Question about Gateway (5502156) CD-ROM Drive
My cd rom is stuck, when i click eject button it won't open.
  • mrvhy Dec 04, 2008
    I cannot get the cd/dvd to open and extend. I have used a paper clip in the hole provided but it still will not open.
  • 153 Answers
There should be a small hole in the front, use a paper clip and push into the hole to eject tray mannualy. The cause of the tray not ejecting is that the belt from the motor that ejects the tray is worn, need to change it.cheers.
Posted on Dec 01, 2008
Gateway dx4200 09 dvd drive will not eject?
Unable To Eject DVD From DVD-ROM Drive With The Eject
The DVD-ROM drive will not open to release the DVD when the button is pushed on the drive. RESOLUTION:
  1. Shut down the program that you are installing or running that uses the DVD-ROM drive.
  2. Wait 10 to 15 seconds, and then open the DVD-ROM drive by pushing the eject button on the DVD-ROM drive.
  3. If the DVD-ROM drive door still does not open, do the following:
    • Insert a paper clip or small pointed object into the small hole near the button on the DVD-ROM door.
      Gently push in the paper clip until the DVD-ROM door opens.
    • Remove the CD from the drive.
To prevent the DVD-ROM drive from exhibiting this behavior again, follow these steps:
  1. From the Start menu, point to Settings, and then click Control Panel.
  2. In Control Panel, double-click the System icon.
  3. In the System Properties dialog box, click the Device Manager tab.
  4. On the Device Manager tab, double-click the CD-ROM category.
  5. Double-click Toshiba DVD-ROM.
  6. In the Toshiba DVD-ROM Properties dialog box, click the Settings tab.
  7. On the Settings tab, clear the Auto insertion notification check box, and then click OK.
  8. Click Close.
Dec 03, 2013 | Gateway DX4200-09 PC Desktop
I have a cd I put in, but do not know how to remove it from my computer need help
1. Open the Computer window on your PC: Either double-click the Computer icon on the desktop, or open the Start menu and choose Computer.
2. Click the DVD drive icon: Clicking the icon selects that drive.
3. Right click on it and choose 'Eject' from the drop-down list.
OR
Try the following only if the above steps didn't work or in times of urgency, such as when the computer is locked up (or turned off), you can manually eject a disc/cd by pushing a straightened paper clip into the tiny hole (the "beauty mark") on the front of the DVD drive.
f90a6593-7fec-4205-a633-379cc4b71e53.jpg8572a8b8-67cd-4c33-bbf8-d5d51bfdd48d.jpg8681c4da-0608-43dc-b4b8-cee760b38e11.jpg
Nov 28, 2013 | Computers & Internet
Cd is stuck in my gateway computer
If you open Computer in the Start Menu, right click on the DVD/CD Rom, select Eject , it still will not open? Look for a "pin-hole" on the DVD/CD drawer, near the button, insert a pager clip. If the CD has exploded, which happened to me, you will have to remove the DVD/CD Rom and dissemble it.
Mar 07, 2013 | Computers & Internet
Dv9815nr cd rom eject button
Yes there is. Open My computer and right click the CD ROM Drive icon and click Eject. This way you can eject your Optical Drive Tray.
Aug 10, 2012 | HP Pavilion dv9815nr Laptop
My cd rom drive has power but when you try to eject the tray it won't go out...my laptop brand is HP PAVILION DV7-1135NR ENTERTAINMENT NOTEBOOK PC
There are two ways to open the CD drive door ifthe button just below the drive tray does not work.
Go to My Computer and right click on the drive and click on Eject.
If this does not work then you can manually open the CD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drivetray next to the Eject button. Push the paper clip gently until the drive traypops out, then pull the tray until it is fully out, then you can remove the CDdisc.
If you continue having problem opening with the Eject button, then the CD drivemay be faulty and needs replacing.
Aug 22, 2011 | HP (198702-001) Plug-In Module DVD Drive
My cd is stuck and the eject button won't eject it. Is there any way I can get it out?
Aug 10, 2011 | Dell Inspiron One 2305 Desktop Computer...
I don't know how to open the CD compartment on this laptop.
Open My Computer, right click on the icon for the cd unit and click Eject.
Dec 04, 2010 | Dell Latitude D600 Notebook
On my HP pavilion mx 75 my hp cd--writer will not open any easy fiX?
Hello
Well, if there is a cd stuck in the device, you might fix this problem by force ejecting the cd/DVD.
Here is how we do this:
Take a small pin, push it into the small hole near the eject button on the CD/DVD rom. While doinf this, gently pull out the trey.
If this was a stuck cd, just take it out, if there was no dc/dvd in the rom, it might be a faulty eject button. Test this by going to My Computer, right click on the CD/DVD rom andd choose to eject.
If this does not work, i would suggest thatyou buy a new drive, because it is often much cheaper than to repair.
Let me know if this work.
Kind regards
Andrea
Feb 17, 2010 | HP (176135-630) (176135630) Internal 48x...
The CD ROM Drive is not ejecting properly
hi,
Locking device / software installed
First, verify no locking software is being loaded, which would allow the CD-ROM tray not to open. If you are unable to determine this, reboot the computer and as it is booting up, attempt to eject the tray. No power to computer or CD-ROM drive
If you have recently installed a new CD-ROM drive or you have moved the computer, it is possible that the power to the CD-ROM may have become loose or disconnected. Check the cable connections. Bad eject button
If you are running Microsoft Windows 95, Windows 98, Windows NT 4.0, Windows 2000, Windows ME, or Windows XP, open My computer, right-click on the CD-ROM drive and choose the option to eject. If this ejects your CD-ROM drive tray, it is likely that the button on the CD-ROM drive has become defective and it is recommended that the drive be replaced. CD stuck within drive
It is possible that a CD may have become stuck within the CD-ROM drive. If the CD-ROM drive has a small hole (that is not the head phone jack), using a paper clip, place the paper clip within the hole and attempt to manually eject the CD-ROM tray. If the CD-ROM drive is only partially able to be opened, attempt to pull the tray gently to see if it can be manually ejected. If it cannot be opened any further, it is likely that the gears within the CD-ROM drive have become bad, dislodged, or that a CD is positioned in the drive, which does not allow it to open. Incompatibility with IDE / ATAPI interface
If you have an IBM compatible computer and recently installed the CD-ROM drive and are unable to open the drive, attempt to temporarily disconnect the IDE cable to verify that you not experiencing an issue with an incompatibility between the CD-ROM and motherboard. Once the IDE cable has been disconnected, power on the computer and see if the CD-ROM drive tray is now able to be opened. If the drive is able to be opened with the IDE / ATAPI cable disconnected, it is recommended you use the interface card supplied with the CD-ROM drive or the ATAPI interface on the sound card / motherboard. Bad drive
Unfortunately, if after following the above recommendations you are still unable to properly open the CD-ROM drive using the button on the front of the CD-ROM drive, it is likely defective and should be replaced. Caution: If you are able to open the CD-ROM drive using a paper clip. We do not recommend that you continue using the CD-ROM drive by manually ejecting the CD-ROM using a paper clip. The drive should be replaced and this is not meant to be used as a temporary solution. Additional information and tips for buying a new CD-ROM drive can be found on our CD-ROM buying tips section.
Jul 02, 2009 | Computers & Internet
CD driver stuck
In the front side of the dvd drive you will see a small hole ...so to eject that cd put one niddle in that hole and .
Now press the button at just after that apply a force on niddle .suddenly you will notice that cd will come outside ,if not try more times and you will learn to eject the cd when you are unable to do it by pressing the eject button...
Low feed backs hurt my ratings and I am tring to help you with your problem,so let me know that the information i given you is helpfull or not.
Thanks
Dilip Bagdi
Technical Associate
Dec 06, 2007 | Dell INSPIRON 6000 CENTRINO...
Computers & Internet Logo
318 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
