Question about Frigidaire FEX831CS Top Load Stacked Washer/Dryer
Washer and Dryer
I have a combo/stackable washer and dryer in my apartment. I used to be able to move or slide my washer and dryer to get out of my back door but now it seems like it is so heavy, I think it is full of water but the water is not in the tub of the washer. I have always kept my drain hose on the top of the dryer when I am not washing so the drain hose is always up. I was wondering could that excess water be sitting somewhere in the washer? (it sounds like water is in there, but cant drain it from the hose) If so how can I get it out. Can I tilt it or lay it down or something? Frigidaire Model # FLXG52RBS8.
Thank You,
Vera
    President:
  • Frigidaire Master
  • 2,651 Answers
There will always be water inside he machine(between the tubs, and in the hoses, but no so much to add that much weight so you cant move it, i would look to see of perhaps a levevling leg has hit the floor not allowing you to slide easily.
Posted on Dec 04, 2008
How do I lift up or remove the top cover to a stackable maytag washer-dryer combo to get to the screws holding the small baffle?
The top panel is attached with 2 or 3 screws into the rear edge of the top panel. Remove the screws and slide the panel to the rear, then lift.
Feb 20, 2017 | Maytag Dryers
Need to replace belt
Search Results
    How to repair a KENMORE double decker washer&dryer ...
    ? 4:59
    www.youtube.com/watch?v=Rc_ZGugYBTY
    May 31, 2014 - Uploaded by MrProductionist
    How to repair a broken dryer belt from a Double Decker Washer and Dryer. ... I have a Kenmore stackable Washer-Dryer, and the dryer belt is ...
Oct 21, 2015 | Frigidaire FFLE1011MW White Washer/Dryer...
I have a stackable Frigidaire washer/dryer combo and the problem is that when you push the start button, you hear an electrical buzzing but the dryer won't start. When you take the panel off it st
Hello Mike Brady - From what you have described it seems like the dryer is experiencing a wiring failure or a communication error with the control board. Contact a professional to move forward accurately.
Jan 08, 2013 | Frigidaire FEX831CS Top Load Stacked...
It is not really a problem. I am wondering if I want to transport our stackable washer/dryer ...(moving it to our cottage) can it be flpped on its side? or will this do it some damage? Can it be taken...
Good Morning; Thanks for your question. The easiest way to move and transport your unit, is to separate them. Go around back of the unit. Where the top unit sits on the bottom, there are two lockdown brackets, one on the right and one on the left. Remove and save. Slide top unit back until front feet are released from front brackets. Then you can lift off. Note, it probably will take two of you for the lifting. It is best, that you not lay them on their sides. Hope this helps and have a good day.
Jan 28, 2011 | Kenmore 98702 Stacked Washer/Dryer
I have a stackable washer and dryer. Both have worked fine except recently clothes started getting caught between the drum and the front frame of the dryer. My husband pulled it apart checked the screws...
You may have a felt seal in the front that needs replaced. A wire off the pin switch could be off, and you will see the pin switch when you open the door, and make sure it is clicking.
Jun 22, 2010 | Kenmore 63942 Dryer
Water under stackable washer dryer
The front panel comes off and you will be able to trace the water source. These combo units spin immediatly and if the drain is slow the water will spin up over the edge of the tub during drain.
Eric
Dec 24, 2009 | Kenmore 98702 Stacked Washer/Dryer
Frigidaire FEX831CS Top Load Stacked Washer/Dryer Logo
170 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
