Question about Canon PIXMA iP2000 InkJet Printer
Canon pixma iP2000 no yellow will print
I have gone through all of the option -clean,deep clean, etc
new ink and it prints perfect on the test but no yellow
  • adeane Jan 16, 2009
    I have the same problem with the magenta, please can sombody help as I cannot aford to buy a new one.
I purchassed a new cartridge and it worked
Posted on Feb 02, 2009
Have you tried cleaning the ink pads on the print head using a can of compressed air and blowing from the inside outwards, taking the print head off first. You can usually buy a tin of compressed air in somewhere like PC world.
Posted on Dec 16, 2008
Why is my Canon Pixma 4820 suddenly leaving lighter lines through color pictures.
Worn print head. And for what they charge for a stinking print head you can get a new printer for less with a warranty to boot!
Mar 24, 2017 | Office Equipment & Supplies
Yellow ink will not print
You may have blocked yellow print head nozzles.
Try the printer maintenance to clear the printer nozzles.
After several deep cleaning attempts and there is no improvements in the printthen a new print head is required.
A new print head maybe expensive and it maybe more cost effective to purchase anew printer.
The Print head will contain all the nozzels for all the different colors so you cannot just replace a single color print head nozzels.
May 22, 2012 | Canon Office Equipment & Supplies
The printer is recognising that the Yellow is full but when I print out a test page the yellow doesn't print. Is this a printer or cartridge issue?
try to do deep head cleaning, few times. If this doesn't helps you need to remove the ink's and print head and bottom of print head ( where are ink nozzles ) few times press on wet cloath.
Then repeat the deep cleaning.
Aug 04, 2011 | Canon PIXMA iP4000R InkJet Printer
CANON PIXMA IP2000 STOPPED PRINTING YELLOW A FEW MONTHS AGO. WE'VE CHANGED INK CARTRIDGES MANY TIMES, BUT CAN'T GET YELLOW TO PRINT. HOW DO WE REMOVE THE PRINTHEAD SO WE CAN TRY TO FLUSH IT OUT WITH HOT...
OK, since nobody answered my plea for help, I merely opened the Canon monster and yanked out the printhead after lifting up the level. (WHAT was so hard about that, that nobody could explain it here?!)
Cleaned printhead using warm water & ice-cube tray & paper towes. Just let it soak all the excess ink out for a while, then allowed it to dry.
Changed cartridges, put new color cartridge in...
THE DAMNED THING STILL WON'T PRINT YELLOW (altho it will print a faint hint of yellow). WHY IS IT DOING THIS? Why is Canon making this a common problem in the first place, rather than producing a product that is reliable and easy to maintain?
Nov 19, 2010 | Canon PIXMA iP2000 InkJet Printer
Black BCI 24 does not print after replacement.
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Feb 10, 2010 | Canon PIXMA iP2000 InkJet Printer
Canon Pixma ip2000 Inkjet printer wont print black. Replacing cartridge did not fix the problem.
Remove ink cartridges,then print head.
Clean print head with dry cue tips.
Apply strong suction over black print
jets on print head.
Replace print head and cartridges.
It worked for me.
Oct 17, 2009 | Canon PIXMA iP2000 InkJet Printer
Yellow not printing on test print -
You either have a leaking cart or the print head has become cross contaminated. Remove all the carts and check the feed hole under each of them. Make sure they are the color of the ink in the cart. Remove the print head and, using a damp cotton bud (water ONLY!) give the print head a clean. DO NOT use the same cotton bud for all sponges.
If that doesn't solve it then take the print head to a re-inking firm and have it cleaned professionally. Won't cost much and will hopefully solve the problem.
Sep 14, 2009 | Canon Pixma iP4500 InkJet Printer
Canon Pixma won't print
Sounds like you need a new printhead.
QY6-0054-000. around $40.00
Jul 03, 2009 | Canon PIXMA iP2000 InkJet Printer
Canon Pixma iP2000 wont print black ink?
Canon IP 2000 / reset
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
Jun 02, 2009 | Canon PIXMA iP2000 InkJet Printer
Canon PIXMA iP2000 InkJet Printer Logo
118 people viewed this question
old marine
old marine
