SOURCE: ONKYO TX-SR606 Single output to TV
Hi there. for your receiver, the only time it can upconvert is when you go out as HDMI. In your current hookup (component out to tv) the signal from your cable (using a composite) will not be able to pass through the component cable. This means you either have to hook up your cable box using a component cable as well or add a composite cable (yellow) from monitor out of the receiver to the tv. Page 22 of the manual will show a diagram of the video signal flow. hope this helps.. ^_^
SOURCE: I have bad static from my Pioneer vsx 49 Elite
sorry no easy solution as it sounds like the output transistors blew out or the emmitter resistors. you will need a service manual and an multimeter to measure the resistors on or around the audio output transistors they are a low value resistor usually around 1 to 2 watts in size. Do not replace any bad , burnt or discolloered resistors around the audio output transistors as if tou do you might just cause more damage to the output transistorsor audio output stage including the audio driver stage of the amp!!!!!!
Larry Dillon
Testimonial: "Thanks techman for the great answer! This is definitely not something I can do myself so I'm glad I just ordered a working one on ebay. rarejem1908"
SOURCE: I HAVE A PIONEER VSX35
Having a live-and-kicking VSX-36TX receiver which I love, I feel for you. But the prices have come down dramatically since we bought them. I paid $1200 for mine new. If I needed to replace it I would go with a used one from eBay and consider searching specifically for one that uses the same remote but doesn't have one included. The price would be low.
Like this beasty, no remote for $250 delivered:
http://cgi.ebay.com/Pioneer-Receiver-VSX-1014TX-Multi-Channel-Receiver-/150581038944?pt=Receivers_Tuners&hash=item230f544f60
or this one with a remote for $232 delivered.
http://cgi.ebay.com/Pioneer-VSX-516-S-7-1-Channel-Home-Theater-Receiver-/250783994297?pt=Home_Theater_in_a_Box&hash=item3a63e411b9
Carefully examine the front panel for clues like a misplaced Mute or Tape Monitor control or Multichannel Analog Input selected.
There is a good chance that a common control may have developed a high-resistance or 'dead
There is a good chance that a common control may have developed a high-resistance or 'dead' spot through idleness and is causing your symptom. Turn the POWER OFF and operate every control throughout its range a number of times, especially rarely-used ones like Tape Monitors and the Mute control.
Turn the volume to something reasonable and see if that helped.
