CD player will not play
My integra cdc-3.1 player will load 6 discs, but it will not play. The drawer closes and machine goes through the discs and displays the numbers 1 through 6, but they don't play. Any idea what the problem might be?
Judy
  • 905 Answers
Dirty lens , focus problem , laser failure , mechanical difficulty
Posted on Dec 01, 2008
Why does my yahama cdc-505 cd changer not play cd, or change tracks
This is a result of the deck kicking out you disc as an unacceptable media. This usually means that it can not read the data on the disc or the necessary TOC (Table of Contents).
The other possibility is that your draw in detection switch has gone bad and when the processor- control type, tries to load a tray or close the drawer it is not getting the door closed signal. Depending on how the unit is programmed it might just sit there and do nothing or in your case throw the disc back out.
It is kind of telling you it wants to go see a Technician.
It could also be a bad belt that loads the Pickup assembly- it might be good enough to move the drawer in and out but the Pickup assembly needs more torque and it might not be there.
Dec 13, 2012 | Yamaha CDC-505 5-Disc CD Changer
Pwr. on but won't play cd,
The lazer is not reading the info off the disc any more, It is costly to have them (Replaced) $180 to $250.
Nov 01, 2012 | Yamaha CDC-655 CD Player
I have a cdc 675 CD changer, When I close the draw it stays close about 10 seconds, the display reads "open" and it opens back up whether there are discs in it or not
It's reporting that it (correctly or incorrectly) detected that the drawer has not fully "closed", i.e., it thinks that there was a "jam" while the drawer was sliding towards the "closed" position.
This sounds (pun intended) like you need to take the unit to a qualified audio/video technician, to trouble-shoot, and maybe check the "alignment" of the drive-tray.
Sep 30, 2010 | Yamaha CDC-675 5-Disc CD Changer
Need drawer belt for Yamaha CDC-805 CD changer - the one needed that opens and closes the changer's door - not sure where to get it or the part number. I thought I ordered the right one and got the 'drive'...
Any decent repair shop should have a large supply of replacement belts. The Part number isn't necessary. Just take the old one in and get a new one just 2mm smaller than the original. Some repair shops won;t sell them because they don't want you repairing your own property but a decent shop should sell you one.
Apr 07, 2010 | Yamaha CDC-745 5-Disc CD Changer
The disc tray of my Yamaha cdc-745 CD player does open properly.
It's the belt inside the machine - open tray and look in front left side and you will see it. Easy to change out with new one.
Dec 13, 2009 | Yamaha CDC-745 5-Disc CD Changer
DOOR KEEPS OPENING instead of playing
Hi. there is a tiny limit switch that regulates the actual CD platform drawer(The part where you lay down the CD). this switch if faulty. it is designed to shut of the load motor when the CD tray is fully inside the unit.
this limit switch must be replaced. this is a job for a qualified Yamaha service tech. contact Yamaha for this repair.
Jul 29, 2009 | Yamaha CDC-585 5-Disc CD Changer
Cd disc player will not play
Reset the drawer timing. The door switch is not working properly.
Dec 16, 2017 | Audio Players & Recorders
CD tray wont stay closed
Try using a CD cleaner. Generally this sort of problem occurs due to dust accumulating on the lens. The CD cleaner comes along with a solution.just spray on the CD and allow it to play in the CD drive. Sometimes the problem might even be due to a virus. Check whether your anti-virus is up to date.
Nov 30, 2008 | Integra CDC-3.1 CD Player
Yamaha cdc 555 5 disc cd player
If you trust yourself enough to open the case w/o breaking stuff, then open it up UNPLUGGED, locate the laser lens (small,clear,plastic) gently clean the lens with a swab of lens cleaner for glasses.
Also clean the chrome runners that the laser assembly tracks on.
Jan 16, 2008 | Yamaha CDC-565 5-Disc CD Changer
202 people viewed this question
 Grubhead
Grubhead
