I have a RCA 52inch D52w136D, the power button blinks three times, but nothing happens no picture or sound
  • Jose Velez
    Jose Velez Dec 01, 2008
    fuise is go tv nothing happens
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, pls try:
  • unplug from the mains for an extended period to reset;
  • if blinking, press and hold the power button to try and engage the diagnostic scan. There should be a flash followed by a series of flashes. Pls count and determine the sequence. This would be necessary to zero in to the probable area where to start diagnosis;
  • there is a probability that this is also a loose connection/cold solder. Pls try clean the inside and verify all connectors are snug & tight and all solder joints are shiny, not corroded nor dull/grayish;
  • in some instances, the blinking is accompanied by the relay clicking at the rear of the unit, if yes, then unplug, dissipate stored electricity and check the HOT, visual inspect the FBT and the HV cap.
This of course would require a fair familiarity of electroniccomponents/circuitry and safety procedures, use of a DVM and asoldering iron. It would be to your added advantage access to a servicemanual (ITC221) or at the very least a schematic diagram with voltage readings.Should you be uncomfortable performing a DIY (do-it-yourself), perhapsyour best bet would then be to seek the services of a qualifiedprofessional.
If the above solution has merit, pls click on my "Ask Me" to explore further or rate as you see it fit.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Posted on Dec 01, 2008
    Genius:
  • 1,847 Answers
Ou need to replace the flyback, and that will fix your set. You can geta replacment flyback at the following link and they will provide freeonline instant messaging when you do the repair so they can take youthrough the replacement step by step. You need flyback number 259296heres the link.
http://servicemanuals.vstore.ca/
    Sergeant:
    Champion:
  • 283 Answers
Check first the fuse of the power supply. Post for more details. Dont rate me yet if not fix your problem. Thank you...
  • amin dianalan
    amin dianalan Dec 01, 2008
    Then check the switch relay.Thank you.
When u push the power button the tv tries to turn on, makes 3 switch noises and then the power turns off
this is somtimes a bad power supply or fuse if you have sound it likly and no picture usaly a fuse put this seems pretty much like a power supply issue this regulates power from the wall to each component of the tv like the picture and the souns amp
Dec 20, 2009 | RCA D52W136D 52 in. TV/DVD Combo
I OWN AN RCA 52INCH REAR PROJECTION SCREEN TV...WHEN I TURN IT ON...A GREEN LIGHT APPERARS AND BLINKS 3 TIMES AND STOP...WITH NO PICTURE OR NO SOUND....PLZ TELL ME WHATS THE PROBLEM?...IS IT WORTH...
24.95 the kit is called the CP150, CP114 and CP120 capacitors repair kit listedunder RCA reapair kits at www.tvrepairworld.com The kit contains the capacitors and detailed instructions on CD
Nov 05, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
No picture or sound
Does anything start to work? Any of the three fans start to turn, Lamp ignite, etc., when you press the power button or does nothing happen before the Red LED starts blinking. How many times does the RED LED blink?
Jul 25, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
Sony 52inch projection nothing happens,timer light blinks all the
check powr suply for a sony wite ceramic fuse 0.01 ohm
if open rebuild or replace power suply befor turning on the unit check the H.O.T high v transistor if shorted replace and also replace vdr610 602 and 603, depending on set flyback should be changed also due to a know internal arking problem with sony fly backs.
25% of the time its just the power suply that goes bad.
Jan 09, 2009 | Sony KP-51HW40 51" Rear Projection...
TV will not turn on.
On the Deflection board check capacitor cp150- 2200uf 16v if it is puffed up on top it is bad,replace 2 other caps in same circuit also cp114- cp120 -220uf 35v. they are green with gold writing on them.
Dec 24, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
No picture (fan& bulb do not come on) but there is sound
Nov 19, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
The sound went out while watching a program on the set.
It sounds like the IC that controls the sounds has gone. Once upon a time they used to start with the letters TDA and other sets of letters that would make them instantly recognizable but nowadays it could start with anything so unless you know what you are looking for call out a technician. Good luck.
Sep 28, 2008 | RCA D52W136D 52 in. TV/DVD Combo
Green blinking power button
Sounds like an internal fuse or a power supply problem. It is worth it (I don't normally say this) to get this set fixed.
Jun 25, 2008 | RCA F36650 36" TV
50 inch 1999 TheatreView Television
#1 When I turn on the TV the power button comes on then blinks 6 times then goes off for a few seconds then repeats the cycle. I have sound over my surround system during this time but no picture.
#2 My sound would crackle and pop every once and a while until now it does nothing. I have to watch it with the surround sound on.
Nov 26, 2007 | RCA HD52W59 HDTV Projection Television
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
