Question about Digi Open Box 50000704-01 ACCELEPORT 16P PCI ADAPTER DIGIBOARD (5000070401) Serial Adapter
HITACHI DIGI BOX
I CANNOT SAY THAT IS THIS PARICULAR BRAND OF DIGI BOX AS IT HAS HAPPENED ON ANTOTHER BOX I HAD. THE THING IS THE PICTURE AND SOUND BREAKS UP INTO LITTLE SQUARES AND FREEZES. I CAN SOMETIMES MOVE THE BOX AROUND AND IT IS ALRIGHT FOR A WHILE BUT THEN IT SLOWLY STARTS GOING AGAIN. CAN ANYONE ADVISE ME AS TO WHAT I CAN DO TO RECTIFY THIS. MANY THANKS. sorry I typed in uppercase I did not mean to be impolite
  • Anonymous Apr 09, 2008
    c annot get picture
How to diagnose a tv problem
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jan 31, 2016 | Hitachi 42HDF52 Television
Digital noise when using ANY HDMI inputs or cables on Insignia 37" LCD TV
Most of the time it will involve replacing the entire board that connects to the HDMI and outputs associated with it--not a cheap fix and good luck finding any board for this brand set.
May 25, 2012 | Televison & Video
I have a plasma 55 dirctors cut. No picture or sound was told upper y board was bad replaced it and still doing same thing
It is really hard to fix sets like this without voltage checks, but if you have any led lights flashing this may tell what is wrong with your set. Also if there are lights in the back of the set that are flashing on the logic board or the Digi-Main PWB But usually with a bad digi-main you have audio, also check the buffer board and see if any holes lie in the buffers. These are the boards on the far left side of the set looking from the back. The buffer chips are the black square IC's sometime you will see chip pieces out of the buffers. This mean that one is bad.
Feb 28, 2011 | Hitachi 55HDX99 55 in. Plasma HDTV
MY HITACHI 50GX30B HAD BLURRY VISION LIKE
Sounds like the convergence board, try replacing the STK voltage regulators and any resistors that may burned or discolored. This problem is causing the power supply to shut down probably.
Mar 13, 2010 | Hitachi 50GX30B 50". Rear Projection...
RCA TV Model F32685
if cable network in tv is using a digi.box with a scrat to the tv, then just unplug scrat and plug it back in, make sure it is fitting corretly-if not working then change scrat lead,
If no digi.box in use redo connection that is there.
In most cases its not the tv. at fault.
Aug 07, 2009 | Hitachi CLU-4324UG Remote Control
Hitachi P50H401 video goes off and on
this is from a tech tip I got that should help.
No Picture:
1. The Power Supply may not be producing the correct voltages.
2. The Digital Module (Digi-Main) may not be producing correct
turn on commands (Power 1 and 2).
3. The Logic PWB may not be supplying the correct Vs/Va turn on
commands (Vsago and Vcego).
The Panel can have a defect of two natures.
1. The panel is shorted.
2. The panel is defective, but not presenting a short.
3. Y-SUS and/or X-SUS may be defective (Shorted and or nonworking
May 01, 2008 | Hitachi P50H401 50 in. Plasma HDTV
42HDS69 plasma Hitachi
My had the same problem, red light on bule led on but no sound or picture ...can any one help??? I appreciate
Apr 09, 2008 | Hitachi 42HDT52 42 in. Plasma HDTV
Hi I have just set up
Ok, have solved it!
I hadn't placed the "magic eye" in the right position on the Sky digi box.
Now have Sky in my kitchen, a good picture, sound and the remote works great!
Mar 20, 2008 | Philips Televison & Video
Computers & Internet Logo
81 people viewed this question
Top Digi Computers & Internet Experts
Alun Cox
Argospete
Argospete
Don Hart
Are you a Digi Computer and Internet Expert? Answer questions, earn points and help others
