Question about Acer Aspire 5100 Notebook
Aspire 5100 notebook error
When i boot my computer it gives me a rescource conflict on pci in slot 3 i thought it was my wireless card. but i removed it and still get same error
  • Acer Master
  • 4,806 Answers
Look in device manager and you will find out what the conflict is, all you have to do is choose available port you want and change it that will sort the problem.
kind regards and please don't forget to rate us
Posted on Dec 01, 2008
Bus: 06, Device: 01, Function: 00 ERROR Resource Conflict - PCI Network Controller in Slot 02 Bus: 06, Device: 02, Function: 00 ERROR Resource Conflict - PCI in Slot 03 Bus: 06, Device: 04, Function:...
I would firstly reboot and if that doesn't clear the error run asc.setup utility to remove crosslinked files and sort out a crosslinked registry. Failing that remove the driver from the Control Panel and let the OS set up a fresh driver. Make sure the driver is the correct one!
May 02, 2011 | Acer Aspire 5100 Notebook
When starting the laptop acer 5100 it tyries to start and it shows the following Bus 06, device 02 ,function 00 error resource conflict pci in slot 03 bus 06 device 04 function...
If it just started doing this all of a sudden, then it is a good bet that *********** board is fried. If you just installed some memory or a communications card or new drive, then take it out and see if it still does it. If not, check the installation instructions to make sure it was put in right.
Sep 08, 2010 | Acer Aspire 5100 Notebook
My laptop wil not boot. Not even in safemode . It has wndows xp that i had recently put on there.. its been doing this for a min but it would come on after a few tries.. This is exactly what happens when i...
Hello Karen
Try removing and resetting your memory modules.
Blow some air in the slots to remove any dirt trapped in there.
They are locate don the back of your laptop.
The instructions are in the manual under how to change or upgrade memory modules.
Please don;t forget to rate this answer if it helps
Jul 22, 2009 | Acer Aspire 5100 Notebook
Aspire 5100 resource conflict - pci slot 3
Yuor RAM memory conflicts with each other check RAM memory fix same frequency memory into laptop.
Thanks for using fixya.
Jul 20, 2009 | Acer Aspire 5100 Notebook
Pci slot error
I have the same problem with an Aspire 5100.
I can eliminate any problems with the software, as the problem exist with the hard drive renoved.
It appears after the 'Acer' splash screen and fails as part of the POST.
After reading through various posts I suspect the broadcom wirless card or LAN has failed at board level.
I will try removing them and try again.
Will post back with results.
Jun 10, 2009 | Acer Aspire 5100 Notebook
Acer aspire laptop wont boot
y dont u dispose it off if it is a problem computer, i guess it is a generic problem of laptop need to replace motherboard or so. avail warrent if it has...
Nov 25, 2008 | Acer Aspire 5100-5033 Notebook
Hi akwasi,
Try pressing F2 and look in the bios for a setting that says "Load Bios defaults". If you have any PCMCI cards inserted please remove them first and try a re-boot.
Have you added any new components on the PCI bus? If you have you need to make sure that the BIOS is allowed to reconfigure the interrupts. The device in slot 03 is conflicting with the integrated network controller hosted on the PCI bus. Remove the device in slot 3 and all should be well.
Most BIOS manufacturers allow the PC/Laptop to manage it's own interrupts, so ensure the device you've inserted allows for this. If it uses fixed interrupts this might be your problem.
A good manual should details the BIOS setting you can adjust in order to get the PCI controller happy again and allow the machine to POST correctly.
Spare head 2
Jan 04, 2008 | Acer Aspire 5100 Notebook
Windows will not boot
Just turn-off network boot in your bios
Nov 15, 2007 | Acer Aspire 5100 Notebook
Acer Aspire 5100 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
