Question about Hoover Vacuums
My Hoover 97441-980 Dual Steam Vac won't hold detergent. The valve is bad. How can I get the old valve out so that I can replace it?
    Scholar:
  • 55 Answers
Just grab the valve stem with a pair of needle nose pliers and pull it out, then you can gently work out the outer valve with the pliers, and then remove the gasket. The older tanks tend to crack around the valve which may be the whole problem, but the good news is that the new replacement valves and tanks are much better.
Posted on Dec 01, 2008
I have a Hoover Steam Vac Dual Model # F7426-900. The nozzle and spring from the bottom of the soap dispenser popped out. Can this be fixed?
You will need a new valve assembly. ( part # 43513014, msrp $3.62 ) Place the rubber seal in first, then wet the valve and push it in with your thumb.
Jun 24, 2011 | Hoover Steam Vac Dual V w/ SpinScrub...
My Hoover steam vac dual v clean water and detergent tank leaks water before attached to the vac and during cleaning
This is a common problem with the earlier models which had a separate soap tank glued to the clean water tank. The plastic was too thin beneath the valve on the clean water side and would develop cracks. You most likely will need a new one piece tank. ( Part # 42272104)
May 21, 2011 | Hoover Steam Vac Dual V w/ SpinScrub...
Hoover steam vac dual v carpet cleaner has stopped dispensing soap. Water is still flowing fine
You probably have a solenoid valve which has failed and will not open. This will require replacement of the valve. For temporary use you can mix a soap solution and put it in the rinse tank. The correct mix is 5 ounces of Hoover shampoo to a gallon of hot water.
May 17, 2011 | Hoover Steam Vac Dual V w/ SpinScrub...
I have a Hoover V2 Steam Vac widepath and the
This is a notorious problem with the Hoover V2 SteamVac's. In fact the tank design by Hoover on your SteamVac was so bad, that Hoover redesigned this tank almost immediately due to the numerous problems customers were having.
For your particular problem, you really have two options. The first option is putting a bandaid over the problem, but will still fix it. We sell the entire gasket assembly on the bottom of the detergent tank as a replacement part. Unfortunately it's sold together with the seal, spring, and valve together as an assembly;
http://www.govacuum.com/hoover-steamvac-dual-v2-tank-valve-part-43513015.html
You also may wish to fix the problem completely by replacing the entire clean water solution tank. Hoover has redesigned this tank, and the new one I don't see near the amount of problems that I do on the older style tanks. The plastic is much more sturdy, and less prone to having the gasket and valve issues that the old tanks do. It's important to point out that the new tank does not come with the handle. You'll need to remove the handle from your old tank if you buy a new tank assembly complete. Rest assured that if you do purchase any part from GoVacuum, you'll have 60 days to return it for a full refund, just in case the repair doesn't work. Not only do we not deduct restocking fees or shipping charges, but we also include a return label with every order that you may use to return any item to us, and we'll even pay for your return shipping!
Here's the Hoover SteamVac V2 Clean Water Solution Tank, Part 12002549
If you'd like us to do a repair photograph series on this repair of the valve and gasket assembly, please just request a repair clarification here on Fixya, and we'll be happy to do so. If you found this helpful, please be sure to rate the review as helpful by clicking on the 4 Thumbs Up Icons in the top right hand corner of the repair.
Thank you so much,
Chris J.
GoVacuum
Mar 23, 2010 | Hoover F7425-900 SteamVac V2 Widepath...
Hoover Dual V steam vac model F7425-900 won't dispense detergent
Check the spring loaded valve at the bottom of the detergent bottle.
Push it up with your finger or a pencil or some such thing and see
if fluid comes out. If it does, then the problem is the valve or tubing I
would suspect.
Tom
Oct 22, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
Hoover steam vac dual v makes humming noise and nothing else.
Is the overfill valve (the yellow thing) in the waste container stuck in the up/full position? Maybe it just needs to be rinses well to avoid it being stuck and shutting off the vacuum portion of the cleaner.
Oct 09, 2008 | Hoover Steam Vac Dual V w/ SpinScrub...
Water and cleaning solution will not dispense unless I hold it for a while
check the belt on the pump it should be a cover on the side pull the belt to the pump if its glazed replace if not then clean the shaft old soap may be on there.
Oct 03, 2008 | Hoover Steam Vac Dual V w/ SpinScrub...
Brushes not rotating on my Hoover Steam Vac Dual
The brushes are all connected to a single shaft. This square shaft is connected to 2 sets of gears and then another shaft which is turned by an impeller (suction from the vaccum pump is used to turn the impell and thus the brushes). There are 2 bearings that the impeller shaft turns on. It's likely these are rusted up and just need a bit of WD 40. Took me 30 min to take apart, lube, and put back together. Remember, its plastic. If things won't come apart, look for another screw. Mine was a brand new unit and the top bearing was rusted.
Sep 22, 2008 | Hoover Steam Vac Dual V w/ SpinScrub...
HOOVER F7430-900 STEAM VAC
I recommend to use the same detergent that came with the machine. Some detergents can cause problems such as damaging seals and causing build up. Hope this helps, post back.
Jun 23, 2008 | Karcher DE4002 Steam Vacuum
Vacuums Logo
76 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
