Question about Brother MFC 7300C InkJet Printer
Will not print
I have a brother mfc 7300c, I change all the cartridge's, fix all the error codes that were comming up now it wont print anything, It makes all the printing sounds and says it printing, but nothing comes out on paper. I have not use it in some time so I thought maybe I just need to run it a few times, clean all the cartridge's a few times and It would print, nothing. A few times some words came out, but after I ran the clean all the colors about 6 times, and ran a print job with about 20 coppies, nothing comes on the paper, but it thinks it's printing. Do you have any Idea why it is doing this.
    Champion:
  • 320 Answers
 ARE YOU USING BROTHER INK??? I MEAN BROTHER OEM INK.? WHAT YOU CAN TRY IS TAKE A PAPER CLIP AND INSERT IT ABOUT 1/4 OF INCH INTO THE AIR HOLE ON THE CARTRIDGE, SOUNDS LIKE WHEN THE SEAL WAS TAKEN OFF, THE ADHESIVE FROM THE SEAL STAYED ON THE CARTRIDGE BLOCKING THE HOLDE. GOOD LUCK SR BROTHER TECH
Posted on Jan 27, 2009
What does error code 20 mean when printting
take the paper towel and add 20 weight oil to clean crap off the carriage then try again
Apr 21, 2015 | Brother MFC 7300C InkJet Printer
How can I fix no cartridge error on brother mfc-465cn
It sounds like it may actually be the "print head" which is what the carts fit into. These can and will go bad. Sometimes you can find replacements on ebay etc. But you need to make sure it is exactly the same part number. There could also be a number of other issues, the cart contacts could be dirty or damaged (another print head issue resolved by replacing), counterfeit cartridge, bad cart. These are the most common, but not the ONLY issues that can cause your problems. I'd check prices for replacement print head vs. new printer.
Jul 18, 2014 | Brother MFC-465CN InkJet Printer
I do not see anything in the manual for error code 70 on the mfc 290c model Brother. I keep getting a message to check teh User's Manual for maintenance and trouble shooting. TEh machine is less than 6...
code 70 Error are caused by misconfigured system files,If you got code 70 error then 96% chance that your computer has registry problems.I will tell you how to fix it under 2 min and for this you can visit code http://tinyurl.com/nznbpm
Jun 20, 2009 | Brother MFC 210C All-In-One InkJet Printer
I have a brother mfc 3240C. I have changed the
Light/faint prints usually are a result from clogged ink or air bubbles between the cartridge and print head (thus changing cartridge wont fix problem). Try printing the test page print from the machine (Ink Management -> set/ok twice). Answer the question(s) in the display and repeat this up to five times. The colors should be improved after 1-3 test prints usually.
Apr 23, 2009 | Brother Office Equipment & Supplies
MFC 7300C
IT SOUNFDS LIKE THERE IS SOMETHING IN THE WAY OF THE PAPER PATH THAT IS CATCHINH THE CORNER OF THE PAPER, WHAT WE USUALLY DO IS TAKE A 8X10 FILE FOLDER AND MANUALY PUSH IT THRU THE PAPER PATHE TO SEE IF ANYTHING IS IN SIDE THEN REPLUG THE MACHINE AND SEE WHAT HAPPENS, GOOD LUCK BROTHER SR TECH
Nov 06, 2008 | Brother MFC 7300C InkJet Printer
Print function stopped working. Brother MFC 5840CN
First things first:
press menu then start bk-copy then fourtimes arrow-up button. machine will display an error code no. plz post AS A NEW POST again.
BTW: The update has nothing to do with the stopping of the machine!
Jan 10, 2008 | Brother MFC-5840CN All-In-One InkJet...
Brother MFC 5840CNZ displays Ink Empty on CYAN when new cartridge is installed
Something that has worked for some Brother owners to get cartridges recognised.
1. With your MFC powered up, open it up and remove the cartridge you are having a problem with, then close the MFC, leaving it powered up. It should report that there is no cartridge in the machine.
Still with the MFC powered up, open it up and reinsert the ink cartridge, then close the MFC. It should either ask if you have replaced a cartridge or go into its cleaning mode.
Answer "yes" to "have you replaced cartridge?" and it should either "print" or "clean" and then "print".
Nov 08, 2007 | Brother MFC-5840CN All-In-One InkJet...
Printing Problem
SOUNDS LIKE YOU ARE REFILLING YOUR OWN CART. THEY DO NOT WORK WITH BROTHER MACHINE, THE BROTHER MACGHINES ARE SET TO WORK WITH OEM PRODUCTS, CHANGE YOUR INK GOOD LUCK BROTHER TECH
Jan 24, 2007 | Brother MFC 7300C InkJet Printer
Printhead
TRUST ME , IF YOU HAVE NEVER PUT A PRINT HEAD IN YOU ARE IN DEEP S--T. MAYBE THE SERVICE CENTER OR WHO EVER SOLD THE PRINT HEAD TO YOU WILL DOWN LOAD THE INSTRUCTION SHEET. MAYBEEEEEEEEEEEEEEEEEEEEEEE THEY WILL DO IT I DO NOT KNOW AS THIS PRIORITY INFO, GOOD LUCK BROTHER SR TECH
Aug 29, 2006 | Brother MFC 7300C InkJet Printer
Brother MFC 7300C InkJet Printer Logo
140 people viewed this question
CheckitRight
CheckitRight
Soulvisitor
Soulvisitor
Ron Dufek
Ron Dufek
