Question about Memorex MT2245 TV
Poor speaker quality - distorted Memorex mlt1912
This TV is only about 6 months old - but left speaker is "distorted". Can the speakers be replaced?
  • meekmom Dec 21, 2008
    thanks - I will try this and get back to you!
  • debbiemms Dec 23, 2008
    I have the exact same problem.  Did you find out what to do?
  • 121 Answers
Yes speakers can be replaced. but more likely tobe circuit prob if your handy you could switch speaker wires. to ck.
Posted on Dec 04, 2008
Terrible sound, sounds like speaker blown. Got it 2 days ago.
If this is a "new to you" TV, keep reading. If it is a brand new TV, I'd be on the phone to the store to have a replacement ready for delivery / pick up. You do not want to be repairing a TV that is 2 days old.
The first thing to do is determine if the distortion is coming from the speaker or if it is on the signal going into the speaker. Do both speakers sound distorted or only one?
You didn't include the model number of your TV, so I can't speak to specifics. Look for a terminal on the rear of the set identified as "speaker" or "external speaker". If provided, there will be one set of terminals marked for the left and one for the right external speaker.
Connect a speaker directly to the terminals marked for either the left or right speaker (connect to the one that sounds distorted if only one of the built in speakers works correctly - other wise pick either speaker terminal pair.). Speakers that have RCA plugs on them, have built in amplifiers, require batteries or or to be plugged in to an outlet should not be connected here.
Alternatively, you could connect a pair of stereo headphones or earplugs if your TV offers a jack for them. It would have a headphone icon or say "phones" above the jack if one is provided.
Once connected, turn the TV on, lower the volume and set the TV to enable the external speakers / disable the internal speakers. This may be done via menu item selection or a small switch near the speaker terminals. Slowly increase the volume to listen to the quality or clarity of the sound coming from the speakers you connected. If they sound distorted, the problem lies with the audio amplifier in the TV. If they sound OK, then there is a problem with the speakers in the TV.
If you can't return the TV, you may have to see about using the left and right audio line out or HDMI jacks to send the audio to an external amplifier and speakers to hear the program.
I hope this was helpful and good luck! Please rate my reply. Thank you.
Apr 06, 2011 | Sanyo 42 in. LCD TV
The left speaker of my denon s-301 makes short loud distortion noises.
Try unplugging the right speaker and plugging the left speaker in the right port. If the speaker still sounds distorted then you know you have a brocken speaker. If it sounds normal then we know its not the speaker.
Sep 25, 2010 | Denon S-301
Left speaker sound is distorted can Ireplace one speaker
Yes, you can check left speaker by replacing it or by interchanging with the rightside speaker. If the speaker is okay, then check for faulty amplifier circuit board. Don't forget to check the dirty EP socket or banana pin for leftside speaker.
Sep 22, 2010 | Logitech Z-2300 Computer Speakers
My left speaker is loose
The symptom you are describing is exactly what is known as a "BLOWN" speaker or the voice coil has "shorted", this is caused from the volume being up to loud, heating up the voice coil and frying it, in the future if the bass/sound is distorted then turn the volume down just enough to stop the distortion and this will save the speaker.
As far as getting a replacement speaker, you will have to contact the manufacture to get a replacement.
Good Luck !
Apr 21, 2010 | Philips FWC577 CD Shelf System
Distortion using rear speaker interfaces.
yea get new speackers or u have a very low quality wire also can bet out of eq
Apr 02, 2009 | Pioneer VSX-1018AH-K Receiver
My old Samsung CRT TV has strange blue dots on the top left corner. Is it because it's next to a speaker? when I move it the dots go away after a while.
Yes, speakers will cause the picture to magnatize amd will cause this distortion. Keep the speakers at a distance to prevent this from happening.
Apr 28, 2008 | Vacuums
Westinghouse 47" hd lcd 1080p
It does not need to be a blown speaker to be causing the problem. The issue (unless you have a habit of running the TV at maximum volume) is more then likely in the audio circuit of the TV.
Since it is only 6 months old, I would be straight onto Westinghouse to have it repaired under warranty.
Apr 14, 2008 | Westinghouse LVM-47w1 47 in. HD-Ready LCD...
Colours on the tv have become distorted particularly black which now has a reddish orange smeared appearance. Problem seems to get worse as the day goes on. Tv is only 7 months old.
The TV is getting magnetize, may be from speakers nearby or any other source. The degaussing circuitry is not functional.
If the TV is only 7 months old, I would say still under manufacturers warranty.
Call the place where you bought it and ask them for an authorize repair center to fix it.
Mar 04, 2008 | Televison & Video
Alesis RA500 amp - channels crackle, distort, cut out
you have a problem in output stage and output ic need to check or replace.
Jan 27, 2008 | Audio Players & Recorders
Memorex MT2245 TV Logo
78 people viewed this question
Top Memorex Televison & Video Experts
 Grubhead
Grubhead
Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
