Question about Dryers
I have a Frigidaire dryer model # glgr341as4 its 4 years old. and the drum will not spin when I turn it on. It does heat up and I hear the motor running
  • 2 more comments
  • star1869 Dec 01, 2008
    Ok.. thats kind of what I thought. How do I fix it? and can I get a belt at homedepot??
    Wow.. Im looking at the diagram and I'm pretty sure I'm WAY over my head. Probably going to call a repair guy. but thank you so much for your help. Happy Hollidays!
  • broken belt.
    Sergeant:
    Champion:
  • 324 Answers
Belt broke
Posted on Dec 01, 2008
  • no you cannot get it at home depot, you can get it from sears.com
    you have to take the front off and put the belt on that way. i think there is a access behind the machine that you can see when you are putting the belt around the pulley.
  • ya it is kinda involved if you have never done it.
Frigidaire dryer not working drum won't spin,
Hi How old is it , ? and dose it soun like the motor is running but not turnning the drum ? this would be a bad belt , you will need to do some more investagating for me to help you
Dec 06, 2011 | Frigidaire Dryers
My dryer won't start. When i activate the start switch I hear a hum like the motor is bound up.. I opened the top and the drum is not stuck and the belt seems in good shape. The unit is about 4 years...
check the blower wheel sometimes objects get caught in it not allowing it to spin. If it is clean open the dryer door push and hold the door switch and push start while it is humming rotate the drum. if it starts to spin then you need a new motor it will run you probably 150 - 200 dollars
Jul 14, 2011 | Frigidaire FEQ1442ES Electric Dryer
My Frigidaire Affinity electric dryer will not start. Its only just over 2 years old. the timer counts down but the drum will not turn nor is there any heat. I've tried jumping the dryer but it still will...
Listen, when you push the start button to hear a low hum, if you do hear this it maybe that your belt is broken. This is an involved job but can be done if you are handy.
Jan 22, 2011 | Frigidaire AEQ6000ES Electric Dryer
My dryer will not spin. It turns on, but doesn't spin.
Do you hear the motor turn on? If you do, most likely the drum belt has broken. The belt tensioning device is known to break as well causing the drum not to spin.
Hope this helps
Dec 20, 2010 | Frigidaire Dryers
When Turned on, drum will not spin?
if the motor is running,your belt is the problem.if all you hear is a slight humming noise,you may have a bad motor,or something caught in blower. if the drum turns easily by hand,its probably the belt
Mar 05, 2010 | Frigidaire GLER341A Electric Dryer
Dryer will not turn
hello check to see if the long pin inside the door has not snaped off if thats ok .then check capacitor next to the motor inside the dryer may have blown
regards
shaun
Mar 01, 2010 | Frigidaire Electric Dryer
The dryer sounds like it's on and heats but drum will not turn
Your dryer drive belt is broken it sounds like. You hear the motor running but ti does not spin right? If so that is the issue.
mrstan
Aug 29, 2009 | Frigidaire FEQ1442ES Electric Dryer
Frigidaire Dryer making loud thumping noise in back.
Some things to check.
Worn rear drum rollers, idler pulley, or drum front slide kit.
Click here for illustrations.
Hope this helps.
Aug 12, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Whirlpool dryer WED5530SQ0, heats but does not run
So,. basically your drum doesnt turn. SO your getting heat still even though the drum isnt turning. Is this right? Sounds strange??? Do you hear any humming noise when you push the start button? I need to know a little more about the problem because im kinda confused as how you decribed the problem. Iv never seen a dryer heat but the drum not spinning. especially your model dryer. Its electric heat right? because if the drum doesnt spin, maybe your motor is bad. and if your motor is bad, then your heating element wont heat up because the centrifical switch in the motor is not switching to complete the circuit to the heating element. So this is why im confused when you said" Dryer heats when knob turned but when "push button" pressed, drum doesnt run." Because your belt wraps around the motor pully and the motor is what makes the drum turn. Like i said, i never seen this model dryer heat with out the motor operating. So if you can give me some more info, ill do my best to help you out....Thanks!!!!
Jul 30, 2009 | Whirlpool WED5500S Electric Dryer
Dryer motor
if the motor buzzes when you push start then it is a bad motor.as long as the drum turns freely by hand.
Oct 29, 2008 | Whirlpool LER4634J Electric Dryer
Dryers Logo
77 people viewed this question
Top Dryers Experts
Marvin
Marvin
