Question about Water Heaters
Water heater doesnt heat up
Everything seems fine but water heater wont heat up
  • 3 more comments
  • Benni Buxton
    Benni Buxton Mar 16, 2009
    I also have a Richmond 6EM30-2 30 gallon tank. Last night, I had hot water; today, lukewarm. This is an electric heater about 10 years old, so I got a feeling it's gonna be an element going out. However, the Richmond online parts replacement list is Greek to me; the label on the heater says 8 volt AC, wattage is 240-208. Does anyone out there have an idea what catalog number I need for a resistor replacement element?
    Thanks!
  • Benni Buxton
    I forgot to add the model number for the Richmond electric water heater above; it's model number 8MV40-2. Sorry!
  • Allen Neal
    Allen Neal May 11, 2010
    what kind of hwh
  • Allen Neal
    MAKE OF WATER HEATER AND WHAT KIND ELECTRIC GAS OIL ECT
  • larry rosen May 11, 2010
    i need to know wether heater is electric/gas or oil make and model
Our gas water heater does not heat the water. Pilot is on everything else seems fine.
Posted on Feb 03, 2009
  • 145 Answers
Has the unit every been cleand you can check the it in the service door
Posted on Dec 12, 2008
Heater wont start. I replaced the pressure witch, doesnt work, I by passed the pressure switch and put the red and blue wire together and it will run until it gets hot. I remove conected wire and...
What water heater do you have?
Is this a tankless or tank-type water heater?
If tank-type, what gas valve is on the heater?
What does the water heater manual say?
Add a comment with more information for possible help, or possible re-direct to correct expert.
Sep 22, 2011 | RELIANCE ELECTRIC WATER HEATER
Water heater not working after turning up heat
Did you turn the breaker completely off, then back on? When a breaker trips it is in a middle position, and nust be turned off to reset it, then it can be turned back on.
Mar 14, 2010 | Stiebel Eltron TEMPRA 24 Tankless Water...
We have a new Rheem 30 gal short water heater. It only seems to put out about 10 gallons of hot water before it starts going cold,any suggestions......
I am assuming that everything was fine and then all of the sudden available hot water usage time dropped.
On a dual heating element hot water heater it can be
1. Internal tank loaded with sediment (drain and purge from lower garden hose fitting)
2. Thermostat or element problem with ONE of the 2 heaters. (Trouble shoot element thermostat)
3. Check Circuit breaker for partial trip of the breaker.
Feb 14, 2010 | Rheem 30 GAL ELEC SHORT Water Heater 6YR...
The hot water and central heating wont work together
what size of gas line is going into boiler and water heater? is it black iron ? natural gas or propane? have you checked gas pressure at water heater and furnace ? if they work fine individually then you have a problem with incoming gas pressure. Call gas company and ask them if they would come out and check gas pressure.
Feb 03, 2009 | Water Heaters
Parkray Cumbria efficiency problem
Some circulation pumps have a 3 phase mixing valve (cold,warm,hot) to regulate the water pressure in the building; no way to know unless you trace the plumbing. Basically, the hot water temperature could be lost because the circ-pump is cooling it with the cold water supplied to it. This is used to balance the pressure (aka Pressure Balancing Circ-Pump), so heater is really working overtime to heat the water. If the pump has two in and one out that's more than likely your problem; but you should consult a "old-school" plumber in your area.
Nov 25, 2008 | Water Heaters
Water Heaters Logo
953 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
