re seat them and reboot,
could be bad sectors on hd,but sounds like unit been knocked or dropped and hd not seated properly...
Jan 14, 2009 | Gateway MX3414 Notebook
Overheating
Overheating is a big issue with Gateway. It mostly involves problems with the fan. When Gateway receives a warranty fan problem they replace it with a fan that is reconditioned or rebuilt (probably from another cutomer's unit like yours) and they don't seem to last long. To make sure it is a fan problem, which is the most common, Turn on the laptop and wait to see if the fan is turning on. It won't take long, processors get hot quick. The fan should turn on and run anywhere from 3 to 15 seconds then turn off. It should do this approx every 5 to 7 minutes in order to keep the processor cool. If it doesn't work at all, works seeming sporadically, or the processor gets really hot before the fan starts, then it's a fan problem, and a NEW fan should be purchased. If the fan works properly, then it could be that the fan and heat sink need to be cleaned internally due to dust build up.
Jun 20, 2008 | Gateway MX3228 Notebook
Gateway MX3215 Notebook Logo
977 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
