Question about True Food VWR Storage Refrigerators with Stainless Steel Doors, 1 to 4°C T72NCVWR w/ FREE UPS
HI: We have a 6-7 yr old TRUE single door, stainless steel fridge. We noticed yesterday ..that at "4" on the temp dial, the fridge is freezing milk in glass gallon jars. We backed the temp down to "2" and the problem persisted. I also noticed that the fan continues to run, although we ahve turned the temp dial to "0". The compressor does kick off when we turn the temp dial to "0", but the fan will not turn off...it runs constantly. Could we be in need of a temp control or fan switch? We are in N GA...are there factory authroized service people here? Thank you! Deb Ridings
  • True Master
  • 1,262 Answers
With the refrigerator, the fan inside the conditioned space should always run. This is normal for most all commercial refrigerators. Need to check to see if the unit is shutting off the compressor after the conditioned space reaches a good temp, usually 35 degrees. If not, probably a bad thermostat.
Posted on Jul 28, 2017
SOURCE: Box Not cooling
Jumping wires out is a good way to KILL SOMEBODY!!!!! You have no idea what you are doing, PLEASE unplug it and call a refer guy.
Posted on Aug 07, 2008
  • 89 Answers
SOURCE: My True beer fridge is freezing inside.
call repairman sounds like low on freon or thermostat problem either way better to have pro do it hope this helps
Posted on Sep 05, 2008
farfield
  • 462 Answers
SOURCE: i have a 2 door reach in true freezer which is now
If its getting warmer or more humid where you are this is probably a sign of needing to clean your outer coils. Remove the panel covering the compressor and check the condition of the coils. Clean with a nylon brush or wire brush. Or blow out with compressed air.
If the outer coils look OK see if they feel warm up and down the sides. If they don't you may have a defrost problem. If they are warm recheck them in 30 minutes if still warm or warmer and no one has opened the door check the lite inside, and the fan inside (it will only run with door closed). Hit the switch and see if lite goes out and make sure the switch is being activated with the door closed. And check the door seals any vinyl cracked on them they need replacing but can be warped sometimes letting in warm air (usually a sign of frost inside the door or water leaking out but not always).
It could be low on refrigerant or an inefficient compressor but not likely as much as these other items are.
The last thing is the thermometer could be reading wrong or out of calibration. Is it Electronic? Yes - Then its most likely one of the other problem before. If its mechanical (bi-metal) get another thermometer you trust or a new one and check it before you trust it. 2 of them telling you its 5'f then Id believe it other wise one or both of them are wrong.
Posted on Mar 12, 2009
  • 7 Answers
SOURCE: commercial TRUE GDM soda machine
If the cooler has power, the condesor fan (bottom) and evaporator fan (top) are spinning put your hand on the compressor. Do you feel a vibration? if so, you probably have a refrigerant leak. If not (if its clicking or nothing at all) its a compressor issue.
Posted on Aug 13, 2009
  • 1262 Answers
SOURCE: my true back bar cooler dosent cool it is not iceing over
If you can gain access to the compressor, you will see 2 copper lines going to the compressor. One is smaller than the other. VERY CAREFULLY lightly touch the smaller line while the unit is running. If the compressor is running, that line will be extremely hot.
Start there.
Let me know if I can be of further help.
Posted on Jun 29, 2010
My True TSD-33G freezes drinks overnight.
T-stat is overshooting or contacts on t-stat are sticking, replace t-stat and problem should go away. Don't forget to clean your condensers. That was just a helpful reminder.
Apr 02, 2014 | True TSD-33G Stainless Steel Cooler...
The fridge is freezing my milk, lettuce and fruit. The temp was set at the recommended 38 degrees. What do you recommend?
Hi, There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
Refrigeratoris Too Cold and Freezing Food
heatman101
May 09, 2011 | Maytag MFI2568AES Stainless Steel Bottom...
Liebherr KBES 3650 - too warm in main fridge compartment. Hi the main fridge compartment of this larder fridge warmer the it should be (milk does not taste as cold as it should). The temp...
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 16, 2010 | Liebherr KBES3650 Stainless Steel...
Fridge not keeping things cold enough
fridge coldest setting is 1
freezer warmest setting is 1
Dec 08, 2017 | Fisher and Paykel E522BLXEZ EZKleen...
Fridge door not closing 100% at the top.
Loosen the screws holding the top door hinge. Pull up on the freezer door and hold it while you re-tighten the hinge screws.
Dec 31, 2009 | GE Profile Arctica Stainless Steel Top...
MY 9 YR OLD FRIDGE IS FREEZING MILK, JUICE AND ALL LIQUIDS IN THE MAIN COMPARTMENT BUT NOT NECESSARILY ON THE DOORS
you gotta send model number,there are different things that can cause this,if the freezer is on top,the cold air from the freezer gets blown into the fridge in the center of the top shelf so if any food is near this it will freeze if the air isn't monitored, check the settings first,it could be set to high, there's a cold control or thermostat that monitors how much air comes into the fridge and when it reaches a certain temp it shuts off but it sounds like your having a problem with it,also on some fridges they have a damper that can mess up,there's a door on it that doesn't close and the cold air just keeps coming into the fridge and things start freezing up
Dec 24, 2009 | Refrigerators
Freezer/fridge fluctuates freezing/cooling
Yes, that is one problem.  The refrigerant needs to remove the excess heat through the condenser coils.  If the air flow is blocked, it will do those symptoms you described.
May 18, 2008 | LG (LRBC22522ST) Stainless Steel
GE PFS22MISBBB freezer not cold enough. Temp won't reset.
replace the fan as quickly as possible it may be shorting and causing damage to your control board,
Mar 30, 2008 | GE PFS22SBSSS Stainless Steel French Door...
True Food VWR Storage Refrigerators with Stainless Steel Doors, 1 to 4°C T72NCVWR w/ FREE UPS Logo
94 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Are you a True Refrigerator Expert? Answer questions, earn points and help others
